Old 19th November 2012, 00:19   #1
sabret00the's Avatar
Thanked: 45 Times
Default Pioneer 7950UB HU Display Issue
It was all fine till today evening when the LCD stopped working. First I thought the LCD was dead but it comes for like a second when I press the cd eject button and then goes off which makes me think that this is due to a loose connection issue. Has anyone come across this problem before with this or any other HU?
I had bought it from grey market so will Pioneer India Service assist me? Or should I take the HU to someone else? I'm in Bangalore.
Does Autocop provide service for Pioneer products in Bangalore? Their website says:-
Store Information of Service - Car Entertainment (BANGALORE)
Delear Name : AUTOCOP (INDIA) PVT. LTD
Contact Name :
Dealer Address
19,3, GROUND, 1ST FLOOR, RAILWAY PARALLEL ROAD
NEHRU NAGAR, NEAR SHESHDRI PURAM COLLEGE
BANGALORE 560020
Dealer Contact No.
080-23563144
080- 23563142
080-40921709
sabret00the is offline   Reply With Quote
Old 19th November 2012, 11:05   #2
DerAlte's Avatar
Thanked: 2,879 Times
Default Re: Pioneer 7950UB HU Display Issue
Originally Posted by sabret00the View Post
It was all fine till today evening when the LCD stopped working. ...
Yes, looks like a loose connection all right.
Is the Service Center location the same as the dealer location? No harm in taking it to a Pio service center. At most they will charge if any part is replaced, if you don't have a valid warranty.
DerAlte is offline   (1) Thanks Reply With Quote
Old 19th November 2012, 11:16   #3
dreamdiesel's Avatar
Thanked: 55 Times
Not sure if this might help. But have you tried a factory reset? Its the small button on the bottom right corner of the display. Use a pen tip to push the tiny button.
dreamdiesel is offline   (1) Thanks Reply With Quote
Old 19th November 2012, 12:47   #4
Thanked: 167 Times
Most probably the wire strip from your head unit to the front plate on which the front fascia is attached (you can see this strip - press CD eject and look from below) has got cut & would need replacement. It is a frequent problem on this model of pioneer with faceplate slide mechanism & typically the wire strip lasts between 1.5 to 2 years.
I think it costs between 700 to 1K for the same. Any head unit repair center would be able to repair the same. However if possible get it done at pioneer center as it involves soldering & local repair guys are clumsy
malgudi is offline   (2) Thanks Reply With Quote
Replacement of DEH 7950UB to 80PRS subbarao In-Car Entertainment 8 10th July 2012 14:27
Pioneer 7950UB Query nikunj_cal In-Car Entertainment 147 19th February 2012 02:25
kenwood KSC X7016 wiring issue and no display makanaka In-Car Entertainment 8 30th March 2011 23:00
ALTO ICEd with Pioneer DEH-7950UB and JBL Speakers sabret00the In-Car Entertainment 74 28th April 2009 15:02
Pioneer headunit Graphics [change display gfx] buzzin_hornets In-Car Entertainment 25 20th April 2007 09:31
