Old 19th June 2012, 12:40   #31
navin's Avatar
Thanked: 4,286 Times
Default Re: Verna SX : ICE options for ~75K
Originally Posted by maverick236 View Post
1 quick question - Which is the best place to have the sound processor setup? Any other last minute checks or tips would be greatly appreciated
Maverick,
I dont know anyone in Hyderabad so I really cant help there.
As far as tips and tricks are concerned for old guys like audio is sorta intuitive we dont have a note book so I dont know if I can list of tips and tricks. After 35+ years of decoding audio problems we old men just do it by instinctively. When it sounds good it is good.
Old 20th June 2012, 10:35   #32
maverick236's Avatar
Maverick,
Navin - When I asked you place to set it up, I meant the Audio processor in the car. Where do i get it fixed in the car? Should i get it fixed under the seat or near the kick panel or boot. what would be the ideal location?
maverick236 is offline   Reply With Quote
Old 20th June 2012, 16:19   #33
navin's Avatar
In the boot. Next to the amps. The idea is to keep the length of the RCA cables to an aboslute minimum.
navin is offline   (1) Thanks Reply With Quote
Old 25th June 2012, 17:10   #34
The 1st phase of installation started yesterday.
Done with all the basics - Amp, Comps, Wiring, Coax, Sub etc..
Unable to configure the Alpine pxa h800. It was not detecting. :(
The tech from Alpine is expected in a couple of days to help me out. Anything that we might be missing?
Sounds decent with the Focals Solid 4 and 165VB..
Currently have the Focal 12" Sub (SP30) but i feel its bass is not as tight as it was with my JBL CS1204 B... Could be the setting or is it the sub?
If its the sub, can I try something for a tigthter bass without having to use the Monoblock ....
Suggestion needed
Old 25th June 2012, 18:44   #35
DerAlte's Avatar
Thanked: 2,879 Times
... Alpine pxa h800. It was not detecting ...
What was it not detecting?
... Focal 12" Sub (SP30) but i feel its bass is not as tight as it was with my JBL CS1204 B... Could be the setting or is it the sub? ...
Could be the box! Just as a test, stuff a small pillow or cushion in the box. If the bass feels tighter, the box is perhaps too big. I am assuming a sealed box.
Old 26th June 2012, 09:13   #36
There was no sound output thou connections were given as per instructions & also the setup through laptop to configure was failing.
It is not a sealed box. Its ported.
Focal SB P 30, car audio hifi subwoofers to customize your car sound system.
I understand that ported enclosures are not as tight as sealed ones but could not go for a powerful sub as it is not being powered by a monoblock but anything which is close to my prev sealed sub JBL CS1204 is also good.
The other Question that I have is - Could it be the separation between the boot and passenger cabin killing that tight punch?
Old 26th June 2012, 09:49   #37
navin's Avatar
If its the sub, can I try something for a tigthter bass without having to use the Monoblock ....:
Reset the Alpine.
Stuff a old cotton sock in the port of the subwoofer box.
Old 26th June 2012, 10:48   #38
DerAlte's Avatar
... Could it be the separation between the boot and passenger cabin killing that tight punch?
No, that will only reduce the intensity slightly (gain would have been set appropriately), but not change the basic boomy nature. As Navin said, try stuffing some old socks, rolled tightly, into the port.
DerAlte is offline   (1) Thanks Reply With Quote
Old 26th June 2012, 10:58   #39
Reset the Alpine.
Tried resetting the Alpine. No luck.
Regarding the cotton sock, I'll try and see if it works.
Also reg the sub, the dealer gave me an option to change the sub if not satisfied. kindly let me know if any other sub could also be recommended.
1 more question Navin Sir - Since I am using only the 4 ch amp that feeds the front comps and the sub and the dsp talks only to the amp, the rears are being fed by the HU. I just want to get rid of them but I would love to have a fill atleast. Anything suggestions on this please.
Old 26th June 2012, 15:28   #40
navin's Avatar
If you want rear fills to be sent from the Alpine you will need an amplifier for the rear speakers. The other choice would be to get a monoblock for the sub and use the 4 ch. for front and rear.
Try the Morel for subwoofer.
WIthout seeing the Alpine there is little we can fo from here. These gadgets are very complicated. It ixs best to let the Apline guys fic it.
Old 26th June 2012, 22:02   #41
The sock thing worked to an extent. Feels a bit tighter now.
Old 10th July 2012, 17:09   #42
I observed a strange thing. Whenever I accelarate, there is a swishh sound that is proportional to the rev. Not heard when played with a high volume. However, it is quite irritating at low volumes. Tried checking with the installer, he suggested me to use some noise cancelling device and it happens for some of the mpfi engines.
Is is true? never heard of it before.
Any inputs on these please
Old 10th July 2012, 19:40   #43
DerAlte's Avatar
... Whenever I accelarate, there is a swishh sound that is proportional to the rev. ...
Do you mean to say when you are driving steady (neither accelerating nor decelerating) the 'swishh' is not present?
First suspects: grounding of amp, and RCA cables not good enough.
Old 11th July 2012, 18:21   #44
If I have my foot on the accelarator irrespective of the whether its steady speed or acceleration, there is definitely that sound.
I am using Streetwires for the wiring... Arent they good enough ?
Old 11th July 2012, 18:45   #45
DerAlte's Avatar
... I am using Streetwires for the wiring... Arent they good enough ? ...
Don't go by brand name. That is no guarantee, considering most of them are just stamped brands with no R&D investment or quality improvement program in place.
1. Ask your installer to redo the amp grounding, this time with 2 copper washers and scraping the grounding point
2. Just check and see if a different pair of RCA cables works better. And while you are at it, check if there is any 12V cable running beside the RCA cables
Fun-to-Ride Motorcycle for 75K! driverace Motorbikes 126 14th October 2013 20:21
Old Verna vs Fluidic Verna : A Comparison amitwadhwa Test-Drives & Initial Ownership Reports 13 10th July 2012 21:30
Baleno 75K done and still going strong !! madhukar_n Long-Term Ownership Reviews 47 1st November 2010 11:48
New Verna Sooner than you Expect: Launched as Verna Transform drchernish The Indian Car Scene 181 22nd July 2010 09:34
ICEing an Innova: Budget 75k frankmehta In-Car Entertainment 21 8th June 2009 13:41
