Old 14th April 2012, 21:20   #1
iron.head's Avatar
Thanked: 117 Times
Default Head Units Pre-outs Pre-out voltages
My search for a new head unit began few days ago and things got a bit muddled up when I got confused between specifications of different head units. I wanted to buy a HU which would have all the options so that I could add an amp, etc later.
Found a nice website where different concepts related to audio have been explained-
http://www.bcae1.com/ Check the scrollable list on the right side.
The cheapest head unit which has 3 pre-outs of 4V each costs around 6k. It has a Low Pass Filter as well as a High Pass Filter.
Car Head Units
Kenwood also has few head units which have 3 pre-outs-
KIV-700 | 1DIN Receivers | Car Electroics | Kenwood
KDC-X8016BT | 1DIN Receivers | Car Electroics | Kenwood
The above two have 4V pre-outs while the ones below have 2.5V 3 pre-outs-
KDC-U7046BT | 1DIN Receivers | Car Electroics | Kenwood (HPF&LPF)
KDC-U6046 | 1DIN Receivers | Car Electroics | Kenwood
KDC-U4549SD | 1DIN Receivers | Car Electroics | Kenwood (HPF&LPF)
KDC-U6046 and KDC-U4549SD look like they are the least expensive ones out of the Kenwood lineup with 3 pre-outs but they have 2.5V pre-outs.
JVC India website also displays few HU's which have 3 pre-outs-
The two below have 5V pre-outs while KD-R626 has 2.5V pre-outs.
1-DIN CD Receiver KD-R926BT | CD Receiver | Car Audio | JVC India (HPF&LPF)
1-DIN CD Receiver KD-R826BT | CD Receiver | Car Audio | JVC India (HPF&LPF)
1-DIN CD Receiver KD-R626 | CD Receiver | Car Audio | JVC India (HPF&LPF)
JVC KD-R626 should be the least expensive option out of all JVC HU's with 3 pre-outs.
Will add another post after I find out the prices of all these head units and High Pass Filter/Low Pass Filter Specification.
iron.head is offline   (2) Thanks Reply With Quote
Old 16th May 2012, 00:35   #2
iron.head's Avatar
Thanked: 117 Times
Default Re: Head Units Pre-outs Pre-out voltages
Got Kenwood KDC-U4549SD and JBL GTO 949 for Rs 9700 with bill and warranty today. JVC KD-R626 was also priced in the same range but I was more towards a Kenwood HU so got it.
iron.head is offline   Reply With Quote
Old 16th May 2012, 07:20   #3
Thanked: 670 Times
most of the current generation amps have very high input impedance, hence it does not really matter if you have 2V or 4V pre outs. After all, you do have a Gain setting on the amp (which is actually a volume control) to compensate for the input voltage.
Most amps accept anything from 0.5V upto 5V. The preout voltage is just another marketing gimmick!
nitinbose is offline   (1) Thanks Reply With Quote
Old 16th May 2012, 10:29   #4
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by nitinbose View Post
most of the current generation amps have very high input impedance, hence it does not really matter if you have 2V or 4V pre outs. ... The preout voltage is just another marketing gimmick!
All amps have always had very high input impedance. How did you relate amp input impedance to the HU output voltage?
In some cases, especially SPL systems, the HU output voltage does matter. Of course, what you have said is true for most systems run at normal listening levels - the gain control in the amp enables one to set the amp output to desired levels even if the HU pre-out voltage is 2V.
Marketing gimmick it may not be, it is just another item of data about the HU. The higher numbers are good for whoever looks for largest numbers in comparisons.
DerAlte is offline   (1) Thanks Reply With Quote
Old 31st January 2016, 22:30   #5
thepilot's Avatar
Thanked: 9 Times
sorry for bumping this old thread, but I cant seem to find any good SQ oriented HU's in sub 10k price with 3 preouts. Bluetooth feature if available will be preferred.
Some of the models mentioned here by the OP don't seem to have 3 pre-outs.
Any help would be appreciated.
thepilot is offline   Reply With Quote
Old 22nd February 2016, 17:51   #6
greenhorn's Avatar
Thanked: 1,516 Times
JVC KDR80BT for 11.75K on snapdeal. + stuff worth 1K
I think its is decent value. else you can wait and pray for better offers
greenhorn is offline   (1) Thanks Reply With Quote
Old 8th March 2016, 17:35   #7
thepilot's Avatar
Thanked: 9 Times
Praying for better offers.
On the other hand, I'm looking at a set of Polk DB6501 components. How good are these? Can a basic HU provide sufficient power to driver them? Or is an amplifier required?
Prices online at snapdeal and paytm are ~6.5k wheras Amazon.in shows 14k. I enquired locally but could get any quotes. What would be the correct price?
Cochin - Kodaikanal (Eat outs, Route) naveen.raju Route / Travel Queries 46 3rd October 2017 15:45
Of White-Outs and Landslides vardhan.harsh Travelogues 39 6th June 2013 03:54
The Terrain Tigers, NCR : OffRoad Day Outs ashnd 4x4 Excursions 13 3rd May 2013 16:20
City Hang outs!!!! anarchist Shifting gears 27 12th May 2011 13:32
Yoko S Drives : 1 year, 9 tyres, 2 blow outs, 4 side wall bulges kj302 Tyre & Alloy wheel Section 26 25th March 2011 01:53
