Old 19th January 2015, 20:47   #16
Umesh Kumar61's Avatar
Thanked: 21 Times
Default Re: CD Error- Fiat Linea
Originally Posted by DerAlte View Post
Get it serviced by A.S.S. - likely to be a dirty lens or faulty drive motor (less likely)
* One can't really hear the spinning sound in any CD player
* By the time the CD comes out, it has already been 'braked' - it is not sent out spinning
* Yes, all CDs get ejected 'the same way' the are inserted! If you mean the label print hasn't moved an inch, the possibility is that the drive motor has gone bad. Only the service guys can find out
Thank you Der.
Sorry for confusing. I meant the label hasn't moved. But seriously you can hear the cd spinning sound (very very soft sound ) when you keep your ears near the HU while it's muted. Havent checked it other cars. Anyways I'm taking it to A.S.S. Hope its covered in the extended warranty.
Umesh Kumar61 is offline   Reply With Quote
Old 19th January 2015, 21:17   #17
Mr.Boss's Avatar
Thanked: 2,548 Times
Originally Posted by Umesh Kumar61 View Post
OEM HU is a Blaupunkt. Should I take it to the A.S.S or is there any quick fix or DIY. Also, Im not much bothered about the Cd, if I can get the aux in.
A.S.S don't entertain HU repair. Get it repaired outside.
For AUX DIY, refer the below thread.
http://www.team-bhp.com/forum/diy-do...aux-input.html
Mr.Boss is offline   (1) Thanks Reply With Quote
Old 20th January 2015, 09:43   #18
Thanked: 21 Times
Thank you Boss,
I've read your thread earlier. That's a great DIY and you were so lucky to get that cable from that shop! I too tried to source it from eBay, but no one ships to India.
I'm taking it to an accessory shop when i get time and hope to get it repaired.
Do I need the code card after repairing.I have to contact FASS to get my Code card for the stereo. I've lost it.
Old 20th January 2015, 12:28   #19
Mr.Boss's Avatar
Cable I used is custom made (DIY) you can get it done from accessories shop.
For the radio code there is (or was??? I'm not sure) an android application. With your HU serial number you can get the Radio code. Let me check to find the name of application.
Old 11th August 2015, 21:29   #20
anand.shankar's Avatar
Thanked: 314 Times
Default Re: Fiat Linea Head-Unit Issues
Had the similar event on my 2015 EVO, I plug in the USB nothing happens. SRC doesnt pick it up as well. But the Autoplay and Media Player option did it. All is well now!
anand.shankar is offline   Reply With Quote
JVC Head Unit Problem. revtech In-Car Entertainment 13 5th October 2015 12:05
Bluetooth pairing issues with Audio Head-Unit triedeverything In-Car Entertainment 12 16th June 2012 10:07
Need a DVD head-unit Sahil In-Car Entertainment 1 24th June 2005 13:43
Pioneer 5750 Head Unit neverclever In-Car Entertainment 4 14th June 2005 07:09
