Old 1st April 2006, 13:59   #46
Sam, I can't find the 1202 and 1204 sub parameters. Could you also tell me how much they cost?
By the way, I got the number of the person who sells peerless india drivers in Mumbai. But the problem is, as Navin said, getting it to Bangalore. And I also have to check them before buying them. I cannot do that.
Vivekphadnis is offline   Reply With Quote
Old 1st April 2006, 15:44   #47
Sam Kapasi's Avatar
Thanked: 1,474 Times
here you go
1202 is a dual voice coil sub, there is no sub-driver called 1204.
Old 1st April 2006, 22:47   #48
Thanks Sam.
Qts=0.44. Cms=242. Bl=7.71. Xmax=12.5mm. What say?
Old 2nd April 2006, 01:23   #49
navin's Avatar
Thanked: 4,346 Times
Fs 24
Vas 100
geez this thing can go low if put in a large box.
I would recommend the aperiodic box about 2cu. ft for this.
at 2 cu. ft. Qts will jump to 1+ so using a aperiodic vent you can bring the Qts down to a more manageable 0.8 or so.
BTW this is back of the head calculations. use Box Model or Box Plot or Perfect Box for a more accurate box.
Old 2nd April 2006, 14:31   #50
Sam, I have another big favour to ask you. Could you let me have the TS parameters for GT4-10 and GT4-12 too. I want to have a look at their figures too.
Do you guys think something like two 10 inchers would beat the daylights out of my neighbours? Or should I stick to just one driver?
Old 3rd April 2006, 10:46   #51
navin's Avatar
advantages of using 2 10 v/s 1 15" (similar to advantages of using 2 8" over 1 12")
15": lower Fs, higher Xmax and so usually a 15" moves more air than 2 10", huge Vas - in most cases 2 10" will need a smaller box than 1 15.
10": Smaller Mms and higher BL/Mms ratio which means that the bass can be made quite tight. With a 15" you would get some bloom. Then again I have used 18" with little bloom.
unless we know the specs of saythe GT4-10 vs the GT4-15 we cant accurately make a decision on this.
Old 3rd April 2006, 13:09   #52
Navin, do you remember Arasu from diyaudio.com. I had totally forgotten that he makes drivers apparently of fairly good quality. Do you have any info on that?
Old 3rd April 2006, 13:54   #53
Bass&Trouble's Avatar
Thanked: 74 Times
I am sure you mean 'boom'. Unless the subs in question are actually flowering.
Old 3rd April 2006, 13:54   #54
navin's Avatar
I do. Is he not the guy from Calcutta?
Old 3rd April 2006, 23:28   #55
No. Arasu is the Bangalore guy. He has one 12 inch sub. Vas=156L. P=100W. Xmax=8mm. Qts=0.45. Rubber surround. Paper cone I think but not sure. About 2K. The Vas is really high, don't you think?
Old 4th April 2006, 10:16   #56
navin's Avatar
big Vas and rather high Qts means rather large selaed box.
Old 4th April 2006, 12:16   #57
So they are not worth trying? I am okay with a big box but not too huge.
Old 4th April 2006, 14:04   #58
navin's Avatar
I would look at a box between 40-80 liters. I know this is a huge range but I think 40 liters might just work in your car.
Old 4th April 2006, 22:17   #59
Sam Kapasi's Avatar
Navin!! He wants to use it in his home!!
Old 4th April 2006, 23:56   #60
Fresh problems. Arasu does not have 10 or 12 inch drivers in stock. Only 8 inch ones. They are rubber surround sandwich cone. 40W, Xmax=4mm. fs=28Hz. Qts is around 0.4 or something. Now what?
Car HU for home audio use? jaibir In-Car Entertainment 16 21st June 2009 00:18
help me choose for 60% highway use 40% city use nawabnabeel SUVs, MUVs & 4x4s 43 7th April 2009 17:48
40k for fronts and 2 subs - Car ford fiesta Magma In-Car Entertainment 31 18th March 2009 22:41
Please Review Soomoku Subs & Speakers SoundManiac In-Car Entertainment 68 19th June 2007 21:03
Amps / Subs abhibh In-Car Entertainment 3 31st March 2006 10:32
