Closed Thread
Old 12th May 2006, 11:55   #16
navin's Avatar
Thanked: 4,286 Times
does you cd player have a line out in addition to the headphone out.
navin is offline
Old 12th May 2006, 12:42   #17
kURETI's Avatar
Originally Posted by merve_extreme
yes i have tried keeping it at the bare minimum but the noise is ever present.And what better can i use than the original adapter.
from the headphone output to the input (line in auxi/p to the headunit) of the headunit there are 3wires right channel wire, left channel and ground right - what you do now is disconnect or cut this ground wire. (just remove it)
kURETI is offline
Old 13th May 2006, 10:14   #18
merve_extreme's Avatar
Thanked: 12 Times
If i remove the ground wire then the audio level drops to a very very low level.
@navin-there is only one audio out.
merve_extreme is offline
Old 15th May 2006, 11:23   #19
kURETI's Avatar
that's not a problem, i like to understand has the noise been elimibated completely!!!!!!!!!!1
kURETI is offline
Old 15th May 2006, 20:06   #20
Thanked: 12 Times
no even if i remove the ground the noise of the motor spinning is always there if powered by the DC-DC adapter.
Old 17th May 2006, 17:09   #21
kURETI's Avatar
Please change your system from Blaupunkt - The only solution now available to you.
kURETI is offline
Old 17th May 2006, 17:52   #22
Thanked: 294 Times
One more buy rechargeable aa batteries this will be the cheapest option for u.
low_bass_makker is offline
Old 17th May 2006, 17:58   #23
Sam Kapasi's Avatar
Thanked: 1,473 Times
I agree with LBM. Buy rechargeable cells and a charger, that seems to be the cheapest solution.
Sam Kapasi is offline
Old 17th May 2006, 21:31   #24
Thanked: 12 Times
@Low_bas and Sam:Yeah i already did that.Bought 6 Sony 2300 mAH nimh rechargeable cells with one hour quick charger.
anyways thanks for advice to all of you.
Old 17th May 2006, 23:03   #25
Sam Kapasi's Avatar
In the interest of TBHP server space i now request the mods to close this thread. It's relevance is exhausted.
Closed Thread
Adding USB, Aux & Bluetooth to integrated in-dash audio system JLN In-Car Entertainment 6 29th September 2014 14:08
DIY blaupunkt Aux adapter greenhorn In-Car Entertainment 8 18th April 2009 22:51
Diy Car Audio Preamplifier for Aux-in _abhay_ In-Car Entertainment 8 1st June 2008 12:31
Blaupunkt 4-ch Amp, Blaupunkt ODx 6x9 3-way coaxials & 6.5" 2-way coaxials for sale hydrashok Shifting gears 3 16th March 2007 16:43
