Old 30th March 2006, 17:07   #1
abhibh's Avatar
Thanked: 34 Times
Default Amps / Subs
Just a simple question how to judge which amp / subs is better in output ?
Like if i have all the details. like:
• MOSFET Power Supply
• Maximum Output Power:
1 Ch x 600W at 4Ω
1 Ch x 1100W at 2Ω
• Frequency Response :5Hz-300Hz
• Low Pass Filter(selectable):5Hz-300Hz, -12dB/oct
• Signal to Noise Ratio:100 dB
AND
• MOSFET Power Supply & Output Stage
4 Ch x120W at 4ohm
2 Ch x 120W + 1Ch x 300W at 4 ohm
4 Ch x 150W at 2 ohm
• Low Pass Filter(selectable):50Hz-300Hz, -12dB/oct
Now which onw of the above is better. How to judge ? Plz give some tips.
Old 30th March 2006, 17:35   #2
jkdas's Avatar
Thanked: 1,436 Times
The first one is a mono amp ( read just for sub use); damn powerful...600W @ 4ohm!
The second is a 4 channel amp; which too is quite poweful and can even be used for a sub + 2 speakers or just for powering 4 speakers (but I guess you got the freq. response of teh second amp wrong)
Old 30th March 2006, 18:30   #3
Thanked: 294 Times
i agree with jkdas the second one must be for speakers but the freq response is max 300hz this is some type of misprint I belive
Old 31st March 2006, 10:32   #4
navin's Avatar
Thanked: 4,284 Times
the 1st amp might be better amp than the 2nd. why?
check out the 4ohm v/s 2 ohm ratings. the first one's rating almost doubles while the second one barely increases. it means one of 2 things (a) the transistors int eh seond amp cant dump much more current than they are doing at 4ohms (b) the seond amp has a very tightly regulated power supply.
that said the 1st amp would be used for aub and the 2nd for front and rear.
Alert - Fake JBL products (Amps, Speakers, Subs...) Sam Kapasi In-Car Entertainment 44 18th January 2012 12:24
ICE budget for 25k, with no amps/subs? funnyguru In-Car Entertainment 1 17th November 2009 22:02
'ICE'ing on my Palio. questions about amps, subs etc wannabe loser In-Car Entertainment 49 12th February 2009 13:18
Best combination of amps for 3 subs? somubj In-Car Entertainment 21 13th November 2008 20:09
pioneer subs, monster cap and alpine amps for sale BikerSG Shifting gears 8 4th October 2006 16:03
