Old 10th November 2014, 18:06   #106
DerAlte's Avatar
Thanked: 2,879 Times
Default Re: Pen Drives : Compatibility issues with Head-Units
Originally Posted by Intrepidspy View Post
By FF I mean that a normal mp3 song when accessed through a 3.0 USB (32GB) on the HU will play by missing a few lines then again play a few lines normally and then again skip a few lines. this goes on...
Which HU?
This 'pausing FF and playing normal for a short while' "preview" would be the implementation method of FF on your HU. One can quickly reach the end of the song otherwise, if this is not done. This has nothing to do with USB 3.0, AFAIK. The behavior would / should be the same with a USB 2.0 pendrive.
Old 11th November 2014, 09:29   #107
I have Pioneer (DVH-3290UB/XNID
As i mentioned, the USB 2.0 works perfect while playing the songs its only the new 3.0 is acting weird.
I just wanted to know if this is something which others have also faced and have found a solution before checking for any hardware issues.
Thanks!
Intrepidspy is offline   Reply With Quote
Old 29th December 2014, 14:11   #108
I am facing the exact same issue. I used a Adata USB 2.0 2GB PD in my XUV500 W6(Stock HU) and it played fine. I put the same songs and more in a Sandisk USB 3.0 16GB drive and the songs started skipping. Dont know what the issue is!
saneguy is offline   Reply With Quote
Old 6th June 2017, 15:35   #109
Thanked: 263 Times
Talking REBOOT YOUR CAR AUDIO - Pen Drives : Compatibility issues with Head-Units
Here is something I tried after a few frustrating weeks of formatting and partitioning and buying - just reboot your car audio. (I'm not sure it actually rebooted, but it did clear something).
How? I pulled the accessories fuse (use the fuse puller provided in the fuse box - for Maruti its in the engine compartment fuse box cover) and wait for a few seconds. Put the fuse back in and try your USB drive again.
You could do this by disconnecting the battery too.
For me, this worked.
mvadg is offline   Reply With Quote
Old 6th June 2017, 16:08   #110
condor's Avatar
Thanked: 4,898 Times
I am using an Alpine KDE-226BT in my Safari. I regularly switch off the engine at long stops in city traffic.
Problem noticed: The pen-drives I use regularly go bad. These are of different brands & capacity.
Is this a problem specific to the HU that I have ? or is it normal across different brands of HU ?
All about USB Flash Drives a.k.a Pen Drive / Thumb Drive / Memory Stick / Jump Drive KSM-Vtec Gadgets, Computers & Software 1 28th February 2012 12:04
USB head units destroy pen drives (due to heat?) akash_m In-Car Entertainment 69 30th July 2008 10:24
The Quick and Dirty on Car Head units & Amps navin In-Car Entertainment 51 21st March 2007 09:15
MP3 flash card compatible head units? Why not? navin In-Car Entertainment 32 19th October 2005 00:36
Let's tweak PIONEER Head Units zzzehar In-Car Entertainment 54 26th September 2005 09:48
