Old 24th March 2006, 17:26   #16
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by SLK
OK, lets see what I can do about that!... a woofer... & an AMP.
Heyyy! A woofer and an amp was never the original plan.
Anyway, now I got a great idea. Use a great 4" component, or better still, rip open the door panels and make way for a nice 6" comp with some spacer rings.
Next (now this may sound cheesy, but it'll work) have a speaker guy take out the tweeter posts from both 6x9s and replace them with some dust caps instead. Connect both terminals of the 6x9s in parallel to the rear output of the head unit in bridged mode. The manual will show you how to. Look in the Direct Sub Drive (DSD) section. Follow the instruction to set the HU to "Rear Speakers - Sub" from "Rear Speakers - Full" which is the default. And voila, you have a 2-ohm sub with the cone area equivalent of approximately two 8" subwoofers and you save the money you would've spent on an amp. The HU delivers about 50 W rms when connected like this. You could leave the tweeters on the 6x9 if you want to avoid the surgical procedure, but how functional are ovaries on a 80yr old woman?
Old 24th March 2006, 17:37   #17
Thanked: 294 Times
I agree with bass&trouble fully with this setup
Old 24th March 2006, 18:25   #18
SLK
SLK's Avatar
Thanked: 192 Times
Yes.. indeed its a very good suggestion. Making fullest use of every resource.
SLK is online now   Reply With Quote
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
Maruti WagonR over Hyundai Eon? EDIT : Bought WagonR with ABS / Airbags BoneCollector Hatchbacks 35 22nd May 2015 11:49
Only a WagonR can replace a WagonR ! From F10D to K10B.. DCEite Test-Drives & Initial Ownership Reports 27 19th April 2014 23:02
WagonR or Swift?(calling swift and wagonR owners) rajshenoy Hatchbacks 43 29th March 2007 09:54
