Old 15th November 2016, 13:57   #211
swami69's Avatar
Thanked: 463 Times
Default Re: ICE upgrade : Mahindra XUV 500
My ICE on a BUDGET
Just wanted to share what I did which may help others who may be in a similar situation.
I already had a FOCAL SOLID 4 amp with me which I retrieved from my Fiesta - so that expenditure was saved
Requirement :
Clean, crisp sound with good sound staging and imaging
Minimal expenditure
Minimal removal of panels
Not to touch the Centre consol and HU at all
Minimum disruption to OE wiring
Thought about this for quite some time and made the following :
Instead of choosing components for all 4 doors OR choosing Components for front and Co-ax for rear doors, due to budget, i chose 4 x Rockford Fosgate Tri-axials at Rs. 3500 per pair for all 4 doors - Total Rs. 7000
Also mounted my earlier JL Audio Tweeters to the Front door sails as an addition to improve the imaging as they are fantastic tweeters. Wierd, probably, but..
Since this amplifier can take Line Level Inputs, WITHOUT touching the HU and centre consol, just tapped the speaker level inputs from all 4 doors and drew two lines to the amp - 1 for the input and the other one for the output back to the door
Connect all 4 speakers to the FRONT CHANNEL and now the amp see them as 2 Ohms load which is Ok for this amp as per specifications - NO FADING possible
Used a SPACER to mount the speakers and put a 1 foot x 1 foot Dampmat just behind the speaker magnets for minimal damping
Wires were neatly drawn through the door trims and Amplifier placed under the passenger front seat
Speaker wires, Power wire, fuses, installation, damp mat, spacer and all that costed me another Rs. 3000
Total Rs. 10000 for the installer and it sounded nice.
But, I wanted to complete the setup using a SUB WOOFER to take care of the low frequencies and anyway I have an amplifier and started the DIY last weekend. Again, budget was an issue.
Bought 2 x 6.5" DAINTY sub woofer drivers from Ritchie street for Rs. 1300 total. I chose this originally to squeeze it between the rear door and last row seat. But later decided to make a descent box which I have now put on top of the folded seats at the end. If this was the case, I could have gone for a 10" straight away, anyway, no regrets.
Made a rectangular box of 1 cu.ft volume without any dividers
Used 1/2 plywood cut to size - 2 pieces each, then FUSED them to make it 1" thick (had these plywood in my house, so no expenditure)
Lined up the sides and rear inside with FELT lining (had them earlier)
Bought a 6 feet x 1 meter Carpet (Rs. 300) and nicely covered the sub woofer enclosure
WIRED the sub woofers in SERIES to make it 4 Ohm load for the amp in BRIDGED mode
Man, it has become heavy due to 1" thick and absolutely solid
and it sounds FANTASTIC exactly as I like
TIGHT, CLEAN and sufficient low end to complete the dynamics. I may not need anything more that this
Even with this in the boot, i have sufficient space. This will only need to be removed from the car IF all 7 seats are occupied which is extremely rare for me. Removing is simply taking the wires off from the terminal.
My reference songs to ensure it works OK are below :
  • Jennifer Warnes "THE HUNTER" album - Song Way down DEEP, some serious low end loose vibrating bass
  • Eagles, Hotel California & Mark Knopfler "Private Investigation" songs to test the Sound Stage and the tighter bass respectively
  • Varanam Ayiram Tamil movie songs to test the other instruments and Vocals
and it came out to my satisfaction.
Hope it helps.
Swami
swami69 is offline   (2) Thanks Reply With Quote
Old 5th January 2017, 15:53   #212
SteeringStar's Avatar
Thanked: 49 Times
Originally Posted by swami69 View Post
My ICE on a BUDGET
Swami
Thank you for the detailed write-up. I recently bought an XUV and is looking for a ICE upgrade without touching HU and dash. Am planning to request this set-up to my local shop here as I'm not confident on doing it myself.
Btw, could you share some snaps of the set-up especially the one that show sub set-up?
SteeringStar is offline   Reply With Quote
Old 25th January 2017, 18:41   #213
SPEEDY_RACER's Avatar
Thanked: 172 Times
Default Re: XUV 500 niggles and their solutions
Though its not a Niggle/Issue but a question to all XUV owners who have the latest W10 Model.
I had a plan to install a Sub-Woofer in my W10, hence approached a known person who is a good friend and he flatly denied stating that in this music system they can't fix the same. How true is this? Any one tried installing the sub-woofer?
Last edited by SDP : 25th January 2017 at 19:58. Reason: Post moved to appropriate thread
SPEEDY_RACER is offline   Reply With Quote
Old 25th January 2017, 23:09   #214
Very much possible. I have it in my w10 though I have a bigger setup wherein I have replaced all factory speakers. You need to install a mono amp and converter in case you want to put sub alone. Any one of the speaker outputs can be tapped for this.
anishr is offline   Reply With Quote
Old 13th February 2017, 17:37   #215
supertinu's Avatar
Thanked: 481 Times
Originally Posted by Night_Hawk View Post
Last weekend, upgraded ICE of my December'2014 red cheetah.
Opted for Sportstage Peak Power 3000 Watts audio enhancement kit by JBL.
Hey NightHawk, hows the upgrade been? Was there an issue with in famous humming sound that comes due to high level inputs to amp?
Anyone else on the forum tried this same product? I am interested given it has DSP integrated. Would that be a significant ROI?
supertinu is offline   Reply With Quote
Old 22nd February 2017, 05:12   #216
Originally Posted by abhi182 View Post
For folks looking for a minimal modification way to fix the hollow/tinny sound from the stock HU/speakers, simply plug in an under seat Subwoofer
It took me all of 1 hour from start to finish and the end result is a much richer and fuller sound
I used a Blaupunkt XLF 200-A underseat subwoofer (approx 11K) with line level inputs
The wiring was quite straighforward - The kit comes with the power cables
I added an in-line fuse at the battery tap and ran the power cable through the existing firewall
The speaker level input was tapped from the front right door without cutting any harness
The entire job required removal of just two fiber panels (the XUV-500 footlight panel and the panel next to the front door) to route the cables and the door panel to tap into the speaker output
The end result will not please an audiophile but the cost+effort to improvement ratio is very very high
vocals now are a lot more richer (which was my biggest complaint with the stock setup) and obviously bass beats are a lot more pronounced
Hi Abhi182,
I will be getting my XUV w6 automatic delivered in March and planning for the same setup! Just wanted to know a couple of things:
1. How is the wiring done through the built-in touch screen? Is there any provision for RCA to attach the woofer? How easy it is to attach to the stock setup?
2. Where did you place the woofer? I'm planning to keep it in the trunk (in standing position)
3. What if at the same price I upgrade the stock nippon speakers to Kicker/Rockford/Polk audio coaxial speakers?
mayank1908 is offline   Reply With Quote
Old 12th June 2017, 15:10   #217
Default Need Advice: Speaker Upgrade on XUV 500 W6
Mod note: Post moved, please use Search before opening a new thread. Topic already exists. Thanks.
Folks, Greetings to all and hope its been a good start to the monsoon to all BHPians out there...
I own a XUVee W6 and is a 2013 model. I am in the middle of my own XUVee facelift (of which I will post my experience a little later), I am looking to upgrade the speakers.
Stating a fact, the stock speakers in the XUV are pathetic and I finally have grown tired of listening music in retro mode ...
So my XUVee speakers need an upgrade and so does my knowledge of the ICE world. I have tied up myself in knots trying to figure out the bits and pieces of ICE world, the 2-way, 3-way speakers, the components, the multi-channel amps and so on.. and here's where I need your help and advice...
The requirement -
The head unit will stay as-is as various other controls seem to be integrated and I also do not want to disturb on that end.
I am also not a "bass" person so the sub can also take its time and with the rest of the mods on my XUVee, a 15K (stretchable a bit) budget also does allow space for a sub.
At this point, I am looking for a good set of speakers, if not mind blowing ones, a set certainly much much better than the stock ones. I do listen to all kinds of music starting from KL Saigal to Benny Dayal, from Beatles to Enigma to some moderns ones including Indian classical instrumentals.
So, as a starting point I am looking at a decent set of speakers. The questions I have are noted below. While I have tried to go thru'
lots of posts on that, I am not sure if I can make sense of the specs or alterations mentioned in various posts are valid to XUVee. Since I'm new to
this ICE stuff, I also ended up confusing myself.
So to start,
1. How does #A whether to go for components at the front and coaxials at the rear (middle row)
compare with #B component systems at both front and rear in XUV ?
2. My Options for a good speaker upgrade are..
Option #1 is POLK DB6501 Component system and Polk db651 co-axial speakers for the middle row.
Option #2 is JBL CS-760CSI 6.5 Inches 2-Way 360W Component for front and Polk db651 co-axial speakers for the middle row.
Can I mix and match JBL for component and Polk for coaxials like option #2 above ?
3. Does it need any alterations on the OEM wiring starting from head unit or is it just plug the speakers and forget ?
4. For a speaker upgrade, do I need an Amp, Do I really need a 4-channel amp only keeping in view of possible addition of a sub at a later date ?
5. I am not a fan of Bass and hence don't need Subwoofer, so do I still need an amplifier given that the component sytems above already have crossover filters?
(So how different is a crossover to an Amplifier?)
6. I see some good deals on Amazon, or other e-tailers, Is it worth buying there from the Warranty and service perspective?
7. Do I need to get damping done to the doors ? Is it mandatory ?
Any help on the questions above will be really appreciated !!
Last edited by Jaggu : 12th June 2017 at 18:18. Reason: Please stick to two smilies per post. Thanks.
The_Wanderer is offline   Reply With Quote
Old 12th June 2017, 18:36   #218
My ICE on a BUDGET
Hope it helps.
Swami
Mr. Swami,
What you've done looks to me like something I want to do to my XUVee. Thanks as it gave an idea of how it looks like. I looked into lots of posts and ended up confusing myself (am new to ICE) and this helps a bit.
Last edited by benbsb29 : 12th June 2017 at 18:52. Reason: Trimmed long quoted post for readability.
Old 14th October 2017, 16:18   #219
Prash22's Avatar
Thanked: 89 Times
Hello, I’m looking for suggestions on amplifiers and sub woofers. I plan to maintain the stock head unit and speakers, looking for 5 channel amplifier to power 2 front and 2 back speakers and a sub woofer. Need suggestions for a good detachable sub woofer too.
Also, any recommendations in Bangalore for a good buy and fitting. Thanks!
Prash22 is offline   Reply With Quote
Old 14th October 2017, 16:24   #220
Travelator's Avatar
Thanked: 130 Times
Originally Posted by Prash22 View Post
Hello, I'm looking for suggestions on amplifiers and sub woofers. I plan to maintain the stock head unit and speakers, looking for 5 channel amplifier to power 2 front and 2 back speakers and a sub woofer. Need suggestions for a good detachable sub woofer too.
Contact Sachin's autoshop in Kormangala. They are usually good and have a complete wiring kit can allow installation of any setup with Amps and components. Holds good for the new gen XUV.
For the older gen, you can opt for JBL soundstage, which is recommended by Mahindra as well.
Travelator is offline   (1) Thanks Reply With Quote
Old 16th March 2018, 16:56   #221
Audio Experts - need some advice.
I am planning to buy a XUV500 - W6 in the next couple of weeks and planning right now to put together a plan to upgrade it once I take delivery of the vehicle. have removed items from my prev car and have some items already with me.
This is what I currently have
Head unit - Pioneer 8890 BT
Component - Polk Audio - DB series - DB6501
Subwoofer 12 inch - MTX - RT1204
DLS 4 channel - XM 40 - 400 Watts RMS
Acoustics Class D - Mono
Power Cables & RCA - Pretty good quality ( Kanban)
I do intend to buy one more pair of components to be used at front and will move the Polk DB components to rear door.
With the loads of ACC and other features of XUV inbuild within the factory infotainment, getting away with that and replacing with after HU doesnt seem be an option.
I can spend an additional 75 K over and above the existing items I already have.
1. What would be the best way to draw inputs from Stock HU to amp. DLS XM 40 does take in Line inputs.
2. How does one feed input to the MonoBlock. Would line out from 4 channel work as input feed to Mono Block.
3. Not a fan of HI low convertors. how does LC 7 score or do we have some better DSP options.
4. what would be the suggestion for front components. XM 40 can drive upto 100 watts RMS per channel at 2 ohms and drops down as Impedence increases
5. Ideal place to fix the amps. Tail area doesnt seem to be a place of choice to me.
all 7 seats wont be used mostly and last row can be kept folded.
Note - All my prev installs have been done by Anwar ( Top gear , Bangalore), pls do allocate some amount of that 75 K I can afford to Damping. I do have good quality cables and RCA already in hand.
Regards, Vijay.
vijay_n81 is offline   Reply With Quote
Mahindra XUV500 W8 AWD : Long Term Ownership Report. EDIT: Now sold! .anshuman Long-Term Ownership Reviews 243 12th October 2017 10:28
Mahindra XUV 500 - Moondust Silver - Loaded with chrome - first in Delhi Pankaj_Ahlawat Test-Drives & Initial Ownership Reports 191 23rd March 2015 01:26
Metro and City Discrimination By Mahindra- XUV 500 Launch anjan_c2007 The Indian Car Scene 18 29th November 2011 15:10
