Old 1st March 2006, 13:15   #1
nitrous's Avatar
Thanked: 285 Times
Default Connecting 2 amps to a HU. Impossible??
Hi ICEmen,
After deciding to combine two cars' ICE setup and plonk it in a single car(ikon).
I'm facing this difficulty:
My plan:
HU: Pio 6750
Front spk: Stock(from ford)
Rear spk : Pio 6990 (on MDF parcel tray)
Sub 1: Pio 305F (on MDF parcel tray)-powered by Sony xplod 502 amp
Sub 2: Pio 305C (in MDF Enclosure)- powered by pio 6000F amp
The 6990s are also powered by the 6000F amp
My installer said its impossible to jointly use 2 amps without an equalizer.So, this is the current config.
Everything as said above, except:
Sub 1, Sub2 and 6990s are all powered by a single 6000F amp. :(
Is it possible to connect 2 amps to an HU so that i can configure the setup as per my plan mentioned above. If so, how??
Thx in advance
Old 1st March 2006, 13:22   #2
rareone's Avatar
Thanked: 11 Times
Post Facing The Same Problem
This is my request to allthe audio guru's here.
Please help us and guide how 2 connect 2 Amps to a Single HU.
Right now the audio guy in my area has doubled the RC Cable to give audio input 2 the amps.
Wud like 2 knw is the setup right for proper sound output, or is there any other method.
Please Guide
Thanx
rareone is offline   Reply With Quote
Old 1st March 2006, 13:35   #3
prince85's Avatar
Thanked: 117 Times
nitrous as far as my knowledge tells me is that to connect 2 amplifiers (4ch and 2ch or monoblock) u need to have 3 pairs of rca pre-outs. The pioneer 6750 has 2 pairs of pre-outs which will at best work with a 4 ch amp or two 2ch amps.
I would suggest you to exchange your head-unit for one which has 3 pairs of rca pre-outs ie pioneer 5750, 7750, P1Y etc.
I am sure the audio gurus like sam, gunbir, audiophile, navin, jkdas and others will chip in their views .
Hope it helps. Cheers.
prince85 is offline   Reply With Quote
Old 1st March 2006, 13:49   #4
navin's Avatar
Thanked: 4,284 Times
Originally Posted by nitrous
Hi ICEmen,
My plan:
HU: Pio 6750
you can connect 2 amps all you need is a Y connector. However make sure this connector is laid out where there are no power cables as you can introduce alternaor noise very easily.
HU Front------> front speakers
Rear ------> 6000F --------> 6990
Sub -------> Y connector ------> 6000F --------> 305C
_______________________------> 502F --------> 305F
OR
Rear ------> Y connector ------> 6000F --------> 6990 and 305C
In the second option the 6000F must have LPF engaged for channels used for the 305C.
If the 6000F has a fullrange out that can be used to feed the 502 and then you dont need the connector.
Old 1st March 2006, 13:59   #5
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Like navin said a Y connector is all u need .. Should be available at prices ranging from 350 - 600 depending on the make ..
Old 1st March 2006, 14:31   #6
nitrous's Avatar
Thanked: 285 Times
Thanks, guys.
My installer says there is provision for just a single front/rear RCA output and a Sub output only.
I have a feeling there are 3 pairs.One for the front, rear and Sub.
Can anyone confirm??
Old 1st March 2006, 16:36   #7
prince85's Avatar
Thanked: 117 Times
Old 1st March 2006, 17:00   #8
rareone's Avatar
Thanked: 11 Times
Thumbs up
Thanx for the details of previous query.
Can anyone suggest which one is the best pioneer HU when i have
2 Sony 504 Amps + Sony Rear Speakers (4way i think) + 2 SOny 12" Subs,
with Pioneer Tweeter & Sony Front Speakers.
Wud b glad for suggestion & idea's.
Thanx a lot
Old 1st March 2006, 17:23   #9
navin's Avatar
rareone, the HU can be any that fits your budget, aesthetics, and sound.
Uber needs a Hotline number! Driver has a heart attack and it's impossible to reach them afunnynut Street Experiences 58 10th June 2016 12:36
My Racing Journey - Chasing the impossible dream goingout Motor-Sports 17 8th February 2015 08:03
Ex Army MM 550 - "It's tough, but not impossible" 4x4army 4x4 Vehicles 180 24th April 2014 17:00
Namma Bengaluru Recreated in Vancouver - Mission Impossible PAVAN KADAM Shifting gears 12 15th June 2011 22:46
Pandit claims Registration impossible w/o permanent address proof EssYouWe Indian Car Dealerships 20 23rd September 2009 10:59
