Old 7th April 2013, 22:56   #61
ampere's Avatar
Thanked: 9,075 Times
Default re: ICE for the Renault Duster & Nissan Terrano
Originally Posted by rajesh_sg View Post
Thanks DerAlte. Will check with the installer. Any suggestion for the speakers & woofer.
I did not change the HU. All I did was infinity components for front and coax for the rear. That along raises the sound quality by orders of magnitude. For my requirements, the stock HU does just fine.
Old 8th April 2013, 10:01   #62
DerAlte's Avatar
Thanked: 2,879 Times
... Any suggestion for the speakers & woofer.
@ampere got Infinity Primus 5.25" components, and seems to be very happy with the response. Audition it. You can put 5.25" round coaxes in the rear doors. The sub could be an Infinity Ref or a JBL sub.
Look for a Kenwood 4-channel amp. 2 channels can drive the components in front, and the other 2 channels can drive the sub in bridged mode.
Old 8th April 2013, 11:03   #63
sumeshmani's Avatar
Thanked: 105 Times
Can Duster owners who got the new Media-Nav HU comment on the performance when it comes to music playback?
sumeshmani is offline   Reply With Quote
Old 8th April 2013, 12:13   #64
ampere's Avatar
Even I have a 6.5 inch one installed. The installer said Infinity primus did not come in 5.25. (I frankly did not know).
(My Google search also did not throw up anything in this regard).
He was suggesting something else which I did not want. So I went with 6.5 inch ones.
Old 8th April 2013, 12:24   #65
DerAlte's Avatar
Oopsie! I thought you had put 5.25". Are your install pictures up? Specifically, how did they install the mid-bass in the doorpad.
Old 8th April 2013, 22:37   #66
I already have infinity kappa 4 & 1 amplifiers. I am looking at infinity kappa 120.9 / morel ultimo sc for sub-woofer.
rajesh_sg is offline   Reply With Quote
Old 22nd May 2013, 16:49   #67
ampere's Avatar
For member @austere_sly. Here is how I have the speaker attached.
ICE upgrade : Renault Duster & Nissan Terrano-20130521_155913_242a3.jpg
The grill is fixed out side. @DA, I tried to get the stock grill to work, but could not. Because some portion comes out. But to be frank, did not give a whole hearted try as well. Will give it another shot once again.
Old 2nd June 2013, 10:17   #68
bdman's Avatar
Thanked: 71 Times
* OE slot is for 5.25". 6.5" can be fitted, though you will lose the OE look since they will mount it from outside the doorpad
Just to clarify, if I want to keep the stock look, I cannot go larger than 5.25" in the doors?
bdman is offline   Reply With Quote
Old 8th June 2013, 17:46   #69
Bass&Trouble's Avatar
Thanked: 71 Times
6.5" can be installed while retaining the original grill in the front doors of the Duster.
Bass&Trouble is offline   (1) Thanks Reply With Quote
Old 9th June 2013, 19:29   #70
bdman's Avatar
Thanked: 71 Times
Thanks Bass& Trouble. What about the rear doors? Will 6.5" speakers fit under the original grill?
Old 9th June 2013, 22:37   #71
crazydave's Avatar
Thanked: 27 Times
Really. Driven - East of Kailash said that it would require cutting and thats why they've started sourcing a small number of 5.25" comps from Focal and Rainbow for Dusters. Can you show me how 6.5" comps are installed while retaining the original grill - pics please?
crazydave is offline   Reply With Quote
Old 10th June 2013, 08:45   #72
bdman's Avatar
Thanked: 71 Times
I am also interested in this information. Can you please share?
@crazydave In case you are not aware, there is a related post that indicates that 6"speakers will fit in the Duster
http://www.team-bhp.com/forum/test-d...ml#post2960049 (Courtship with the Renault Duster RxZ)
Mod Note : Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another on the SAME THREAD!
To know how to multi-quote,
(How to MULTI-QUOTE (when replying to a thread) on Team-BHP)click here (How to MULTI-QUOTE (when replying to a thread) on Team-BHP).
We advise you to read the
Forum Rules before proceeding any further.
Old 10th June 2013, 10:12   #73
ampere's Avatar
My installer tried and said it was not possible without editing the door pads. So I just chose to let it be that way (see the picture above that I posted). I was interested only in Infinity Primus. And as per the authorised dealer, the smallest ones were 6.5. Now I don't how true or false is that; I just went with him.
Though the grill comes out, I have learned to live with. The sound quality is excellent. (Now that again is relative! All I can say is its at least five notches above OEM speaker performance)
The HU is the same. No Amp.
ampere is offline   (1) Thanks Reply With Quote
Old 10th June 2013, 12:40   #74
crazydave's Avatar
Thanked: 27 Times
Is this directed at me? I dont have much more information to share honestly. Driven said that they have 5.25" speakers from Rainbow off the shelf and that they can get Focal with a couple of days notice. He also said that they can source speakers from JBL, Infinity of the same size but it will take more time
I'm happy that the Rainbow option is available as I'm most probably going to go with that. Just need to figure out whether I should just stick with the Medianav amplification or get a separate amplifier as well (are Rainbow amps worth the price btw?)
Thanks for this link - should widen the options. Will show it to the installer!
Old 10th June 2013, 13:00   #75
bdman's Avatar
Thanked: 71 Times
@moralfibre
I am new member and each post of mine has to be approved by a mod before it becomes visible. During that time I cannot edit the post. When it becomes visible, if 30 mins have passed, I cannot edit it either. Hence the multiple posts, which you have now consolidated. I hope you understand.
Renault Duster : Wheel & Tyre Upgrade isldhn Tyre & Alloy wheel Section 92 23rd February 2018 21:18
Nissan Terrano Unveiled : To be launched in early October parrys The Indian Car Scene 227 9th October 2013 14:56
Nissan's Duster-based SUV, the Terrano: Full Pics are out! CARDEEP The Indian Car Scene 381 20th August 2013 13:31
