Old 24th February 2006, 21:19   #1
luv_bikelover's Avatar
Thumbs up woofers in rear seats
hey bhpians this is luv here, i am taking out my rear seat of wagonr and putting 3 jbl 100 watts and 4 amps 440 do you have any suggestion will it work out in right way what amount you think i should spend o this modifiation morover i own an ikon and a xing too so should i do it on wagonr or xing or ikon , i guess wagonr has that shape too carry on such high systems what do you say
luv_bikelover is offline   Reply With Quote
Old 25th February 2006, 11:30   #2
navin's Avatar
Thanked: 4,282 Times
I did something very similar to a contessa about 15 years ago
There is no need to discard the rear seats. I would do this to the Ikonand use the trunk as a big sealed box. 3 10" woofers powered by about 600W rms in a big sealed box can be very effective. let the wofoers fire though the rear seat.
Old 25th February 2006, 11:46   #3
Godfather's Avatar
Thanked: 65 Times
.. currently i am running two 800W 12" pioneer subs in my esteem's boot and also i had the boot covered with waste cloth and then sealed with carpet. The effect is really good..
Godfather is offline   Reply With Quote
Old 25th February 2006, 11:58   #4
I would either use the Santro or the Wagon R as they like hatchbacks and the bass would be right there in the cabin. There is no need to remove your back seats.
5u3zEr0 is offline   Reply With Quote
Old 27th February 2006, 10:27   #5
navin's Avatar
5u..., Bass will penetrate right thought the rear seat. In the contesa I had to modify the rear seat a little.
Old 27th February 2006, 18:15   #6
Navin, yes bass will penetrate but will it match the hatch's bass? Plus the dicky could rattle away with those three subs unless he spends on Dynamatting.
Old 28th February 2006, 09:48   #7
navin's Avatar
when i built the contessa system dynamat was not available locally. i used fiberglass insulating material for damping much like the stuff they use in speaker boxes.
In fact the seat will act like a low pass filter. the bass will be lower in volume but the low bass will be well defined.
Changing OEM seats with 'Sport' seats? redsfx Modifications & Accessories 49 21st April 2014 17:21
Sub woofers - Are they bad for the car? neoranjit In-Car Entertainment 32 15th June 2005 09:50
Woofers CaliAtenza In-Car Entertainment 22 19th May 2005 15:12
3 amps, 4 tweters, 4 sub woofers, 2 12''s??? N.J In-Car Entertainment 19 27th April 2005 15:03
