Old 27th April 2006, 00:41   #31
kb100's Avatar
Some fruits of my Research!!
For RCA, could you not use Belden # 1694A (approx 120bucks/mtr), and for the RCA plug, could one use Switchcraft Gold Tip, (approx 200 bucks)
Gurus??...
kb100 is offline   Reply With Quote
Old 27th April 2006, 07:18   #32
jkdas's Avatar
Thanked: 1,436 Times
Gurus??...
that is ...120*6 +200*2 for a 6mtr setup
and 120*1 + 200*2...costly na?
Old 27th April 2006, 11:59   #33
kb100's Avatar
Yuip... so the 6 mtr should cost you 920.... or with Sam's help a litlle lesser!! (he mentioned special prices on Bledens for T-bhpians) ..
My question is .. will this be better - in quality - than the readymades...
Old 27th April 2006, 13:14   #34
navin's Avatar
Thanked: 4,282 Times
Belden is better than most cable in it's price range. there are better cables ofcourse but Belden can embarrass many reputed brands.
Old 27th April 2006, 13:30   #35
jkdas's Avatar
Should be better then as Navin said.Also its soldered etc properly for better performance right?
Old 27th April 2006, 13:50   #36
Sam Kapasi's Avatar
Thanked: 1,473 Times
A cable with suprisingly good performance in the car is Monsters XLN series. Very very good. I use it in my own car.
Old 27th April 2006, 19:43   #37
navin's Avatar
Monster XLN i think run more than Belden do they?
Old 27th April 2006, 21:26   #38
kb100's Avatar
SAm
... Where do you get them..and how much did it cost you???
Old 28th April 2006, 11:28   #39
Sam Kapasi's Avatar
Navin, yes they are more expensive. But we never imported any Belden Line level cables in India, only speaker cables.
KB100, I never pay. Heh heh. But I do know that Monster XLN is sold in India, at all dealers that sell Monster Car Audio Cables. If you need help locating a dealer, lemme know, i can sort of tweak gonads from here.
Old 29th April 2006, 03:26   #40
Bass&Trouble's Avatar
Thanked: 71 Times
Tweakin gonads...ouch!!! And Sam thinks I'm evil (Ouch again!!!)
Btw, Monster is distributed by Digimax India to the best of my knowledge. I don't know who distributes it in Bangalore but you can contact Zareer from Digimax at 0-98200-89786. I'm sure..in this case also, you can tell him that you have a reccomendation letter from Sam, and that you should get you a fair discount.
Old 16th May 2006, 10:26   #41
Thanked: 294 Times
Yesterday I was surfing the net and I found out this topic on rca wires. Please can we see about it is it right or wrong. Even the page is named as interconnects myths....
http://www.teamrocs.com/technical/pa...nect_myths.htm
Old 16th May 2006, 11:46   #42
navin's Avatar
hey i agree with most of that still a good conductor can make a difference and i have done double blind tests. In fact I did not even know that the cables had been changed and I could detect what sounded "right". My sister's hubby who conducted this experiment (by accident) was surprised with the results too.
a) skin effect occours at freq we dont consider to be part of the audio spectrum but many hf transducers also have response that extends into the same releam and we can surely hear these differences. I suspect there is more to the audible effects of skin effect than we can measure using current measuring techniques.
b) gold it not the best conductor at 25 deg C. silver is. gold is the best material to use if you want to plate something so that it does not corrode. in fact silver oxide is almost as good a conductoer as pure silver so even if it does corrode you wont notice
c) I never believed in Multipath stuff hence I have said this before Monster (the king od multipath) is over rated. still thanks to the care they put into their sleeves and marketing they do provide a easy way for those who cant find Nordost or VdH or Kimber etc... to get a decent if overrated cable.
d) capacitance see skin effect.
e) insulation. wonder why teflon is not used more!
f) as far as anti noise cable goes dont use it and if you do open one end so do you dont get a ground loop. if you dontunderstand what it means to "open one end" stick to Monster. There is nothing wrong with Monster execpt that it is a bit too expensive for what it does. Using some varites of Belden for example one can make 3 times the cable for the same money but then one has to feel inclined to learn and experiment.
Old 10th June 2006, 23:37   #43
Thanked: 294 Times
from where can I get the above stuff ???????????????
Also from where Neutrik is avaliable..........
RCA cables and Alternator whine :( nitrous In-Car Entertainment 44 24th February 2015 15:02
Speaker Wires and RCA for Home Theatre viper Gadgets, Computers & Software 51 13th July 2009 06:48
VGA to RCA S-Video TV Adapter Cable heavy_foot Gadgets, Computers & Software 15 16th March 2009 17:42
good rca and speaker wiring makanaka In-Car Entertainment 2 15th August 2008 19:22
RCA splitter for HU? gopz In-Car Entertainment 8 5th June 2007 17:41
