Old 28th September 2012, 10:52   #16
navin's Avatar
Thanked: 4,282 Times
Default re: LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)
Originally Posted by low_bass_makker View Post
Each sub weights about 35 kgs. I have also done a weight check again. The weight of the enclosure is approx 70-75kgs, that is wood and fiber work only !!!
Originally Posted by nitrous View Post
I would suggest Swift diesel springs+struts up front and Dzire springs+dampers at the rear. This is the farthest you can go with OEM stuff.
LBM, I would agree with nitrous above. With the weight of the amps, batteries, box and woofers all adding up your Swift's weight distribution will drastically change. If this car is a daily driver you should consider overhauling the suspension to compensate.
Old 28th September 2012, 11:50   #17
kpzen's Avatar
Thanked: 1,655 Times
LBM,
Earlier you were running similar setup with 17" wheels.
What was the total weight of V1.0 ?
Old 28th September 2012, 12:08   #18
Thanked: 294 Times
Good stuff, LBM.
What have you planned to do to the cars mechanicals to handle the massive increase in weight?
I have modded the rear springs. I went to some shop who deals in repair of shocks and I have put two springs in the back. It is not the final mod will have to check the operation of the same with all the equipment in the ride. One more thing this not a daily drive car, It is just a show-off car !!!!
Will surely update the thread with the final outcome !!!
Originally Posted by ghodlur View Post
BTW how much weight is expected to be increased due to the ICE? Also will it be legal on the road..
How is the rear view vision being planned due to the wall?
Final weight would be in range of 450 kgs !!!
Rear camera will be installed !!!
Originally Posted by makanaka View Post
Very interesting thread, i will stay tuned for more updates, LBM are those steve meade designs subs? any specific reasons for choosing those over other spl subs, one other thing when you alter the existing power/ charging system does it effect other electrical equipments like AC, bulbs etc do share in detail if you can and please do clean the car after the install,
I have used SMD subs because I had them. And they are not at all SPL subs they are daily driving subs. No other electrical equipment is affected as the voltage is still in the permissible limtis
LBM,
Ya they were 17' wheels. This time I got the 16 inch wheels due to budget constraints but will be upgrading soon !!! And I did not weighted the earlier ride !!!
low_bass_makker is offline   (2) Thanks Reply With Quote
Old 28th September 2012, 13:05   #19
panky12345's Avatar
Thanked: 149 Times
Look who's talking..
Anyways, congrats to your GP V2.0. How do you wish to plan the front? FG enclosure? What is the list of the other equipment i.e. Front Speakers etc.?
panky12345 is offline   (3) Thanks Reply With Quote
Old 28th September 2012, 13:14   #20
iceman7's Avatar
Thanked: 259 Times
LBM - you are INSANE!! What a install Mindblowing...er...ground blowing actually.
Someone please inform the geological department when this is fired up. It's not an earthquake you will feel but LBM's ride.
Glued to this thread to see the final outcome
iceman7 is offline   (2) Thanks Reply With Quote
Old 28th September 2012, 16:18   #21
Thanked: 294 Times
Yet not decided !!!
But will FG the doors at a later stage. First priority is to finish what is in hand !!!!
Old 28th September 2012, 16:43   #22
Rehaan's Avatar
Thanked: 25,038 Times
Good lord LBM, this is crazy.... but AWESOME
One question (pardon my ignorance): It seems you're using MDF everywhere. Howcome MDF is used for most of these ICE installs rather than (stronger) plywood?
cya
R
Old 28th September 2012, 16:58   #23
greenhorn's Avatar
Thanked: 1,516 Times
here's a reply I dug up from navin
http://www.team-bhp.com/forum/ask-gu...ml#post1287241
Personally, I was under the impression that MDF was acoustically more inert than ply - in terms of damping out resonances. A simplistic explanation I read was that MDF was more homogenous than ply.
LBM, though that's an old thread, I'm curious why you used MDF (instead of Al you preferred then)
greenhorn is offline   (2) Thanks Reply With Quote
Old 28th September 2012, 19:24   #24
navin's Avatar
Exactly, ply is stronger but it MUST be void free. Ply also gives a nicer surface than MDF to veneer (good for home audio).
I used a brand of ply called Truwood. It is 100% gurjan ply.
In addition my current floor standing speakers have a 3mm sheet of lead sandwiched between the layers of ply, MDF and FRP. The speakers are based on Rick Craig's Tempesta Extreme.
http://www.audiocircle.com/index.php?topic=97720.0
However for car audio installs MDF and FRP make more sense since ply tends to "open up" over time due to heat and humidity.
navin is offline   (3) Thanks Reply With Quote
Old 28th September 2012, 20:33   #25
Desmosedici's Avatar
Thanked: 410 Times
Wow oh Wow!!! This is insanely insane. With such a humongous setup, it sure is going to blast of the glasses, windscreen included. Since you mentioned its a show car, i wont ask you further on the driveability etc. Way to go man.
Desmosedici is offline   (1) Thanks Reply With Quote
Old 28th September 2012, 23:49   #26
Gill's Avatar
Thanked: 12 Times
Guess who's back!
Will be watching this thread. BTW, in one of the photos of your friends helping you:- One of them was holding the sub is a scary manner.
Gill is offline   (1) Thanks Reply With Quote
Old 29th September 2012, 11:00   #27
Thanked: 294 Times
The equipment going in the ride !!!
  • Source -> Kenwood KOS-A300
  • Processor -> Alpine PXA - H 701 With controller
  • Amp for High +mids -> Rockford Fosgate T600.4 x 2 nos
  • Amp for Subs -> Rockford Fosgate T2500.1 x 4 nos
  • Highs -> Rockford Fosgate PP4-T Punch Pro 1.5" 4-Ohm Tweeter x 4 nos
  • Mids -> Rockford Fosgate PPS4-6 Punch Pro 6" 4-Ohm Midrange x 6 nos
  • Subs -> SMD 18 inches #59 and #60
  • Alternator -> Mechman 220 amps
  • Batteries -> Northstar NSB 170 (about 600 ah combined )
  • Wiring -> welding copper cable 0/1 and 0/2 runs with copper busbars
  • Rca -> Sommer cable with Neutrik Connectors
  • Enclosure -> 1 inch MDF with lots and lots of Reisn (approx 15-18 kgs with 5 kgs glass...solid as rock)
NOTE :- I am not a dealer or distributor of Rockford Fosgate. I am just using there equipment because I like them. I am not recommending the same to anyone !!!
low_bass_makker is offline   (3) Thanks Reply With Quote
Old 29th September 2012, 11:18   #28
W.A.G.7's Avatar
Thanked: 795 Times
Arrow re: LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)
That's a big install; as in really really big install
Sorry about the noob question (since we never had a chance to interact with each other before), but you have mentioned that this will be a show-off car, may I ask, do you own an audio equipment showroom or are you a dealer in car audio equipment (so you need to show the setup to customers)?
W.A.G.7 is offline   Reply With Quote
Old 29th September 2012, 11:56   #29
Thanked: 294 Times
No I am not a dealer or own a showroom. I am just a enthusiast like may other !!!
Saying it a showcar is a little incorrect I would say fun car. It is like starting the LOW BASS culture here in India and take the game to next level !!!
low_bass_makker is offline   (1) Thanks Reply With Quote
Old 29th September 2012, 16:53   #30
Safari_Beast's Avatar
Thanked: 202 Times
Lbm sir waiting eagerly for your ground pounder to be fired up, need to feel the bass from smd's in real. Seriously you are on a roll this time and best thing about your install is DIY. Hats off to you sir, you rock.
Safari_Beast is offline   (1) Thanks Reply With Quote
Windshield cracked. Need replacement anandtheleo Technical Stuff 56 2nd July 2017 16:37
Poor roads and a cracked windshield on my Ikon benbsb29 Street Experiences 54 23rd September 2009 14:25
Cracked Windshield - Advise needed Vivek Technical Stuff 1 17th June 2005 20:43
Windshield cracked in Indigo TheBrainCell The Indian Car Scene 5 3rd July 2004 12:21
