Old 28th December 2009, 09:05   #61
ampere's Avatar
Thanked: 9,108 Times
Originally Posted by ruchirtnt View Post
Right, yesterday i saw the FM transmitters and they are not of much help and also to add IMHO does not look good even.
I got a Aux IN of 3.5mm jack for playing Ipod music,
there is one trouble i am facing, when i connect the ipod through the Aux In cable then for some time the music is good, after that there is a noise coming from the Aux in jack connected to cars Port, could anyone tell the probable reason for this
and after a few seconds the music starts sinking.
I have never seen anything like this. Only time when this can go wrong is, if your jack breaks-up, you can get crackling sound or sound only through one speaker etc. When I bought mine, the cable was to be connected at the back. Also you are bound to buy the same cable as the one provided by the head unit brand.
Now its an open ended market, as you can choose any. Buy a moulded cable and that should solve the problem.
Old 29th December 2009, 09:20   #62
Thanked: 91 Times
no use i have already bought two cables but there is a spark sound coming from the aux in cable attached in the car, dont know what to do. its a 3.5mm jack on both sides.
do i need to check with the ford workshop regarding it.
ruchirtnt is offline   Reply With Quote
Old 29th December 2009, 11:50   #63
Thanked: 91 Times
hello friends,
can anyone guide me the way to connect my ipod to my car and have a good voice, aux in is a very good option but there is a spark sound coming which is not good.
is there any other way (except FM transmitter)
Old 29th December 2009, 19:44   #64
DerAlte's Avatar
Thanked: 2,879 Times
Change the cable with which you are connecting the iPod to the Aux-in. The cable that you have has insufficient shielding.
The only other way is to change your HU to one which has direct iPod connectivity.
Old 30th December 2009, 10:05   #65
Thanked: 91 Times
What is "insufficient shielding"
Old 30th December 2009, 10:25   #66
Awaiting Email Confirmation
Thanked: 11 Times
lots of audio cables come with some form of metal foil wrapped around them internally, heres a diagram to demonstrate this - note that most audio cables will also have a ground layer somewhere in there ie between the centre core and shielding
if this shield is not present the cable may be susceptible to EMI (electromagnetic interference) which could cause the noise that you are encountering. better cables will most of the time be shielded especially if they are coaxial type cables ie if they have a centre core and a ground
naughty001 is offline   Reply With Quote
Old 30th December 2009, 18:43   #67
DerAlte's Avatar
The shielding is normally a woven-wire shield. The metal-foil is an additional layer, which makes the cable better. The difference between a good cable and a bad one is also in the density of the woven shield - denser the better.
Old 31st December 2009, 13:53   #68
Thanked: 91 Times
This is the aux in cable which i have purchased from a music shop. i bought it for 30 rupees
Old 31st December 2009, 20:54   #69
DerAlte's Avatar
Get a better one from a good audio / electronics shop. Should cost at least 100-150.
Old 1st January 2010, 12:26   #70
Thanked: 91 Times
is there any brand coming in Aux in, i purchased this cable from a very good shop, i dont think these people have something better than this
FM Transmitter for car. the_maven In-Car Entertainment 8 23rd August 2014 22:13
ipod integration with Safari 2.2 stock ICE - Blaupunkt bahamas?? HU smsrini In-Car Entertainment 12 17th October 2011 13:14
iPod connectivity to stock ICE in Corolla H2 carbaliga In-Car Entertainment 5 26th July 2008 20:45
iriver FM transmitter and my fiesta OE HU tortoise In-Car Entertainment 15 17th July 2007 23:42
ipod ice??! FATAL3RROR In-Car Entertainment 10 12th June 2007 14:29
