Old 3rd October 2007, 18:40   #61
I have 6.5" comps installed in the front doors of my indica. No problems at all so far. Only had to get the sheet metal bent to make room for the speakers. Nothing major.
akg7091 is offline   Reply With Quote
Old 3rd October 2007, 19:02   #62
panky12345's Avatar
Thanked: 150 Times
akg, you also need to cut the stock portion AND bend the metal.
Old 3rd October 2007, 21:09   #63
Forgot about that. Yes, the stock plastic portion is also cut. There are no problems with the power windows in case anyone's wondering about that
Old 3rd October 2007, 22:37   #64
adityamunshi's Avatar
And did u do anything to protect it from water that may enter the door frame ?
adityamunshi is offline   Reply With Quote
Old 4th October 2007, 12:05   #65
panky12345's Avatar
Thanked: 150 Times
naah, kuchh nahin hota. chalne de. if you are overprotective, use an appropriate gear while in action (no am not talking about condoms).
Old 4th October 2007, 12:55   #66
Never had any problem with water entering the door till now. It might be because I have never driven my car through waterlogged roads before
Old 1st December 2007, 22:13   #67
Hi gurus
I'll be doing a DIY install of 6.5" coax speakers in the front doors of my Indica. Unfortunately there is no installer in my city who can fit a size larger than 5.25".
I have a few questions for the gurus :
Do I need to bend / cut the sheet metal visible behind the spacer ring in Picture 3 (caption in bold )
Is the spacer ring in Pic 3 attached to the plastic door panel or is it also attached to the metal door frame?
If only to the door panel, wont it become loose and rattle ?
@akg7091
What is the thickness of the spacer used in your setup?
Originally Posted by gunbir View Post
Hey Panky
B&T is right... the Indica takes 5.25" in the stock door location. BUT... you can fit larger sizes too, with a bit of mods of course...
here are some pics
You would need to cut out a portion of the stock locations plastic.
Install the door panel back and install a MDF spacer ring of approprite depth. What you see here is a 6.5" midbass driver.
Connect your speaker...
Mount it
Attach the grill
And you're done!!!
Old 2nd December 2007, 13:32   #68
Gurus. please reply.
I need this info urgently.
Old 2nd December 2007, 13:59   #69
Thanked: 21 Times
Not really, but that also depends on your spacer depth and midbass profile.
IIRC, its attached only to the plastic. And no, there are no problems till now as I met the owner recently.
Old 2nd December 2007, 14:04   #70
Gunbirji,
Thanks for the reply
A few more questions :
What kind of screws are best for attaching the spacer to the panel ?
As seen in picture 1 there is a screw on the door panel which is cut off with the plastic, Wont it affect the stability of the panel ?
Old 3rd December 2007, 21:35   #71
Any one ?? Gurus ?
MODS : Im bumping this thread again because i need this info urgently
Old 3rd December 2007, 21:46   #72
navin's Avatar
Thanked: 4,286 Times
I'd use a screw/nut combo and then use quick fix on the nut.
Old 3rd December 2007, 21:59   #73
Navinji, And would it be advisable to pass the screw through the metal sheet ?
I removed the screw (Pic 1) and the lower end comes loose. How should I fix that ?
Old 3rd December 2007, 22:51   #74
navin's Avatar
I dont see any metal sheet in those pics. just the door panel.
Old 3rd December 2007, 22:55   #75
Navinji,
This is what i was talking about. There's the plastic door panel just behind the spacer and the metal is about half an inch behind that.
Speaker Size. Does it really matter? nitin.dangayach In-Car Entertainment 19 18th December 2008 17:15
Speaker size for Palio Stile 1.6 Sports? uttamc In-Car Entertainment 7 29th May 2007 22:14
Fiat siena (new shape) speaker size ece2k2 In-Car Entertainment 17 25th April 2007 12:53
