Old 5th April 2006, 10:21   #61
navin's Avatar
Thanked: 4,282 Times
how much are they for?
4mm is rather small. for an 8" sub i'd like to see 8-9mm atleast. 4mm means that the driver might be a better midwoofer than a subwoofer.
however i gotta see other specs too
Cms, Mms, Vas, etc.
Old 5th April 2006, 21:41   #62
Exactly what I was thinking. Xmax does not look that good. Each is about Rs 550 I think. Will have to check that properly. Samuel Jayaraj suggestes pro audio drivers. Samuel has a source for Eminence sub drivers.
But tell me, if I get a good quality driver like Eminence, would one 12 incher (maybe 200W RMS) be enough for serious thumping?
Vivekphadnis is offline   Reply With Quote
Old 6th April 2006, 12:33   #63
To add to post no 62, I spoke to Mr Dilip from Dev Electronics in Mumbai. He has peerless india sub drivers. 10 inch= rs 3500. 12 inch= rs 4500. He was not sure the model numbers. But the problem is that I cannot see the drivers.
Old 6th April 2006, 19:00   #64
Sam Kapasi's Avatar
Thanked: 1,473 Times
Tell Dilip your my friend. He will send you the woofers. ask him to speak to Sam before sending. Set.
Old 6th April 2006, 21:02   #65
You are some character Sam. Is there any audio dealer you do not know?
Now, I am in the mood to try something like a horn design or tranmission line when I get hold of some good drivers. I want to do something big. Opinions please anyone.
Old 6th April 2006, 23:23   #66
navin's Avatar
Sam, Vivek, I'd love to see these woofers. esp if they have reliable spec sheet attached.
Old 7th April 2006, 00:26   #67
Navin, the specs are all on the site. I looked them up from peerlessaudio.com
Old 7th April 2006, 12:39   #68
navin's Avatar
if Dilip can deliver these drivers go ahead but i doubt their published specs.
http://peerlessaudio.com/products/dr...n3.asp?pname=9
Resonance Frequency Fs 24.7 Hertz
Sensitivity E 89.99 dB
Thiele Small Parameters :
DC Resistance Re 4.72 Ohms
Compliance Cms 435 mm/N
Equivalent Volume Vas 172.25 Ltr.
Moving Mass Mms 95.45 g
Mechanical Q Qms 5.05
Electrical Q Qes 0.34
Total Q Qts 0.32
Piston Area S 518.75 Sq.cm
Force Factor Bl 14.41 N/A
this driver will be ok till about 32Hz in a 65 liter box with a 3" dia 5-6" long port.
i would be interested in this one
http://peerlessaudio.com/products/dr...n3.asp?pname=1
Old 7th April 2006, 13:00   #69
What to do now? That is the question. But what if I can get hold of an Eminence Lab 12 driver? WOuld that not be a better bet?
Old 7th April 2006, 13:02   #70
navin's Avatar
Have seen good and ordinary Eminence subs in India. the better ones were 8 and 10". so lets see the specs first.
Old 7th April 2006, 13:07   #71
what about pro audio sub drivers? What brands do we get in india?
Old 7th April 2006, 13:09   #72
navin's Avatar
quite a few but their Fs is too high and the Cms to stiff for home use. pro audio drivers are built to take huge ammounts of power over log duration.
you are looking for a Maruti not a Mack truck.
Old 7th April 2006, 13:19   #73
Oh God! I think I will call Mr Dilip again and find out what models he has. Then we decide. right?
Old 7th April 2006, 13:22   #74
navin's Avatar
yup. lets see what dilip has and also if he has something other than PI.
Old 7th April 2006, 17:07   #75
Thanked: 54 Times
Default beyma
hey ,guys i would suggest that you look at beyma as well . The drivers are quite reasonably priced and its easy to get them and start off . they had studio series of subs as well as professional series
I have beyma 12 " and i can tell you they are excellent .vivek ,since you happen to have some experience with electronics ,i wud suggest that you try looking for beyma subs .
Car HU for home audio use? jaibir In-Car Entertainment 16 21st June 2009 00:18
help me choose for 60% highway use 40% city use nawabnabeel SUVs, MUVs & 4x4s 43 7th April 2009 17:48
40k for fronts and 2 subs - Car ford fiesta Magma In-Car Entertainment 31 18th March 2009 22:41
Please Review Soomoku Subs & Speakers SoundManiac In-Car Entertainment 68 19th June 2007 21:03
Amps / Subs abhibh In-Car Entertainment 3 31st March 2006 10:32
