Old 15th March 2007, 10:51   #16
ajitkommini's Avatar
Thanked: 109 Times
As many have said, it makes little sense to do what you're planning. consider the two alternatives
1. 12V DC from Car battery --->[Inverter]---> 220V AC --->[laptop pwer adapter] ---> 12V DC again.
2. 12V DC ----> laptop
Method 2 seems more direct, efficient and reliable right? Why dont you look for a laptop car adapter accessory?
ajitkommini is offline   Reply With Quote
Old 15th March 2007, 10:54   #17
rishibravo's Avatar
What is your exact purpose ..If the purpose is charging the laptop then Its better to get a 12V Laptop charger.
rishibravo is offline   Reply With Quote
Old 15th March 2007, 11:02   #18
tsk1979's Avatar
Thanked: 16,016 Times
Laptops use 40/35V DC.
So you still need a DC-DC converter, and that is more efficient.
Old 15th March 2007, 12:05   #19
Thanked: 294 Times
are nahi bahi...what I have seen is from 15 volts to 21 volts max.......with different companies but the 19 volt is the most common....
Old 15th March 2007, 12:19   #20
tsk1979's Avatar
yup, my mistake, its 19V actually.
Dell uses 19V.
You will need a DC-DC converter for a laptop.
Old 15th March 2007, 12:42   #21
gd1418's Avatar
Thanked: 656 Times
When I purchased a Garmin GPS device for self - iQue3200, it never came with a car adaptor. Its battery used to last for hardly 5-6 hrs. The GPS dealer then sold me an invertor - 12v to 220v AC ~ 150W for Rs.2500. That was 1.5 years ago. It is working fine and runs my laptop, DVD player, charges my GPS device etc.
Have not encountered any problem whatsoever.
Old 17th August 2007, 10:15   #22
Thanked: 33 Times
Default Is it possible...
to make a laptop draw power from the car battery?
Not sure why any one wud do that...but still then.
If so how?
amohit is offline   Reply With Quote
Old 17th August 2007, 15:36   #23
nitrous's Avatar
Thanked: 285 Times
There are car-chargers available for Laptops. Unbranded car chargers are dangerous for the Laptops.
So, I would suggest getting good brands.
Old 17th August 2007, 16:21   #24
gd1418's Avatar
Thanked: 656 Times
Go to - Inverters - Inverters under 1000 Watts
If so how?
Old 17th August 2007, 19:59   #25
chetanhanda's Avatar
Thanked: 44 Times
Originally Posted by naveendhyani View Post
hi all!
is there a device which plugs in the cigerette lighter adapter & can b used 2 charge ny 220 v device?
i mean something like a power strip which takes in 12 V, amplifies it to 220 V & has normal extension cords on the other end. sometimes need to charge the laptop & other electronic devices while on travel.
there are lots of them... but dont go for a cheap ones from ebay..get a branded one with a decent fuse..
also make sure it has an in-built fan/cooling system, coz they will get pretty hot lying on the floor of the car..
go for brands like Cobra -they got a decent reputation with radar detectors and other car gadgets , pretty good.
I've been using one for past 2 years..
chetanhanda is offline   Reply With Quote
Old 17th August 2007, 20:30   #26
hellstar's Avatar
Thanked: 17 Times
I recently brought one for about Rs 1.2 K from Hyundai A.S.S , comes with 6 month warranty and yes it has both a fuse and a Fan for cooling itself has been using it with my laptop and also my mobile and handycam charger. I have the 150 W version, but had i know about the existence of the 300W version i would have jumped at it :-).
But then again you have to check the fuse rating of he Car Ciggy Plug before you start attaching things on to it , or it might just blow you fuse .
you can find details of the product at AC DC Adapters Manufacturer,Switching Adapter Manufacturers,AC DC Adapters India,AC DC Switching Adapter,India
hellstar is offline   Reply With Quote
Old 19th August 2007, 00:40   #27
yuv
Thanked: 39 Times
hi... I got belkin a 1000 watts... using it since last 2 years.
no problems at all and it "is" very handy.
yuv is offline   Reply With Quote
Old 19th August 2007, 09:40   #28
hydrashok's Avatar
@yuv, did you buy it from India or abroad? If from abroad, did you buy online? Could you say how much you bought it for? I was also looking to get a good quality power inverter.
The ones in hellstar's links also look to be way better than the typical ebay-type ones.
Old 20th August 2007, 09:17   #29
rdkarthik's Avatar
Thanked: 11 Times
I have used and blown 9 inverters so far, all different brands and made in china and inda, all of them rated over 150W and with cooling fans....
Now i use an APC inverter secifically made for laptops. This has been the most reliablle and robust system so far for me. Retails for around 2.9k.
rdkarthik is offline   Reply With Quote
Old 20th August 2007, 10:23   #30
hvkumar's Avatar
Thanked: 3,362 Times
I use inverters (250 W) in my car that can be used to charge laptops, handycams and mobiles. For my Garmin GPS, I have a special adaptor supplied by Gramin (as an accessory). I bought the inverters in Bangkok, teh first one is over 2 years old, once there was burnout (thanks to an overload, my fault, tried to run a car vacuum cleaner off it!), but taht was locally repaired. I have tried finding teh inverters in India (Bombay, Lamingyon Road) but did not succeed. The inverter costs me less than Rs 1,500 equivalent in Bangkok.
After the adapter, I have no problems with charging any devices on the move. Particularly useful when I go on my long driving holidays.
hvkumar is offline   Reply With Quote
Laptop Battery charging? VMG Technical Stuff 1 17th August 2007 15:26
Charging my phone via laptop or PC abhibh Gadgets, Computers & Software 33 30th July 2007 12:35
Pre Fuel injection treatment by Electronic Convertor for Diesel and Petrol Suryam Technical Stuff 0 1st February 2005 11:39
