Old 28th April 2011, 13:03   #61
Thanked: 386 Times
Default Re: Electronic chargers/inverters for cars (for laptops and other devices)
Originally Posted by SirAlec View Post
Bought these at NP long ago for 1800/-. So far its been almost two years and has not given any problems yet.
Am thinking of buying a car inverter to charge my camera batteries and laptop, there are too many watts and volts flying around...could any one pls let me know the minimum voltage or wattage i need to buy?
My camera battery charger plugs into my wall socket and has the below mentioned graffiti on it...
Volts: AC 100V-240V, 300mA, 50/60Hz
ChargerType: Li-ion battery charger
Output Volts: DC 12V 500mA
Any advise?
nix1976in is offline   Reply With Quote
Old 28th April 2011, 14:30   #62
tsk1979's Avatar
Thanked: 15,682 Times
Laptop usually needs higher current than your camera charger.
So lets say if your laptop was 100W at peak power, a 200W Belkin inverter would do fine.
It will charge your camera batteries with ease.
Regarding Laptop charging, if its a small 15" piece, its okay, otherwise the current drawn from car battery will touch 10A, and 10A is usually the fuse rating.
Old 28th April 2011, 20:27   #63
SS-Traveller's Avatar
Thanked: 10,966 Times
...the current drawn from car battery will touch 10A, and 10A is usually the fuse rating.
The Scorpio comes with a 15A fuse as standard for the cigarette lighter socket. My Belkin had a 20A fuse. Changed it to a 10A fuse, with a few spares lying around, because it's easier to change the fuse on the inverter than fiddle around under the steering column on a pitch dark night in the middle of nowhere!
Old 25th July 2011, 18:57   #64
Awaiting Email Confirmation
Thanked: 4,221 Times
Default Car Inverter-Cum-Charger With 220 V AC Supply
My Linea does not have provision for 220 V AC supply for using laptop for long time during long trips. So, I am looking for a good car inverter-cum-charger that converts 12 V DC into 220 V AC through the cigarette lighter socket. I searched and found this in ebay.in. Any reviews on this Belkin AC Anywhere car inverter? Kindly advise whether I can go ahead with this or if there is any other brand, please suggest.
J.Ravi is offline   Reply With Quote
Old 25th July 2011, 19:26   #65
v&v
v&v's Avatar
Thanked: 1,071 Times
Default Re: Car Inverter-Cum-Charger With 220 V AC Supply
There a lots available and i am using Tripicool bought from Reliance auto zone.
Here is the link for the same. OEM Fitted Products | Tropicool
Also here is the thread on car inverters.
http://www.team-bhp.com/forum/techni...devices-4.html (Electronic chargers/inverters for cars (for laptops and other devices))
v&v is offline   (1) Thanks Reply With Quote
Old 25th July 2011, 20:59   #66
Ricky_63's Avatar
Thanked: 388 Times
Those invertors are available at almost every decent accessory store, why bother with ebay ??
Ricky_63 is offline   (1) Thanks Reply With Quote
Old 26th July 2011, 07:37   #67
Thanks a lot, v&v. Today, I shall visit Reliance Autozone near my home and explore. I searched in vain for the exclusive thread.
Thanks for kind information, Ricky_63.
Old 26th July 2011, 08:11   #68
parimal_g's Avatar
Thanked: 174 Times
Check if you can get Belkin, i think they have best quality.
parimal_g is offline   (1) Thanks Reply With Quote
Old 26th July 2011, 08:37   #69
yogeshnagpal's Avatar
Thanked: 81 Times
This gadget is a real interesting stuff I saw at my neighbourhood sardarji's car accessories shop. When I asked him he said its good stuff and they drove to Delhi in their Innova and carried the same inverter. On the way connected a juicer to that inverter and enjoyed fresh juice on the go.
Just wanted to check with bhp'ians here on the kind of impact this inverter will have on the battery. Wouldn't it drain the battery if you connect a juicer.
yogeshnagpal is offline   (1) Thanks Reply With Quote
Old 26th July 2011, 08:49   #70
My Linea's cigarette lighter socket can withstand up to 15 A, and with its battery's DC supply of 12 V, I can use any gadget with a power consumption of 180 W or less. So, please check the gadget's power consumption before use to prevent blowing of fuse.
Old 26th July 2011, 09:53   #71
sgiitk's Avatar
Thanked: 3,786 Times
Infractions: 0/1 (5)
I would say 150W may be more like it. These inverters are not exactly the most efficient. If you need more juice you should be able to go for a bigger fuse (within limits). Some older cars may even have 10A fuses, so maybe 100W is more like it.
I will agree that Belkin are excellent. Tropicool should also be very good.
sgiitk is offline   (1) Thanks Reply With Quote
Old 26th July 2011, 10:18   #72
John's Avatar
Thanked: 166 Times
I am using a Belkin with 200W output. Works great, also has a USB charging port.
John is offline   Reply With Quote
Old 26th July 2011, 10:19   #73
mercedised's Avatar
Thanked: 161 Times
I have one purchased for 250 Rs from a local electronic shop (the one which is used by THELAWALAS), connected the wires with battery of the car and putted a 15 Amp fuse in between. I use it for charging my laptop and phones in the car. It is hardly of the size of a little kids lunch box.
mercedised is online now   Reply With Quote
Old 26th July 2011, 14:44   #74
Just a few minutes back, I placed an online order with letsbuy.com for Belkin F5L071Ak200W AC Anywhere + Usb Port + 200W costing Rs 1499 inclusive of shipping and delivery. This is my first transaction with letsbuy.com. Thanks a lot for recommending Belkin.
Old 26th July 2011, 14:57   #75
Thanked: 127 Times
J.Ravi: Something like this? 100W Universal Car/Home Laptop AC Power Supply with 8 Connectors (AC 110~240V / DC 12V) - Free Shipping - DealExtreme
You can also search for similar stuff on DX web site, in case interested. DX ships as well, but takes a few weeks to receive it in your hand
EDIT: Just saw that you have placed order at letsbuy.com, sharing still as it might help others.
narayanang76
narayanang76 is offline   (1) Thanks Reply With Quote
Laptop Battery charging? VMG Technical Stuff 1 17th August 2007 15:26
Charging my phone via laptop or PC abhibh Gadgets, Computers & Software 33 30th July 2007 12:35
Pre Fuel injection treatment by Electronic Convertor for Diesel and Petrol Suryam Technical Stuff 0 1st February 2005 11:39
