Old 12th July 2013, 21:54   #91
bdman's Avatar
Thanked: 47 Times
Default re: ICE for the Renault Duster & Nissan Terrano
Originally Posted by bdman View Post
This is true. I opened up the front grill (rear is pretty much the same)...
I just installed rear speakers, and the dimension of the cavity behind the speakers are even more cramped than the front . The same model 5 1/4" beefier speakers that dropped into the front required some cutting before they could be installed in the rear. Beware.
bdman is offline   Reply With Quote
Old 21st July 2013, 09:25   #92
bdman's Avatar
Thanked: 47 Times
After not being satisfied with the sound quality even after replacing my speakers -- not enough bass, mid-range lack of focus -- I decided I would try to stuff the doors with padding. What a huge difference in sound that made! Bass is much deeper and mids more clear.
Procedure is simple:
1. Procure 2 nos, 12"X12" sofa cushions with polyfill. Available at most big stores like big bazar etc. Rip cover.
2. Detach speaker grill
3. Remove speaker - you will need a Torx Screwdriver
4. Stuff as much polyfill as you can into door via the speaker hole (about 1/2 cushion)
2. Replace speaker and grill.
I highly recommend this as the first option for any one who wants to improve their sound, as it is the cheapest.
Old 21st July 2013, 09:48   #93
ampere's Avatar
Thanked: 8,759 Times
I got the doors damped both inner and outer linings along with speaker change. Now based on what you mention, it looks like it does make a difference to the sound. I got it because I just wanted a heavier door feeling, which I got too!
So improvement in bass/mid range, does show up. I thought it may happen, but was not sure about it.
Old 21st July 2013, 09:50   #94
condor's Avatar
Thanked: 4,416 Times
@Ampere, he has filled the cavities. You have damped your doors using Damping sheets.
Would be good to compare both ..
Old 21st July 2013, 11:00   #95
bdman's Avatar
Thanked: 47 Times
Depends if they have damped the front of the doors (behind the panels) or the rear (against the metal). If the former, I think you may still get some benefit of stuffing.
IMHO, the sound gets distorted because of internal reflection/resonance from the door.
Related Article
bdman is offline   (1) Thanks Reply With Quote
Old 21st July 2013, 14:56   #96
ampere's Avatar
Thats what I thought to. I got the full door inner and outer linings damped.
As condor said, I did not fill the cavities part, but got the doors damped.
Old 21st July 2013, 15:11   #97
condor's Avatar
So when you damp the sheets in the door, it alters the reflection & resonance. I have damped the doors of my Ikon (only outer sheet). I think it made a good difference - no stuffing, or damping of inner sheet.
Old 21st July 2013, 18:09   #98
DerAlte's Avatar
Thanked: 2,877 Times
... no stuffing, or damping of inner sheet.
Stuffing is anyway ruled out - where will you stuff what?
What you have done is quite right, @condor, the inner metal is broken up by large gaping holes and doesn't resonate. Some judiciously placed damping does help reduce rattling.
Old 21st July 2013, 18:14   #99
condor's Avatar
May be the foam that was mentioned a few posts back, between the two sheets of the door ? (Not that I want to do that)
Sir.ji, then why do the auto accessories shops close these holes (on the inner sheet) with damping sheets ?
Old 21st July 2013, 20:28   #100
DerAlte's Avatar
... then why do the auto accessories shops close these holes (on the inner sheet) with damping sheets ?
A very innocent assumption: closing all the holes in the inner sheet is going to make a box out of the cavity between the inner and outer layers, and give more bass!!! One has to realize that when the damping material is not stuck to a metal / FRP layer, it is *not* doing *any* damping - it is transparent to sound. And not just auto accessory shops, even many experienced installers do that. They also think it will save them time if the just plaster on a whole sheet of damping material.
It is a good practice to close the holes, though - but with the plastic sheet that was the original vapor barrier. This is to prevent moisture ingress into the cabin.
DerAlte is offline   (1) Thanks Reply With Quote
Old 22nd July 2013, 11:02   #101
bdman's Avatar
Thanked: 47 Times
A very innocent assumption: closing all the holes in the inner sheet is going to make a box out of the cavity between the inner and outer layers, and give more bass!!!....
True, but stuffing has the theoretical effect if making the enclosure seem much larger, hence even more bass!
And the stuffing can be done quite simple by removing the speaker and stuffing through the same hole that lies behind it. Unless, the damping material has closed up that hole too.
Old 22nd July 2013, 11:11   #102
DerAlte's Avatar
... the theoretical effect if making the enclosure seem much larger, hence even more bass! ...
If the enclosure is created with rigid walls *not* transparent to sound (like the enclosure of a sub), one can understand. With large holes covered with a rubber-like material which is transparent to sound - it is definitely a 'theoretical effect'!!! Even then, done without accounting for the T-S parameters of the speaker would be like taking pot shots in the dark.
... And the stuffing can be done quite simple by removing the speaker and stuffing through the same hole that lies behind it. ...
Not sure I understand what you are trying to say. Stuffing what in which hole behind where? To remove confusion, 'stuffing' would mean stuffing cotton waste, CC foam or thermocole between 2 planes.
Old 22nd July 2013, 11:36   #103
bdman's Avatar
Thanked: 47 Times
Stuffing would mean any soft sound absorbing material. I used polyfill with is used to to fill pillows etc. It is polyester fiber and would not absorb water in case of leaks etc. When the speaker is removed, there is hole behind it that opens up into the door cavity. The polyfill can be stuffed through this hole into the door. Thermacole and other rigid material would not work as it would disintegrate.
Old 22nd July 2013, 12:21   #104
sumeshmani's Avatar
Thanked: 104 Times
I am not an expert, just sharing some internet findings.
http://moneyexpertsteam.blogspot.com...er-louder.html
This page says:
"Fill your subwoofer enclosure with polyfill can help increase the volume level of your subwoofer. Its simply buying a cheap bag of polyfill and stuffing it into your subwoofer box. What polyfill does is it tricks the subwoofer driver into thinking it is placed in a larger box with more cubic volume."
sumeshmani is offline   Reply With Quote
Old 22nd July 2013, 13:38   #105
DerAlte's Avatar
... I used polyfill with is used to to fill pillows etc. ...
So you used polyfill to fill the bottom 20% of the door (assuming the rest 80% is required to be kept free for window operation)!!! Interesting, though I wouldn't expect anything to happen - neither lowering of bass nor improvement of sound.
Originally Posted by sumeshmani View Post
... This page says: ...
Very simplistic, though not untrue - but only for specific configurations and setups. One wishes that one can extend such logic to other circumstances, or explain the maths behind it in easier terms.
1. One adds polyfill first and foremost to cut out the resonance in the subwoofer enclosure. Usually one uses 0.5-0.8Kgs of polyfill in a box with internal volume of 1cft. (approximation) for this
2. All this is dependent on Thiele-Small parameters of the subwoofer and the exact volume of the enclosure
3. The same logic cannot be extended to relatively higher frequencies, i.e. mid-bass speakers
a. The door cavity volume is much larger than what calculations with T-S parameters of the mid-bass would indicate as required enclosure volume
b. Putting stuffing in 20% of the enclosure volume doesn't even tickle any of the variables in the equation
Renault Duster : Wheel & Tyre Upgrade isldhn Tyre & Alloy wheel Section 89 19th November 2017 10:10
Nissan Terrano Unveiled : To be launched in early October parrys The Indian Car Scene 227 9th October 2013 14:56
Nissan's Duster-based SUV, the Terrano: Full Pics are out! CARDEEP The Indian Car Scene 381 20th August 2013 13:31
