Old 4th June 2012, 21:03   #1
triedeverything's Avatar
Thanked: 165 Times
Default DIY - Lock down the Woofer from moving around in the Scorpio
The Issue:
The Woofer in an 8 seater sits pretty snuggly when the third row is in place. But when it is folded, the box tugs at the wires every time you brake or go up or down a slope. I was fed up with all the unwanted bass that the speaker was making by hitting the walls and everything else around.
I thought of a really low tech solution to fix this problem. I'm not sure if it works on other cars, but this works just fine for the 8 seater Scropio.
The Solution:
You need 2 - 3 meters of Velcro and this costs about 25 Rs per meter. You usually get this at hardware shops. But if you are particular about black colored velcro, try shops that sell tailoring stuff. We need the hard part of the velcro and not the soft fibrous part. Most speakers have a fibre finish that can naturally act like the soft part of the velcro. I got this idea from Red Liner who has dome something like this for smaller speakers. But he stuck the hard part on to the base of his speakers and used the fibrous parts of his car to interlock with the velcro at the base of the speakers. I did something a little different. Here is how you do it.
1. Measure the base of the speaker and cut the velcro band to the same lengths.
2. Now that you have similar length bands, Stitch or staple these together to form a large patch. I did both.
3. Check the position at which you want the speaker to be placed and then loosen the plate you see as soon as you open the rear door. (Not sure what it is called, check the pictures.)
4. Don't remove the plate completely, you may not be able to assemble it back. We just need a small gap to insert one end of the velcro under the plate.
5. Make two holes on the Velcro patch so that it corresponds to the pitch of the screws holding the plate.
6. Now insert the velcro patch in the gap and screw the plate back on and place the speaker on top.
Result:
Rock solid Woofer that does not budge even if you can drive your car upside down..
Here is the picture of the patch that was stapled AND stitched together
After inserting and screwing back the plate
DIY - Lock down the Woofer from moving around in the Scorpio-patch-installed.jpg
Another view of the velcro being held in place by the plate.
DIY - Lock down the Woofer from moving around in the Scorpio-patch-another-view.jpg
Top view after speaker was placed on top of the velcro patch
Side view of our new sticky woofer.
DIY - Lock down the Woofer from moving around in the Scorpio-final-picture.jpg
triedeverything is offline   (3) Thanks Reply With Quote
Old 5th June 2012, 00:35   #2
blackfire_9's Avatar
Thanked: 187 Times
Default Re: DIY - Lock down the Woofer from moving around in the Scorpio
I saw the thread title on the Forum home page & thought I would suggest the Velcros. But you have already done that & it will hold good enough.
Good luck mate
blackfire_9 is offline   (1) Thanks Reply With Quote
Old 5th June 2012, 02:55   #3
ghpk's Avatar
Thanked: 193 Times
Nice work,
I was planning to do the same but didn't had time to buy Velcro and put some DIY brains to subwoofer.
May be will do this in a few weeks as currently i've other things to take care of.
ghpk is offline   (1) Thanks Reply With Quote
Old 5th June 2012, 10:44   #4
shuvc's Avatar
Thanked: 287 Times
Like @blackfire, I too opened the thread to suggest velcro
Btw, is the sub covering one of the rear speakers?
shuvc is offline   (1) Thanks Reply With Quote
Old 5th June 2012, 12:15   #5
Thanked: 49 Times
Neat solution.
I would still tie it down with something more robust to prevent it from coming loose and hitting someone inside the scorpio in the unfortunate case of a crash.
CrackedHead is offline   (1) Thanks Reply With Quote
Old 5th June 2012, 21:59   #6
Thanked: 165 Times
The rear speakers aren't connected. I've installed ovals on the sides on the last row.
Originally Posted by CrackedHead View Post
Neat solution.
At high speeds, mostly on the highway, there's usually a lot of other stuff in the back that are used to tightly pack everything in place.. including the speaker.
What did you have in mind when you say 'tie it down'?
triedeverything is offline   Reply With Quote
Moving to Gurgaon - Advise on moving my car nurni76 Shifting gears 22 2nd October 2016 17:36
Diesel Cars: Down, down, down! Market share = 34% S2!!! The Indian Car Scene 66 2nd June 2016 16:21
Which Steering lock and Gear lock to buy? willy Modifications & Accessories 73 3rd September 2015 12:17
Security : Gear lock, steering lock venkatrx Modifications & Accessories 11 25th January 2011 18:04
Superbike Security Systems - Disc Lock / Chain Lock / Alarm Systems gsferrari Superbikes & Imports 3 3rd July 2009 01:45
