Closed Thread
Old 10th May 2006, 23:54   #1
merve_extreme's Avatar
Thanked: 12 Times
Default Blaupunkt audio aux in problem?
I have a Blaupunkt Bologna C50 car audio.It has an aux in on the rear pannel.
I have connected a portable Sony Cd player to this aux in.I power the Cd player using a 12V to 4.5V Dc-DC converter which fits in the cigrate lighter slot.
Now my problem is that when i turn on the Cd and start playing it i can hear the noise of the CD motor spining from my car audio speakers,this noise increases as the motor spins faster.This problem does not occur if i use 2 AA battries to power the Cd instead of the DC source.i have tried different portable audio Cd players and this happens for all of them.
Please help me.
merve_extreme is offline
Old 11th May 2006, 00:01   #2
Thanked: 294 Times
This is because of the differance in the ground of the dc-dc converter and the aux in HU. It means that the dc-dc converter and Hu aux in have voltage devloped between ground points. U must change the dc-dc converter or it may damage ur cd player or HU aux point.
Also is this dc-dc converter of any make ? and if yes which make.
low_bass_makker is offline
Old 11th May 2006, 00:13   #3
Thanked: 12 Times
It is sony's original car power adapter.so from what you are telling me if i use the ground of the aux HU instead of the DC_DC converter's this problem will not happen.
should i take the ground from the HU of the car and give it to the DC-DC converter or should i give the +ve 4.5 V from the DC-DC converter and ground from the AUX HU to the CD player.
please help.i need to sort this ASAP.
Old 11th May 2006, 00:39   #4
Thanked: 294 Times
u can do the later one and also connect the ground to the dc-dc -ive also, but first check for the voltage across the dc-dc converter output first before connecting any thing....
Old 11th May 2006, 01:02   #5
Thanked: 12 Times
ok i am going to try it.
Old 11th May 2006, 02:11   #6
Thanked: 12 Times
tried the method.it dosent help one bit.Is there a solution to this problem.
Old 11th May 2006, 12:27   #7
Sam Kapasi's Avatar
Thanked: 1,473 Times
Try this.
You are using a Stereo EP (earphone pin) to 2 RCA audio out wire.
This wire then goes into the aux in on your HU right? Take a small wire and earth the negative of the RCA pin. I mean, take a wire and wrap it around the negative of the RCA. Then touch this wire to the chassis of the HU.
Let us know the result.
Sam Kapasi is offline
Old 11th May 2006, 12:33   #8
Thanked: 294 Times
sam this is what i am trying to say....
Old 11th May 2006, 12:57   #9
Sam Kapasi's Avatar
Sorry LBM, I didn't read what you wrote earlier. This should solve the problem.
Old 11th May 2006, 13:06   #10
Thanked: 12 Times
Originally Posted by Sam Kapasi
Try this.
this is not a RCA to stereo wire.on the rear aux in connector in blaupunkt there are 3 pins.Audio In left .audio in right and AF ground.
now what i did yesterday was took a piece of wire and connected the AF ground to the ground of the HU,but it dosent help.i even tried to connecting the HU ground to the ground of the DC-DC converter.
but it dosent help.what can be the cuase of theis issue.if i use a portable TV or mp3 player powered by same DC-DC and give the audio to the aux in there is no problem but all portable CD players are having this issue.i tried atleast 5 different makes.
Old 11th May 2006, 13:37   #11
Thanked: 12 Times
Does anyone know how to design a ground loop supressor.if yes please give me the details.
Old 12th May 2006, 01:38   #12
kURETI's Avatar
Install a better quality cigar lighter.
Try this and let me know
kURETI is offline
Old 12th May 2006, 01:41   #13
kURETI's Avatar
hey wait try this also.
Keep the volume on your portable cd player at a little more than the min volume. and then use the system volume control knob in the system.
I think the input sensitivity is high
kURETI is offline
Old 12th May 2006, 10:08   #14
navin's Avatar
Thanked: 4,286 Times
Are you using line out or headphone out? If you are using the later what Kureti says can help.
navin is offline
Old 12th May 2006, 11:53   #15
Thanked: 12 Times
yes i have tried keeping it at the bare minimum but the noise is ever present.And what better can i use than the original adapter.
Closed Thread
Adding USB, Aux & Bluetooth to integrated in-dash audio system JLN In-Car Entertainment 6 29th September 2014 14:08
DIY blaupunkt Aux adapter greenhorn In-Car Entertainment 8 18th April 2009 22:51
Diy Car Audio Preamplifier for Aux-in _abhay_ In-Car Entertainment 8 1st June 2008 12:31
Blaupunkt 4-ch Amp, Blaupunkt ODx 6x9 3-way coaxials & 6.5" 2-way coaxials for sale hydrashok Shifting gears 3 16th March 2007 16:43
