Old 12th February 2008, 18:16   #31
Thanked: 294 Times
Originally Posted by JPL View Post
I think he has already asked it
I meant the thread has no relation to his question
Old 13th February 2008, 01:56   #32
rider60's Avatar
Thanked: 47 Times
ok agreed lbm ji this may be OT, but still can please tell me what i have achieved with setup and would this make it a VFM sql or spl or sq or none but only a decent setup?
rider60 is offline   Reply With Quote
Old 13th February 2008, 09:23   #33
rocksterraghu's Avatar
Thanked: 65 Times
I wouldn't be asking LBM as to how he would rate my system. His definition of SQL is a little different, you know.
Old 13th February 2008, 11:32   #34
Thanked: 294 Times
Major of sq and a little bit of sql for spl you would need two of these subs.
Hmmm
Old 28th October 2008, 12:09   #35
Thanked: 16 Times
One of the best (vfm) SPL systems in the country right now: Sam_786's system.
Config:
JVC dual din dvd HU
Rainbow Slx 6.5" components
2 Pioneer 510 monoblock amps
2 IDv3 12" subwoofers in a partitioned ported box
The setup has achieved an insane 151.2db in SPL test. The best part of this setup is that it's not just designed for SPL but with the bass turned down, the setup can be enjoyed to listen some good music for very long periods.
A proper thumbs up setup! :
Old 28th October 2008, 21:11   #36
Originally Posted by low_bass_makker View Post
I forgot ask earlier 32000 watts rms at what ohms ?
if, P=(V^2)/R
R=(V^2)/P
= (18*18)/32000
= .010125 ohms
How many voice coils are in parallel?
Is this for ICE? I can think of wheels and engine mounted in Speaker Box. OR some energy is ulilized for heating elements
omishra is offline   Reply With Quote
Old 28th October 2008, 23:01   #37
sam_786's Avatar
Thanked: 23 Times
I am very much thank full to BBW Distributors. Without there support i could not get a good VFM system which is a SQ+SPL combo and also i have not imagined the my system can sound upto torturous 151.2 DB
Hats off to Gunnu Paaji and J.B. cheers:
sam_786 is offline   Reply With Quote
Old 29th October 2008, 00:34   #38
Thanked: 294 Times
Originally Posted by omishra View Post
if, P=(V^2)/R
R=(V^2)/P
= (18*18)/32000
= .010125 ohms
I think you are calculating a bit wrong here. It should be 32 ohms at 32000 rms if each amp is 1 ohms stable. If the amp is .5 ohms stable it will be at 16 ohms.
So it will be VC wired in series than parallel.
It should be like this...
V= (rms watts x ohms) sqrt
Since the power supply of the amp is 18volts. But in the formula you posted the voltage output at amp end should be put.
Good SPL Sound Jas6789 In-Car Entertainment 34 30th May 2011 22:15
Need a good audio speaker system (SPL+SQ) for home Nos007 Gadgets, Computers & Software 31 13th February 2008 15:52
goin by the xmax is it possible to identify tonal quality,sq,sql spl of the subwoofer zucchero In-Car Entertainment 41 17th August 2007 17:51
Pioneer SPL subwoofer for sale low_bass_makker Shifting gears 15 27th December 2006 20:07
