Old 11th April 2006, 11:04   #16
Autophile's Avatar
Alpine Type R's need good amount of power. I would recommend two Type R's running on 1005 instead of 605 with a final impedance of 4 ohms.
Autophile is offline   Reply With Quote
Old 11th April 2006, 11:32   #17
navin's Avatar
Thanked: 4,286 Times
JB, I think he is getting only 1 type R.
Old 13th April 2006, 04:29   #18
panky12345's Avatar
Thanked: 150 Times
gyz.....never wanted to start a new thread....which one.....Pioneer Mono or Alpine Mono? (Only SPL needed)
Old 13th April 2006, 11:03   #19
navin's Avatar
Originally Posted by panky12345
BTW, am not buying.....
Now I am confused. Pio Mono costs less than Alpine mono and there are a few other factors (which woofer, SPL required, etc...) that are involved.
Old 14th April 2006, 02:35   #20
panky12345's Avatar
Thanked: 150 Times
navin boss,
budget : flexible (upto 12-15K)
woofers: pair of pioneer 306C
basic requirement : lot of Boom
Box used : ported; seperate for each woofer.
Old 14th April 2006, 18:57   #21
navin's Avatar
15K of amps for 6K of woofers? Odd match. Anyway the Pio 944 can swing a lot of volts and sells for less than 15K. I dont know if the Pio 510 is 2 ohm stable but that can also be an option.
Old 14th April 2006, 23:05   #22
Thanked: 294 Times
yes if u a SVC then 510 will be a good option to go for but for future expansion and use go for 944 it is also a good option. If only subs then 510 is the best for u and it is 2ohms stable
Old 15th April 2006, 00:50   #23
panky12345's Avatar
Thanked: 150 Times
wat if i run these pair with ALPINE MRD-M605? will they sound good than i if i were to run them with Pioneer 510.
Old 15th April 2006, 09:00   #24
navin's Avatar
look at the specs see which one can dump more current with large drivers (Mms > 100gms) this is eesential.
Old 15th April 2006, 23:59   #25
panky12345's Avatar
Thanked: 150 Times
navin boss, he he....
another one for you plz.....i cdnt find Mms
Alpine MRD-M605
  • • CEA-2006 Power Rating (4Ohm@14.4V = 1%THD+N), S/N 65dBA (Ref. 1W into 4Ohm): 400W x 1
RMS Power (at 14.4V,20Hz-200Hz)
  • • Per channel into 4 ohms : 400W x 1
  • • Per channel into 2 ohms : 600W x 1
MMs is for the woofer not the amp. as far as the amps go, the rest of the alpine specs are not required and the Pio specs are not readble (i have PMed you the not readable specs so you can refine them). Thanks Navin
Old 18th April 2006, 02:14   #26
panky12345's Avatar
Thanked: 150 Times
sir, i think we had a choice between the amps and not woofers.
Old 18th April 2006, 09:45   #27
navin's Avatar
I know that panky! please post readable specs on both amps ok?
Old 18th April 2006, 11:49   #28
Thanked: 294 Times
mrd-605 spec
Pioneer d510
Maximum power output
600 W × 1 (4 Ω) / 1,000 W × 1 (2 Ω)
Continuous power output
300 W × 1 (at 14.4 V, 4 Ω,, 0.4% THD)
500 W × 1 (at 14.4 V, 2 Ω, 0.8% THD)
It means that alpine is a little more power than pioneer. And alpine has got a good digital display on it for all the settings. I would prefer mrd 605 if compared with pioneer.
Old 18th April 2006, 11:58   #29
Thanked: 13 Times
Originally Posted by freakrz
The sub weighs like 7 kilos..i guess..and i am also getting some components and some momo accessories..
Slightly offtopic...but what airport will you be flying into? Im just curious about how people bringing in ICE/accessories deal with fussy customs officers at times...maybe I will start a separate thread
I think there is a thread on this topic. Please seach.
Old 18th April 2006, 13:06   #30
navin's Avatar
Originally Posted by low_bass_makker
mrd-605 spec
Pioneer d510
600 W 1 (4 Ω) / 1,000 W 1 (2 Ω)
300 W 1 (at 14.4 V, 4 Ω,, 0.4% THD)
500 W 1 (at 14.4 V, 2 Ω, 0.8% THD)
at 14.4V, about 1% distortion
4 ohms
Alpine 605 = 400W = 40A
Pio D510 = 300W = 34A
2 ohms
Alpine 605 = 600W = 34A
Pio D510 = 500W = 31A
this means Alpine 605 > Pio D510, BTW is the 605 the smae price as the 510?
Pathetic EcoSport delivery (Shreeji Ford): Low coolant levels, charging over MRP etc. ACM Indian Car Dealerships 30 30th September 2014 15:17
A Complete List of Accessories for your Skoda's Including their MRP Sunilrj Modifications & Accessories 11 18th January 2013 02:14
14% VAT on MRP for spare parts in KA? black12rr The Indian Car Scene 7 22nd July 2012 08:04
FS : Alpine MRP F240, 4 Channel Amplifier (used) s0uljah Shifting gears 1 4th February 2007 00:12
Recommended Sub For Alpine MDR-M -1001 2000 Watt Monoblock Tool In-Car Entertainment 45 6th June 2006 02:11
