Old 16th June 2012, 13:22   #16
_chikku's Avatar
Thanked: 55 Times
Originally Posted by navin
THe gas struts were designed to hold only the weight of the boot hatch. The added weight of the speakers was never part of the design. As the gas struts got older their capacity was derated and hence are unable to hold the boot hatch and speakers anymore.
Yes I agree. Guy who installed the speakers told the same thing. But I went ahead as I wanted more boot space. Now the only problem is one or the other screws in the boot keep loosing out and start making noises. I have learnt to live with that now.
_chikku is online now   Reply With Quote
Old 16th June 2012, 17:11   #17
svsantosh's Avatar
Thanked: 1,444 Times
Default Re: Can Speakers damage the Boot Lock?
DEJAVU!!
check out my garage pics. 2002 Alto LX, rear speakers same position - same issue of lock getting misaligned! Lots of trial errors, dampers changed finally sold the car - no, not because of this, but moved on to a sedan. But never could find the cause of this issue! Always take a hammer and screwdriver, bang-turn-bang-turn and problem gone for few months!
svsantosh is offline   Reply With Quote
Old 19th June 2012, 09:50   #18
navin's Avatar
Thanked: 4,282 Times
Youy dont have to. If your hatch panel (where your speakers are attached) is removeable and you can access the back side of it then you can use a lock nut. This will secure your speaker for longer.
navin is offline   (1) Thanks Reply With Quote
Old 6th April 2018, 09:29   #19
Thanked: 473 Times
In my Santro, gas struts for dickey door is not functioning. The door falls back to closed position.
Can the gas struts be repaired or only be replaced?
gkveda is offline   Reply With Quote
Old 6th April 2018, 09:45   #20
roby_dk's Avatar
Thanked: 784 Times
No need to repair them they are not that expensive. Please go for replacement option.
roby_dk is offline   (2) Thanks Reply With Quote
Which Steering lock and Gear lock to buy? willy Modifications & Accessories 73 3rd September 2015 12:17
Security : Gear lock, steering lock venkatrx Modifications & Accessories 11 25th January 2011 18:04
Damage due to Hydrostatic lock Sudhir Joshi Technical Stuff 1 4th November 2010 07:53
Superbike Security Systems - Disc Lock / Chain Lock / Alarm Systems gsferrari Superbikes & Imports 3 3rd July 2009 01:45
Mounting speakers on Boot tray.. good or bad for tray?? varunghatge Modifications & Accessories 11 5th December 2008 20:07
