Old 18th April 2012, 13:55   #16
sandeepmohan's Avatar
Thanked: 1,900 Times
Default Re: Eargasm from pure SQ - The TJet's ICE Story
Originally Posted by nishantgandhi View Post
AFAIK, you would hear the turbo whistle only when it spools up i.e. at 1700 RPM and beyond.
This I have heard but it is feeble. You can't hear it with the air conditioning going at full blast. There are times I turn of the air conditioner just to hear it.
They will check whether the alternator is properly charging the battery and supplying adequate power to the electricals.
Okay. Now I know what to tell them when I go there.
If it accepts high-level inputs, you can directly connect it to the HU and you wont need a Hi-Lo converter
It is a Blaupunkt VA475 and it does accept high level inputs. I just need to find the amplifier end connectors that are proprietary connectors. Supposed to have come in the box but I have surely misplaced them. Attached an image of the amplifier. Image from google.
If you don't re-route the HU wiring, it will stay on thereby keeping the amp also on always.
Which will be the case if I try to integrate the amplifier with my stock head unit. The amplifier will always be ON. Is there any harm as the Blue & Me announcements won't be heard otherwise?
sandeepmohan is offline   Reply With Quote
Old 18th April 2012, 14:00   #17
nishantgandhi's Avatar
Thanked: 151 Times
^ The only harm is that your battery will be drained in no time. I suggest you go to Anwar/Thoufeeq/Satya (check TBHP BLR directory for their locations) and discuss with them. I'm sure you can connect an amp with Line Output Converters and also have the remote turn on feature.
nishantgandhi is offline   Reply With Quote
Old 18th April 2012, 14:26   #18
Is it not all systems off when you turn off the key? Oh wait, think I understood. With no remote trigger and the amplifier directly wired to the battery, which is how it is done, it will drain even if the key is removed. Like you mentioned, if the power line for the amplifier is linked to some auxillary fuse from the car's internal fuse box, then it would be all systems off when the key is removed. There is a spare open terminal in the fuse box that is the same size as another terminal that has a red wire lead travelling out, I think it is for the air conditioning blower motor unit.Eargasm from pure SQ - The TJet's ICE Story-lineafusebox.jpg
Will do that. I am sure they have more experience with cars that are a pain to work on. I could do the install and uninstall of the stereo in my Ford Ikon cause I knew the wiring pattern. I am totally clueless on how it is on the Linea.
Old 20th April 2012, 08:16   #19
Thanked: 151 Times
So I got time to visit my installer for the 2 pending jobs:
1. Correcting the alternator whine : The funny thing is that noise comes on as soon as the HU is switched on. So even if the engine is not running but HU is on, there is whine. That made me think this is possibly not alternator whine.
We tried every possible trick i.e. tried running new RCA cables, Re-connected the ground wire by scraping off paint under the terminal, checked the HU (for any possible fuse/circuitry issues) and also re-checked the running of the power and RCA cables (they are running on either side of the car, as expected). Nothing seems to correct the whine.
In the end it seems that channels 3 & 4 of my Blaupunkt amp are gone. When we disconnect these and play the system, the whine almost goes away. But as soon as we connect them, whine gets back. In fact, we tried changing the speaker and RCA connections so that the whine gets 'shifted' to the rear coaxials for the time being till I can get my amp repaired.
But the moment rear channels are connected, whine gets into all 4 speakers. Frankly, I was baffled as I've never seen this happening before. But then, if everything points to the amp, I guess I have to get that checked up now.
2. The Connects2 kit did not work. I have got confirmation from fellow members that the black box (code : STK 277) they supply with CTSFA004 is the wrong one and infact that is designed for Skoda.
So the correct box code for Fiat is STK 272. If any of you are ordering from Dynamic Sounds, make sure you mention this. Else, get the Connects2 from the India dealer (Kumar's Auto, BLR) for 5k.
BTW, are there any other steering interface models known? I bumped across Autoleads and someone mentioned 'THK' or 'THB' or something. Any info?
Old 20th April 2012, 10:49   #20
navin's Avatar
Thanked: 4,286 Times
Are you saying that which ever channel of the amp is connected to the rear speakers is the one that causes the whine?
Connect Ch 1-2 to front speakers, Ch 3-4 to rear speakers. Plug in one RCA at a time. When does the whine start?
Connect Ch 1-2 to rear speakers, Ch 3-4 to front speakers. Plug in one RCA at a time. When does the whine start?
Old 20th April 2012, 11:12   #21
Thanked: 151 Times
We did that too (swapping the front-to-rear). If the rear channels are disconnected, whine goes away. But as soon as they are connected, whine gets
back in the entire chain. In the end, it was a trade off between driving with rear speakers disconnected, or, having all speakers on along with whine. That is till I get the amp repaired. I chose to go with the latter option.
Old 20th April 2012, 12:37   #22
navin's Avatar
Sir maybe I was not clear.
By rear channels do you mean channels 3-4 or the rear speakers.
Old 20th April 2012, 12:49   #23
Thanked: 151 Times
A problem of semantics from my end too!
I meant Channel 3-4.
Old 20th April 2012, 13:21   #24
navin's Avatar
have you tried a different 4 ch. amp?
Old 21st April 2012, 02:08   #25
sonirohit's Avatar
Post deleted by the Team-BHP Support : Please do NOT post one-liners that add little or no informational value to the thread. We need your co-operation to maintain the overall quality of this forum.
Please read our rules before proceeding any further.
sonirohit is offline   Reply With Quote Received Infraction
Old 22nd August 2012, 15:17   #26
Thanked: 151 Times
Update
I sent back the STK 277 adapter to Dynamic Sounds and they had agreed to a replacement. I had asked for STK 272 adapter, as I was told by Amit that its the one that works. However Dynamic Sounds has come back over email and they say there is no STK 272 coded adapter (?!?!) This is quite strange to hear from them.
I tried to contact Kumars Auto (the dealers for Connects2 in India) but they are least cooperative I've seen. Can users of Connects2 CTSFA0004 in Fiat let me know the part number of their adapter/black box?
Old 15th January 2013, 10:25   #27
Thanked: 151 Times
Does anyone on this forum use Connects2? Can someone help me with the model number printed on the black box? Mine was STK 277 which is not picking up signal at all.
I was told by Amit that STK 272 is the working one in his car (though he couldn't check for sure) but Dynamic Sounds says there is no such model with them! Strange!
If anyone who has purchased Connects from the Indian dealer ie Kumars or Poona Motors, can you please post a pic?
abhipuru1.6'S ICE- Ford Fiesta 1.6S- First Steps towards THE WORLD OF PURE MUSIC abhipuru16 In-Car Entertainment 59 17th September 2012 13:58
ICE for Pure Music Whaateva In-Car Entertainment 7 2nd March 2011 19:13
Mercedes W124 - Pure SQ ICE (W.I.P) gunbir In-Car Entertainment 78 12th October 2007 09:28
Haaaaaaalp - ICE for Scorpio - pure Audio SQ setup prabhuav In-Car Entertainment 5 11th October 2007 11:11
