Old 1st July 2009, 02:50   #46
ghpk's Avatar
Thanked: 193 Times
Question CAR INVERTER, Are you using it, If Yes Details Please
Since last few days I am thinking of getting a Car Inverter like this one.
photo courtesy ebay
Has any one used it ?
Can someone be kind enough to post the Price for it and the supported wattage.
My primary requirement is to charge my laptop.
Thanks for your time,
Peace
Old 1st July 2009, 07:37   #47
Hi Bro,
Just a suggestion , instead of having a charger just for the laptop , you could go in for the one which has power plug like our household sockets , this can be used to charge anything like your mobile / laptop or any other small / light power withdrawing units . let me know if you want a picture of the same as I am using the same in my car.
passion4cars is offline   Reply With Quote
Old 1st July 2009, 07:39   #48
phamilyman's Avatar
Thanked: 3,520 Times
They do work - i've tested them - you get them between 500-1500 depending on how high end the point of purchase is.
However, I'm just a bit concerned about the quality of AC it'll generate - any long term users?
Old 1st July 2009, 08:16   #49
Thanked: 2,469 Times
Nice thread,
I am planning to use a similar setup for my 1971 VW Baywindow Bus.
I have purchased a 500 kva APC inverter and am going to use big batteries that'll hold more power.
This set-up needs to run a mini fridge,a electric coffee kettle, and some other small gadgets.
Anyone with more and precise detail, pls write
Old 1st July 2009, 09:58   #50
Abes's Avatar
Thanked: 57 Times
Panvan, it must be 500VA; 500kVA (500,000VA) big is enough to power a small village. You should go in for a 1500VA inverter if you are planning to use all of the equipments simultaneously; assuming that your kettle is 800-1000W and mini fridge is around 200W. Otherwise, 500-1000VA would be enough, depending on the wattage of the equipments and the nature of the use. Also the battery needs to be properly sized, based on the power requirement and duration of usage.
(W=VA*0.8 approximately)
ghpk, the laptop might be around 20-30W, you may require a 40VA inverter. Calculate the VA 20% more than your requirement; an inverter rated for 40VA might not safely give you 40VA continuously in the longer run.
Abes is offline   Reply With Quote
Old 1st July 2009, 10:02   #51
gpa
gpa's Avatar
Thanked: 281 Times
My friend is a long term user of one of these gadgets. We picked it up at a Crossword store here in Bangalore sometime in early 2006. He used to use it primarily for his old Thinkpad which didn't have an old battery and lasted for 10 mins or so on its back up.
He used to initially use it in his Santro and then has been continuing to use it in his i10 as well. He has not reported any problems with the power from the device.
Well, he still uses the Thinkpad, so it could also mean IBM's rugged construction hasn't let anything happen
Old 1st July 2009, 10:44   #52
tsk1979's Avatar
Thanked: 16,012 Times
If your inverter is upto 100W its okay. The car lighter socket is rated for 10A, If you use a more powerful inverter, the fuse can blow.
If you are connecting directly to the battery, then you can go higher, esp if its a bus. The alternator in that case will be pumping out 150A approx, and tapping 45A for your 500W setup should be okay.
Old 5th April 2010, 08:53   #53
akp
akp's Avatar
Thanked: 151 Times
Default car inverter query
Maximum load a car lighter socket can take is 120W (12V, 10A) -- does this mean that I should not connect an inverter rated higher than 120W, or is it ok to connect a higher capacity (say 200W) inverter as long as the devices I connect to the inverter do not exceed that 120W limit?
Thanks in advance.
akp is offline   Reply With Quote
Old 5th April 2010, 11:14   #54
Thanked: 60 Times
Thanks in advance.
You can connect a inverter of a higher rating as long as the load is limited to 120 W.
adnaps is offline   Reply With Quote
Old 13th April 2010, 03:49   #55
ghpk's Avatar
Thanked: 193 Times
I am using a CAR Laptop charger, this doesn't gives 220 volts, so less power drain from battery.
but charges my laptop perfectly, Been using it for months now, Its All good till now.
Cost me around 500 from ebay.in
Old 16th April 2010, 19:23   #56
SS-Traveller's Avatar
Thanked: 11,590 Times
Found this Belkin Inverter at my neighborhood electricals shop today. Output 220V 200W. Carries a warranty of 3 years. Price asked is Rs.1650.
It does mention that the fuse rating required is 20A.
Car Battery to 220V AC convertor / inverter for charging laptop etc-belkink150.jpg
Old 16th April 2010, 19:38   #57
akp
akp's Avatar
Thanked: 151 Times
Attachment 330914
You will get it a little cheaper at Nehru Place. Picked it up from there at Rs. 1425/-. But I guess its much more hassle free to be able to pick it up from a neighbourhood store rather than running to Nehru Place. Do they have other car electrical items as well? If yes, mind telling where is this shop? I am pretty near to VK.
Old 22nd November 2010, 19:37   #58
deky's Avatar
Thanked: 1,051 Times
Attachment 330914
Some more photos of the same adapter, but out of the box. The specifications as mentioned on the electrical unit are
BELKIN
AC Anywhere with USB charging
model# F5L071ak200W
input : 11-15VDC
output: 220V AC/50hz
constant output : 200W
peak output : 400W
fuse rating : 20A
Car Battery to 220V AC convertor / inverter for charging laptop etc-22112010130.jpg
Car Battery to 220V AC convertor / inverter for charging laptop etc-22112010131.jpg
Car Battery to 220V AC convertor / inverter for charging laptop etc-22112010132.jpg
deky is offline   Reply With Quote
Old 23rd November 2010, 00:34   #59
ghpk's Avatar
Thanked: 193 Times
Recently bought a Android phone (galaxy3) from futurebazaar, they offered a similar belkin inverter for free, however this one is 85W with peak of 170W.
They shipped the belkin charger real promptly however the phone is still out of stock since last 12 days.
I think this inverter/charger can charge laptop of 65W or a Handycam atleast.
Any existing user of 85W belkin inverter ?
how's the performance of this unit ?
I'll fix this permanently in car somewhere with a separate switch and wiring at a later date so it can be used instantly if needed.
Car Battery to 220V AC convertor / inverter for charging laptop etc-img_b2.jpg
Old 23rd November 2010, 22:23   #60
Thanked: 660 Times
Bought these at NP long ago for 1800/-. So far its been almost two years and has not given any problems yet.
Laptop Battery charging? VMG Technical Stuff 1 17th August 2007 15:26
Charging my phone via laptop or PC abhibh Gadgets, Computers & Software 33 30th July 2007 12:35
Pre Fuel injection treatment by Electronic Convertor for Diesel and Petrol Suryam Technical Stuff 0 1st February 2005 11:39
