Old 15th February 2012, 23:21   #1
rmk
rmk's Avatar
Default Reverse Camera or MapmyIndia touchscreen unit with cam support?
Hi all...
Im planning to install a rear view camera in my new i20. My parents will be using the car mostly and both of them have issues while reversing and parking. Now my doubt are,
1. Our dealer has quoted Rs 13K for a unit named Autocar (china i guess). The display unit looks cheap. I dont know of any other reputed brands available in the Rs 15K range. I invite your suggestions on this
2. The new mapmyindia touchscreen units come with rear cam support. They are also selling compatible rear camera units for Rs 2300. Aint it a better idea to buy a navigation unit (Rs 12000 for the one im considering) and install a rear cam to it, than to spend Rs 15K on some Chinese brand?? Does it work fine? Has anyone tried this???
thanks in advance.
Takecare
rmk is offline   Reply With Quote
Old 16th February 2012, 00:28   #2
Thanked: 74 Times
Default Re: Reverse Camera or MapmyIndia touchsreen unit with cam support??
Originally Posted by rmk View Post
Hi all...
thanks in advance.
Takecare
You have answered your own question. Cost wise and quality wise, including aftersales service, the May my India setup is better for your parents/ you.
I have tried the same out in my i10 since i didn't want to go in for a separate setup for a reverse cam and gps. Its been working well till now with absolutely no issues, except that the Map my india PND needs a charger at all times, battery doesn't last more than 2 hrs without the charger. So incase of reversing either you'll have to plug in the charger or make sure the unit is always charged.
Hope this answers your query.
kevinephraim is offline   Reply With Quote
Old 16th February 2012, 00:38   #3
Abhinav667's Avatar
Thanked: 94 Times
Hi all...
Autocar?? Hormazd Sorabjee won't be very happy to read this. Stay away from it, for 15 k you'll easily get a branded unit.
thanks in advance.
Takecare
MapMyIndia should be decent, however do have a have a look at Caska first. It is decent for its price, and I have seen a number of BHP-ians installing it in their cars. I am not really sure if Pioneer or Sony gives Navigation as a feature, but before you finalize anything do visit a couple of shops that fit accessories in cars. It'll give you an idea about the prices and will help you decide too. Overall, its either Caska or MapMyIndia
Abhinav667 is offline   Reply With Quote
Old 16th February 2012, 07:07   #4
Thanked: 65 Times
I have MapMyIndia Navigation in my car.
Also bought a reverse camera and plugged it into the navigation.
It works well.
Plus,Navigator has bluetooth connectivity, so you can pair your phone. So answering calls or listening to music while driving is also possible.
Reverse camera alone may not be sufficient,because in bright daylight, one can hardly see a thing,so suggest you also keep a reverse sensor.
Rameshdude is offline   Reply With Quote
Old 16th February 2012, 19:20   #5
rmk
rmk's Avatar
Another option that im considering is the Necvox roofmount and connecting a rear cam. There are necvox roofmount units available for rs 7000 which has decent quality displays.
Old 16th February 2012, 19:45   #6
libranof1987's Avatar
Thanked: 4,203 Times
If you are considering the MMI + Rear camera just because the only-rear-camera option is not worthwhile, why don't you consider other companies for the reverse camera.
I have Blackcat reverse sensors in my City and they work fine. You could check out the reverse camera from Blackcat.
libranof1987 is offline   Reply With Quote
MapmyIndia's Smart Mirror: Integrated IRVM, Reversing camera & Navigation solution GTO Modifications & Accessories 9 19th August 2015 09:25
MapMyIndia Connect: Mirror your phone screen to the Head-unit witwiky In-Car Entertainment 1 30th November 2013 10:45
ICE for Toyota Altis J - 2 din touchscreen with gps/bt/reverse camera skuz In-Car Entertainment 8 13th August 2012 14:37
Xenos reverse camera unit fixed in Tata Safari RavenAvi In-Car Entertainment 13 11th January 2012 15:52
Enfield Bullet:Cam gear backlash and solutions including adjustable cam spindles deepclutch Motorbikes 73 17th December 2008 00:47
