Old 13th November 2012, 09:10   #106
navin's Avatar
Thanked: 3,879 Times
Originally Posted by GTO
A windshield can be replaced. I'm worried about your ear drums
Do you wear ear plugs at demos & auditions? Please take care, man!
Most ear plugs will reduce SPL by about 30db at best. With the low frequency rumbles that LBM generates with his Ground Pounders I worry not so much about his ears but sometimes also what's between them.
Seriously, I believe Ragu is usually not in the car when he turns it on.
LBM have all these high output low frequency sound waves done any other damage? Engine moorings perhaps?
navin is online now   (1) Thanks Reply With Quote
Old 13th November 2012, 09:30   #107
deetjohn's Avatar
Thanked: 7,352 Times
Default Re: LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)
Insane! I still recall the first time I saw the V1.0 video. Never knew rumble from a sound system could distort a car quite like that.
LBM, I sincerely hope you wouldn't trade your Swift for a bus.
Take care man.
deetjohn is offline   (1) Thanks Reply With Quote
Old 13th November 2012, 14:23   #108
ramie2400's Avatar
Thanked: 58 Times
Suicidal, if you ask me !!
good luck.
Well dosen't matters even i use a Suicidal setup like this in my car but with 2 x 15s DC Audio doing about 32hz
Ramie
Old 13th November 2012, 22:21   #109
sohail99's Avatar
Thanked: 161 Times
The flex is unlike I've ever seen!!!
Truly an amazing feat, this!
But you should check this out - http://thorax.bmj.com/content/59/8/722.abstract
sohail99 is offline   Reply With Quote
Old 13th November 2012, 22:53   #110
Safari_Beast's Avatar
Thanked: 196 Times
Sohail now what will happens to this person in the video sitting between the woofers . There are many people in US which have bigger setup and they havent got any problem related to hearing .
Last edited by bblost : 13th November 2012 at 22:56. Reason: Fixed youtube embedding. Please use http instead of https for youtube urls.
Safari_Beast is offline   Reply With Quote
Old 5th December 2012, 16:59   #111
Thanked: 294 Times
I have finally installed the second alternator in my ride. The voltage now is very much stable. So stable that it does not goes below 13 volts at full tilt. And returns to 14.0-14.2 as soon I reduce the sub !!! The RF 2500.1 are very efficient amps !!! Very happy with the result.
The alt used here is Bosch 150 Amps Alternator doing approx 160 amps got it for approx Rs 6000 = $110. So the final combined current both alt give is 220 amps (Mechman) + 160 amps = 380 amps !!! More than what I need at the movement. I have installed switches to manual switch off the alternator if required . Like when the setup is not running and further reducing load on the engine !!!
The bracket of the alternator. I made it myself.
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20121204_154502.jpg
With the alt mounted
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20121204_155624.jpg
another view
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20121204_155635.jpg
mounted on the engine.
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20121204_161400.jpg
both the alts
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20121204_161501.jpg
current measured
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20121204_163601.jpg
low_bass_makker is offline   (6) Thanks Reply With Quote
Old 6th December 2012, 11:36   #112
Thanked: 294 Times
One more thing, the a/c compressor is still there. It was not removed for the alternator install.
Old 6th December 2012, 12:49   #113
audioholic's Avatar
Thanked: 4,899 Times
Could you share more information on the second alternator? Basically, I would like to know
1. How it is driven.
2. Was there space to accomodate the alternator?
Designing mounting for the alternator is definitely a PRO job! Congrats.
audioholic is online now   Reply With Quote
Old 6th December 2012, 13:22   #114
Thanked: 294 Times
Via a belt. Clearly shown in the pics along the space where it is installed !!!
If you need more info do let me know !!!
Old 6th December 2012, 16:14   #115
audioholic's Avatar
I got that it was belt driven. But did you use existing belts or did you add a pulley + belt to the existing pulley setup?
Old 7th December 2012, 13:48   #116
Thanked: 294 Times
I think this pic will clear all your doubts !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20121206_131949-large.jpg
low_bass_makker is offline   (3) Thanks Reply With Quote
Old 14th December 2012, 17:46   #117
Thanked: 36 Times
In the picture above, I can see bearings between the AC Compressor and the Second Alternator.
The bearings are uncovered and probably not crowned.
1. Don't you think you risk the bearings going bad if water splashes on them while driving.
2. And also, because there is no crowning over the bearings, don't you risk unnecessary vibration and slipping of the belt that might lead to premature failure?
Just some observations.
But yes, you deserve a lot of respect for this build.
Cheers!!
abhipuru16 is offline   Reply With Quote
Old 15th December 2012, 12:14   #118
Thanked: 294 Times
Cheers!!
Thanks !!!
The bearing used are sealed one and are resistant to fail in these type of situations. Also I would not be using this ride as a daily drive so the usage is very low.
Crowning is not required here as the belt is guided at two points that is the alternator and the compressor. The purpose of the bearing is to increase the belt wrap at both the alternator and the compressor. The belt stay at the same position and does not moves or gets slips even under load !!!
Old 16th December 2012, 01:04   #119
Thanked: 294 Times
Few pics !!!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-dsc_0865-large.jpg
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-dsc_0914-large.jpg
low_bass_makker is offline   (2) Thanks Reply With Quote
Old 16th December 2012, 09:53   #120
audioholic's Avatar
LBM bhai, could you show us a close up of the 'Warning' sticker on the rear windshield?
audioholic is online now   (1) Thanks Reply With Quote
Windshield cracked. Need replacement anandtheleo Technical Stuff 56 2nd July 2017 16:37
Poor roads and a cracked windshield on my Ikon benbsb29 Street Experiences 54 23rd September 2009 14:25
Cracked Windshield - Advise needed Vivek Technical Stuff 1 17th June 2005 20:43
Windshield cracked in Indigo TheBrainCell The Indian Car Scene 5 3rd July 2004 12:21
