Old 25th May 2006, 01:05   #46
Thanked: 21 Times
Originally Posted by sidharth_j
A 6x9 powered by an amp acts like an 8" sub. So; you will get enough bass.
No No NO!! a 6x9 doesnt ACT like a sub. It is not an actor. it is a speaker that has near equivalent cone surface area of a 8" speaker. Thats about it. A 6x9 speaker and an 8" sub have different design objectives and different applications.
Old 25th May 2006, 16:56   #47
shrivz's Avatar
Thanked: 92 Times
a lot of people have advised me to stay away from sony.. for various reasons, the only reason why people recommend sony is for the price...
Sam, Gunbir, Navin, what's your take on this? i'm a little confused out here...
shrivz is offline   Reply With Quote
Old 25th May 2006, 16:59   #48
jkdas's Avatar
Thanked: 1,436 Times
yah; its like a cheap 8inch sub. That its gives good bass for that money.
Old 25th May 2006, 17:02   #49
jkdas's Avatar
Sony do make good amps like the sd series or so.
Sony had 2 amps below 5k in India with B&W. So we suggest taht amp below 5k. 5k up you have Pios etc which are more poweful and vfm. Thats all I guess.
Old 25th May 2006, 17:06   #50
shrivz's Avatar
Thanked: 92 Times
Hmm.. i think i might go in for a used amp! is it advisable, will i get a used JBL within 5k-7k???
Old 25th May 2006, 17:10   #51
Sam Kapasi's Avatar
Thanked: 1,473 Times
Well you can get a CS amp. All JBL CS series amplifiers(2ch, 4ch and mono) are below 10K brand new.
Old 25th May 2006, 17:12   #52
jkdas's Avatar
maybe you can. Check if you get teh GTO75.4 or teh new cs series.
Old 25th May 2006, 17:17   #53
shrivz's Avatar
Thanked: 92 Times
thanks for the prompt replies guys... will keep you posted...
cheers!
Shrivz...
Old 28th April 2010, 21:16   #54
febyphilabr's Avatar
Default JBL 8' sub with enclosure
Hey guys,
Was going through this thread and I wanted to know if there are any JBL 8 inch subs in enclosure, i.e built-in at factory. If yes Samji could you please post the model no.?
If no, could you guys recommend any pre-fabricated boxes for the JBL GTO804 that gives a precise and tight bass! I am looking for this because, I might want to remove the subwoofer from the boot of my i10 rarely!
febyphilabr is offline   Reply With Quote
Old 28th April 2010, 22:36   #55
thelightening's Avatar
Guys !! my current setup is
Pioneer 4050 hu
JBL GT series 4" coxials in the front dash
JBL GTO 948 6x9 limited edition coaxials in the rear mdf box.
I am interested to go ahead with a sub and an amp.. which one I should go for.. its for a wagonR.
thelightening is offline   Reply With Quote
Old 29th April 2010, 00:03   #56
navin's Avatar
Thanked: 4,286 Times
Originally Posted by febyphilabr View Post
Hey guys,
8" bass tube? I have not seen one from JBL. Try their website to see if they have one.
Originally Posted by thelightening View Post
Pioneer 4050 hu
i'd look at a 4 ch amp from JBL, Pioneer, Kenwood etc.. and a 10" in a small sealed box. Use the amp to power the 4" (HPF 120Hz or so) and the sub (LPF at 100Hz or so).
Total cost: sub 5-6K, box 1K, wires: 2K, optional damping 3K so say 10-12K will cover this.
Old 29th April 2010, 01:31   #57
You got me wrong mate! I meant a small sealed box and not a bass tube!!
I believe both are two different things. Correct me if I'm wrong sir!!
Oh yeah!! Got it.
Crutchfield-Sound Ordnance Bass Bunkers
Is this worth the money?
Old 29th April 2010, 13:08   #58
navin's Avatar
I'd much prefer a small sealed box than a bass tube. It will help a lot witht he range between 50Hz and 100Hz but dont expect an 8" to produce good SPLs at 30-40Hz.
Old 29th April 2010, 13:35   #59
Navinji, I'm not looking for SPL !! Actually deep booming systems give me a headache after 10 mins of exposure, hence I prefer SQ and thought of putting in a sub just to reproduce the lows to a fair extent!!
Old 29th April 2010, 16:10   #60
Navin, I've got a doubt. If I drive a JBL GTO804 (200W RMS) sub with the GTO1004 amp, with rear channel bridged, i.e., 300W RMS fed into to the sub, will either of them go KA-BOOM ?
New Amp and sub for existing setup quakerme In-Car Entertainment 12 6th December 2010 11:48
Add amplifier to existing stock headunits arunkumars In-Car Entertainment 2 3rd June 2010 09:21
Which one: Dual 8" sub V/s Single 10" sub? Invinsible In-Car Entertainment 53 28th May 2009 13:33
To add Sub for NHC Vtec aks_karthik In-Car Entertainment 6 5th September 2007 16:05
Good Sub+Amp combo to add to my Esteem? aalaap In-Car Entertainment 23 21st January 2006 09:52
