Old 16th December 2012, 23:13   #121
Thanked: 36 Times
Default Re: LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)
Originally Posted by low_bass_makker View Post
Thanks !!!
The bearing used are sealed one and are resistant to fail in these type of situations. Also I would not be using this ride as a daily drive so the usage is very low. Its good you got sealed ones, but still, are these considered to be water-proof? Or just dust-proof?
The purpose of the bearing is to increase the belt wrap at both the alternator and the compressor. The belt stay at the same position and does not moves or gets slips even under load !!! Why not go for an idler pulley? Wouldn't that be simpler?
20 characters........
abhipuru16 is offline   Reply With Quote
Old 16th December 2012, 23:41   #122
Thanked: 294 Times
The bearing used here is a ZZ type. Nearly all the other bearing used in a automobile are nearly the same. And I am not going to immerse the bearing in water while using it. It is quite resist to both dust and water !!!
About the Idler pulley I did not get your point here. The bearing are used as a idler pulley just the diameter is a little small. Can you help me clearing up what are you asking here ????
Old 16th December 2012, 23:50   #123
Thanked: 36 Times
Instead of going for 3-4 bearings stacked together over a bolt (this is what I see), why not work up a design for a pulley itself and get it fabricated and mounted over a SINGLE bearing? You will be able to increase the arc of contact of the belt much further and the design would be much more reliable.
I mean, it would look neat and you wouldn't have to worry about the bearing going bad.
But yes, that's only when you are looking for reliability over a long-term. I don't think this design of yours will fail easily.
Just a suggestion if you wish to improve this design .
abhipuru16 is offline   (1) Thanks Reply With Quote
Old 16th December 2012, 23:59   #124
Thanked: 294 Times
Initially I was using a single bearing but the belt slipped under load. Thats why I installed two of them to increase the area. I might be putting a bigger bearing when these fail as they are designed to handle upto 15000 RPM. Next time I will be using a bigger diameter pulley/bearing to decrease the net RPM of the idler pulley/bearing !!!
Old 17th December 2012, 00:10   #125
Thanked: 36 Times
Good idea I'd say.
Also, with 3-4 bearings stacked together, they might heat up due to rubbing against each other, and ultimately, the lubricant inside might melt, but that's a remote possibility I think but you should still consider it.
It'd be better that you get one big bearing of the required dimension to be used as an "idler pulley".
Or better still, fabricate something similar to the pulley in the link below according to the dimensions you require-
http://www.google.co.in/imgres?q=idl...r:51,s:0,i:242
Old 17th December 2012, 01:12   #126
Thanked: 294 Times
Two bearing stacked together does not rub !!! There is always a little bit of clearance between them. And they both rotate at the same speed !!!! So from where the rubbing will come ???? Or the heat !!!!
And I cannot see the image. Please post it again !!!!
Old 17th December 2012, 17:19   #127
Thanked: 36 Times
Yes, I think you're right, they'll not rub.
The bosses of both the bearings will butt together and provide clearance.
Sorry for the confusion.
Regarding the pic, let me try again-
http://www.autopartsexpress.com/parts/Idler_Pulley.html
If not this, one big bearing (sealed) will be nice. You might have to keep the dimensions in check, but you will find it.
Old 24th December 2012, 17:08   #128
Thanked: 294 Times
Autocross Demo`s 2012 !!!
low_bass_makker is offline   (2) Thanks Reply With Quote
Old 24th December 2012, 18:01   #129
audioholic's Avatar
Thanked: 6,147 Times
So many people are practically tortured inside the car! Man I am drooling over such a setup now
audioholic is online now   (1) Thanks Reply With Quote
Old 24th December 2012, 20:27   #130
Thanked: 36 Times
To one and all, this thing needs to be experienced. Its a crazy setup inside his car. I had a look and "feel" of it at Autocross, BIC. If you think its "just bass", well, the bass, howsoever low and powerful, is still sweet-sounding, and that is something I found amazing. Even with so much power, the bass still sounds sweet from 50 meters away from the car, hehe.
One must appreciate LBM's effort towards building this setup ALL BY HIMSELF.
God knows how much study and fabrication must have gone into this build. The end-result is extraordinary .
Keep it coming, LBM .
abhipuru16 is offline   (2) Thanks Reply With Quote
Old 25th December 2012, 13:07   #131
Safari_Beast's Avatar
Thanked: 203 Times
Hello low_bass_makker Paaji
Windshield gone again , was just going through your links and found another from autocross 2012 .
Safari_Beast is offline   (1) Thanks Reply With Quote
Old 27th December 2012, 12:15   #132
Thanked: 294 Times
A small attempt at a Hair trick !!!
Old 27th December 2012, 13:44   #133
DerAlte's Avatar
Thanked: 2,879 Times
Bhai LBM Freedabadwale, be careful - you will be pulled up for domestic abuse (even if she was smiling).
Tangential thought: With a very simple attachment to the window, your setup can actually function as ... a cotton ginning ('dhunai') mill. Ask your neighbors to bring out their quilts.
DerAlte is offline   (3) Thanks Reply With Quote
Old 31st December 2012, 13:56   #134
Thanked: 28 Times
This is just awesome, each video is better than the one earlier.
I have to see this in person. LBM, agli trip me demo zaroor lene aaenge!
jaygeetee is offline   (1) Thanks Reply With Quote
Old 23rd September 2014, 22:29   #135
Thanked: 294 Times
My GroundPounder featured in Maruti Swift Showstopper contest !!!
low_bass_makker is offline   (10) Thanks Reply With Quote
Windshield cracked. Need replacement anandtheleo Technical Stuff 56 2nd July 2017 16:37
Poor roads and a cracked windshield on my Ikon benbsb29 Street Experiences 54 23rd September 2009 14:25
Cracked Windshield - Advise needed Vivek Technical Stuff 1 17th June 2005 20:43
Windshield cracked in Indigo TheBrainCell The Indian Car Scene 5 3rd July 2004 12:21
