Old 10th April 2006, 20:57   #1
abhibh's Avatar
Thanked: 34 Times
Exclamation Help Help Urgent Help!!!
One of my friend has a Sub woofer, 4 CH Amp and 4 Speakers (2 front 2 rear) and 2 Tweeters (rear) installed in his car. Yesterday we were just checking the system out and noticed that when the voice balance is turned to right the subwoofer and right speaker both of them works. Where as when he turn the balance to left the speakers get turned off and only woofer works.
We went to the dealer and tried to rectify the problembut he says its like this only and is trying ot ignore it.
Now what i want to know is the dealer saying true. I mean this is first time i am hearing this. Though i have also never tried this ever so i dont know.
So plz RELP!! I mean Help!!
Old 10th April 2006, 22:49   #2
navin's Avatar
Thanked: 4,282 Times
Originally Posted by abhibh
the dealer has connected the amp and speakers poorly. you dont say if both right speakers work or only the front.
Which HU are you using? how many pairs of RCA out does it have?
Old 10th April 2006, 22:55   #3
jkdas's Avatar
Thanked: 1,436 Times
As Navin pointed out; he had his speakers and sub connected to one channel!
please answer navisn queries + these
1. HOws his speakers fed?
2. how is his sub fed?
3. His sub is being fed with high Frq too!
Can you post pic of teh amp connections?
Old 10th April 2006, 22:58   #4
navin's Avatar
JK, the initial post is very confusing. from that post it seems to me that the left speakers never work.
Old 10th April 2006, 23:04   #5
abhibh's Avatar
Thanked: 34 Times
Front works all fine. Even rear tweeter works all fine. everything balance works fine except for the rear speakers. If balance is 0 then both the speakers work. If balance is right the right speaker and sub works. and if the balance is on left then only sub works.
HU is JVC. I will post some pics tom. with all the connections and stuff as we are going to boston acoustics. Though i will tell him to wait maybe you ppl are able to help.
Old 10th April 2006, 23:12   #6
navin's Avatar
this is confusing. i would remove all the wires and start fron scratch.
1. connect HU front to ch 1-2 of amp
2. bridge ch 3-4 of amp
3. connect HU sub out to ch 3-4 of amp
4. connect HU speaker out to rear speakers and tweeter (in parallel) but add a small 10W 4ohm resistor in series with the tweeter.
5. connect ch 1 or amp to right front and ch 2 to left front
6. connect ch 3-4 now mono to subwoofer
Old 10th April 2006, 23:14   #7
Could some left to right or right to left connection somewhere be causing this problem?
Vivekphadnis is offline   Reply With Quote
Old 10th April 2006, 23:18   #8
navin's Avatar
I think the dealer has connected all 4 speakers to the right channel and the sb to the left using the balance as a fader but then why does the sub work when the balance is on the right?
Old 10th April 2006, 23:24   #9
abhibh's Avatar
Thanked: 34 Times
Hi naveen,
This may not confuse you.
1.) HU is connected directly to Front speakers. SO no amp role here. So point no. 5 in yer post is out.
2.) connect HU speaker out to rear speakers and tweeter (in parallel) but add a small 10W 4ohm resistor in series with the tweeter. This has been done so this is also of no use.
Also any one have a pics of amp where one can tell me which channel is which .
Old 11th April 2006, 00:00   #10
navin's Avatar
ok this is getting confusing. It is best that you post the entire circuit.
if the HU is driving the front then i asume the amp is driving the rear and tweeters and the sub.
Obviously the wiring is messed up. So why not remove all the wiring and start over logically. connect one pair of speakers at a time.
Old 11th April 2006, 00:08   #11
Thanked: 21 Times
Dude... It seems you are in Delhi... if so, who is the dealer who installed your system. Like Navin and others, I suggest you take it apart and start from scratch.
Old 11th April 2006, 00:30   #12
abhibh's Avatar
Thanked: 34 Times
Ya, i think we have to do it all over from scratch. Have found a tutorial http://www.crutchfieldadvisor.com/S-...ps.html?page=2. tell me is it good enough for setting up ?
Old 11th April 2006, 12:15   #13
Sam Kapasi's Avatar
Thanked: 1,473 Times
Hey abhibh,
you need a new installer.
Urgent help needed. please help-Santro Xing not starting iron.head Technical Stuff 3 12th May 2012 08:27
Pls help me Urgent: Help me to connect ipod classic to amplifier vasudeva Gadgets, Computers & Software 2 5th October 2009 17:14
urgent help required with spyware aadix Shifting gears 34 21st March 2007 20:38
Fast decision your help needed urgent Montoya Sedans 72 17th May 2005 01:36
