Old 30th September 2012, 20:37   #31
Thanked: 294 Times
Default re: LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)
Just finished the setup today. Final pics coming tomm. Tired as hell !!
low_bass_makker is offline   (4) Thanks Reply With Quote
Old 30th September 2012, 21:12   #32
abishek2222's Avatar
Thanked: 162 Times
Wow , you simply have gone berserk with your install. I guess the install does justice to your username.Simply devastating. Wish i could listen to it if i stayed close by. Why not choose a car with a larger cabin space for increased cabin gain?. Was the intention of the build to win a decibel drag from the inception or just for fun,
abishek2222 is offline   (1) Thanks Reply With Quote
Old 30th September 2012, 21:52   #33
Thanked: 294 Times
Same car is just matter of choice nothing else.
Intention is just pure fun nothing else.
low_bass_makker is offline   (2) Thanks Reply With Quote
Old 1st October 2012, 12:42   #34
govigov's Avatar
Thanked: 531 Times
Was the car weighed in? What was the final weight?
govigov is offline   Reply With Quote
Old 1st October 2012, 19:09   #35
Thanked: 294 Times
Checking the battery space
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120928_143748medium.jpg
Installed both batteries and checking space and location of busbars
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120928_164322medium.jpg
Final mockup of the amp rack with batteries underneath and
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120928_144101medium.jpg
With the busbars and amp rack in position.
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120928_165130medium.jpg
Busbar mounting on the base.
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120928_192732medium.jpg
continued
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120928_193155medium.jpg
Battery wiring done all the wire is 0/2 gauge 99.99 % annealed pure copper !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120928_204854medium.jpg
Amp rack installed !!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120928_214107medium.jpg
Wiring stared !!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120928_220512medium.jpg
After that I did not took any pic and worked sincerely in installing everything. I fired two amps first since I am still short of two batteries.
Played the setup for a day to check what it can do !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-328733_4233961941663_503747320_o.jpg
Due to the box rise the setup was playing with just 2000 watts clamped power of both subs combines.
Now the testing part starts !!! Let us hope for the best !!!
Not yet weighted the setup will do when all the batteries are in !!! Will be close to 1450 kgs !! Net weight will be approx 450 kgs !!!
low_bass_makker is offline   (6) Thanks Reply With Quote
Old 1st October 2012, 22:38   #36
govigov's Avatar
Thanked: 531 Times
Have you done any cooling mechanism in place for the amps? I think if the amps are all stacked up like that, it can generate a lot of heat.
govigov is offline   (1) Thanks Reply With Quote
Old 1st October 2012, 22:57   #37
Thanked: 58 Times
LBM sir still can see that sonata in 4th pic. I was not able to digest your older setup, this one you don't need any fuel to drive. Just switch on system and you are on the move.
sam003 is offline   (1) Thanks Reply With Quote
Old 2nd October 2012, 02:45   #38
Thanked: 294 Times
Yes I have added High CFM fans along the sides of the amps !!!
low_bass_makker is offline   (3) Thanks Reply With Quote
Old 4th October 2012, 12:48   #39
Blow Horn Ok's Avatar
Thanked: 466 Times
Crazy and Amazing Work! I saw the hair raising videos but never went through making of that kind of setup! This is taking the ICE to extreme level. Seeing the report I learnt many new things like the bus bar for car, the amp rack, Heavy duty alternator, separate batteries for amps and a lot more. I am sure this set up will rock and neighbors would curse your ride .
Do post the start-up and running videos.
Blow Horn Ok is offline   (1) Thanks Reply With Quote
Old 4th October 2012, 13:36   #40
speedmunster's Avatar
Thanked: 122 Times
That's some really crazy setup you got there. By the looks of it, would most probably knock the tooth fillings out of people. I would love to hear this monster.
Waiting for the pics of the final setup.
LBM, you rock.
speedmunster is offline   (1) Thanks Reply With Quote
Old 4th October 2012, 15:07   #41
Thanked: 41 Times
Originally Posted by abishek2222 View Post
Wish i could listen to it if i stayed close by. ,
I think with an install like this being close doesn't matter.
amazing work. Im sure all you'll be a hero in the schools that the neighbourhood kids go to.
"arey, swift wale uncle ki gaadi goes boom boom boom"
harshaguduru is offline   (1) Thanks Reply With Quote
Old 4th October 2012, 16:04   #42
Bazinga's Avatar
Thanked: 65 Times
Post deleted by the Team-BHP Support : Please do NOT post one-liners that add little or no informational value to the thread. We need your co-operation to maintain the overall quality of this forum.
Please read our rules before proceeding any further.
Bazinga is offline   Reply With Quote Received Infraction
Old 5th October 2012, 12:31   #43
bharatbs's Avatar
Thanked: 109 Times
Attachment 994418
Wiring stared !!
Attachment 994419
Crazy Stuff You pretty much have a mini Data Center in your boot. Now you need a beefier HVAC installed to get the BTU to acceptable levels.
I guess the party starts where ever your car stops.
bharatbs is offline   (2) Thanks Reply With Quote
Old 5th October 2012, 14:16   #44
Thanked: 294 Times
The car audio amps are designed to operated in a non air ventilated environment. But since I have installed 6 in a row I have put four 100+ CFM server grade fans to cool them. And when the extended demos are given the boot is opened to make them breath properly !!!
Old 5th October 2012, 15:18   #45
scarecrow's Avatar
Thanked: 154 Times
@LBM awesome stuff. Waiting for the final setup pics & hopefully a video of how is sounds
scarecrow is offline   (2) Thanks Reply With Quote
Windshield cracked. Need replacement anandtheleo Technical Stuff 56 2nd July 2017 16:37
Poor roads and a cracked windshield on my Ikon benbsb29 Street Experiences 54 23rd September 2009 14:25
Cracked Windshield - Advise needed Vivek Technical Stuff 1 17th June 2005 20:43
Windshield cracked in Indigo TheBrainCell The Indian Car Scene 5 3rd July 2004 12:21
