Old 28th March 2006, 16:17   #31
Autophile's Avatar
Originally Posted by viper
Hey,
You can try Esoteric Audio, Kimber Kable and Stinger as well. Kimber is excellent but priced a bit on the higher side.
Viper
Kimber is not practical in cars...very thin sheathing...prone to cuts
Autophile is offline   Reply With Quote
Old 28th March 2006, 16:53   #32
kb100's Avatar
Originally Posted by Bass&Trouble
The Alpine 545 is 300W rms at 12 V. That isn't extraordinarily higher than the 275 which is about 270W rms at 12V. Which is why your money is better spent on a cheaper 4-ch from Alpine. But if you are hell bent on spending the moolah on the 545 ($650, gosh), please go ahead.
For the system in concern, I think your total budget for cabling should be about 7000.
Breakup
1. 3 x RCA cables @ 1000 each: Rs. 3000
2. Power wiring kit incl fusing & dist block: Rs. 2000
3. Approx 15-20m speaker cabling @100/m: Rs. 2000
Don't waste money buying ridiculously expensive brands like Kimber. Let it be proportionate to the amount you're spending on your other gear.
Now Zats exactly what I wanted!! Thanks B&T
Originally Posted by navin
I agree 200% with B&T.
Both Monster Jr. and Streewires are available for about Rs. 1200 per pair. It should suffice.
Kimber and co are a sheer waste in the car.
The prices B&T has given are spot on.
Thanks Navin
Now my earlier question - TWO different makes of two way COMPONENTS .. one rated at 93db ---- the other at 97db ... what should I make out of this??
kb100 is offline   Reply With Quote
Old 28th March 2006, 17:02   #33
Sideways's Avatar
Thanked: 18 Times
Thanks Navin
Sujith,
Gunbir's nswered your question in post # 22.
Sideways is offline   Reply With Quote
Old 28th March 2006, 18:15   #34
rsjaurr's Avatar
Thanked: 27 Times
Kb100,its same for subw and speakers.97db spk will be lowder but not much.
rsjaurr is offline   Reply With Quote
Old 29th March 2006, 11:23   #35
navin's Avatar
Thanked: 4,282 Times
oh no...Sam please read this post....gonna get technical! :-)
Most speaker measurements are part fiction and part fact just like the balance sheets of most publicly listed companies. :-) LOL
Saying a speaker is 97db sensitive (in volt terms) is a very small part of the story. I have seen speakers rated at 86db/1W/8ohms sound louder than a speaker rated at 90db/1W/8ohms. Why? Well it all depends on the techniques used in making these measurements. The IEC and AES have some guidelines for these but no fixed regulations.
This is why just as the publicly listed companies one reads through the reputation of the speaker company and this knowledge unfortunately is emprrical and changes as the company's management changes.
If Paul Klipsch says (ok said) his speaker was 103db/1W you believe him. If Mathew Polk says the same I dont nesscarily believe him unless the specs are independantly verified.
I am not saying MP is a bad designer but that in many cases his measurement techniques favour his speakers. Is this fair. Technically yes. Morally wel lets jsut say I'd buy a pair of Richard Vandersteen's speakers instead.
Now some claim that a speaker's votlage sensitivity should be the average across the audible frequency spectrum in an anechoic chamber at seas level at 25 deg C.... Now you know where the errors can creep in. (a) what is the correct audible spectrum and it is relavant (b) where does one get an anechoic chamber? (c) should it be measred in a 2pi space ot 4pi space...
This is what a John Atkinson of Stereophile article once said
"In general, my measured sensitivities are slightly low compared with those published by the speakers' manufacturers. Mostly, I believe this is due to the optimistic nature of published sensitivity specifications."
the whole article can be found here. http://www.stereophile.com/reference/99/index.html and funnily i have realised I dont realyl care for many speakers that are prefered/recommended by Stereophile. :-)
the present method most companies use it to pick 4 or 5 freq. point and take an average. this method is largely unchanged since the 1940s and I wonder why. With the advent of the PC any P4 based computer would be able to do analyse a more sophisticated mean of the freq. curve.
Picking arbitaray points on the freq scale leaves too much room of manupilation and error.
This link provides some simple explanations of the terms used for measureing loudspeakers. http://www.svconline.com/mag/avinsta...ing/index.html
back to the question asked. which speaker shoudl i choose 97db or 93db. I'd say listen to both. Then use your ears and what's between them.
DRA Labs makes a Loudspeaker Measuring System called MLSSA (pronouced Melissa) see what they say....http://www.mlssa.com/pdf/MLSSA-Brochure.pdf and BTW MLSSA is an industry standard. LEAP/LMS, CLIO, Calsod are for poorer souls like us DIYers.
Old 29th March 2006, 11:56   #36
kb100's Avatar
WOW.... KOW-TOW@NAVIN
MODs... We need a KOW_TOW smiley badly!!!
Thanks Navin... very informative... !... and proves a few things I thought are right!
Old 29th March 2006, 12:02   #37
navin's Avatar
KB, What is a KOW_TOW?
Old 29th March 2006, 12:04   #38
mohit's Avatar
Thanked: 125 Times
http://en.wikipedia.org/wiki/Kowtow
All you want to know ....with a pic
mohit is offline   Reply With Quote
Old 29th March 2006, 12:09   #39
navin's Avatar
Sorry I was not clear i meant in conext of this forum. How do you want to KOW_TOW here? is there a particular graphic you desire? remember I am not so PC literate as you guys.
Old 29th March 2006, 13:50   #40
Navin, how different can anechoic chambers be? All they need is a room where sound reflections are kept to a minimum. Regarding measuring equipment I agree that some companies might skimp.
And what is the problem in measuring all voltages in the frequency spectrum instead of just 4 or 5 pts?
Vivekphadnis is offline   Reply With Quote
Old 29th March 2006, 16:21   #41
navin's Avatar
anechoic chambers are hardly different but how many speakers you hear tested in one? I know many reputed european brands that dont test their speakers in anechoic chambers.
Not that a AC is a requrement to produce good sounding speakers. If it were these good European brands would use one. but when you have so many variables in testing a speaker we have to rely on the speaker manufacturers reputation above most other parameters. just as you would rely on Infosys's balance sheet to be accurate than say Essar's.
Old 29th March 2006, 16:42   #42
Autophile's Avatar
Anechoic chambers are used by manufacturers as a controlled environment to develop the speakers.
In that controlled environment it is easy to monitor the final outcome by altering minute details in the loudspeaker design.
Don't worry much about anechoic chamber because none of us has listening rooms or cars designed like that.
Manufacturers measure sensitivity in different areas like freespace, halfspace, anaechoic chamber etc. generally with the difference of 1m between speaker and mic.
Old 29th March 2006, 16:57   #43
kb100's Avatar
Yes .. just like the hand clapping smiley here - there is one which shows the figure bending - If I remember right is is also available on Yahoo/msn will check and post one if I can.
It for sure can be used to acknowledge supremacy , as a salute , to pray, or at times even to Beg!!! :-) lol
Old 29th March 2006, 17:44   #44
jkdas's Avatar
Thanked: 1,436 Times
GURUS... WHATS with the "DB" Pls??
DB 12yrs back when I was a teen was debonair ( the mag not the sub/tube thats making news here at ICE)
Old 29th March 2006, 18:09   #45
kb100's Avatar
JK ... ... you read THAT????
psst: can we swap collections??
Alert - Fake JBL products (Amps, Speakers, Subs...) Sam Kapasi In-Car Entertainment 44 18th January 2012 12:24
Confusion v/s Confusion geek Sedans 32 7th July 2006 19:23
five by five seismic Introduce yourself 2 10th May 2006 20:31
