Old 19th February 2013, 14:57   #1
invincible7's Avatar
Thanked: 154 Times
Default Troubleshooting an Intermittent Speaker Issue
Need help from the Gurus.
Currently the sytem in my car is going through a mixed phase and I kind of finding it difficult to pin point on the exact issue.
The comps are being driven from a 2 channel amp with dedicated 4 AWG wire connection.
Now the problem is the system will work fine and then when I start the car next morning the right side speakers wont work and at times both wont work, if I raise the volume up it kindof starts working for some time and then back to not working.
I got the wiring check, even got the entire speaker wires replaces for both but still the issue persists.
Went ahead and changed the HU to see if its the HU, still its same.
In the meantime it was found that the amp is shutting of in between, so to be sure installed a spare amp to see if its the amp itself.
The sytem worked fine for hours and today morning the right side doesnt work.
Have checked the connections, ground including its fine.
When the sytem works both the speakers. i.e. right and left work flawlessly and there is no issue.
But then suddenly the next morining one of the side wont work.
I am kindof stuck what to look for now to troubleshoot the issues, do you think I should change the 4 AWG wire to see if thats the problem cause that is what is left now in the equaltion of is there anything which I have missed out.
invincible7 is offline   Reply With Quote
Old 19th February 2013, 15:30   #2
Thanked: 21 Times
Default re: Troubleshooting an Intermittent Speaker Issue
When you wrote this, I got a feeling someone's been driving my City :-)
I have an identical problem in one of my rear speakers. When it wont work, I would raise the volume really high & it'll start working fine. After some time, it'll fizzle out again until I realise the difference in sound. Got wires/connexions checked, the guy fooled me saying "carbon aa gaya hai, saaf kar diya, ab chalega" but its still the same. Mine is a no-frill Kenwood HU with 2 front and 2 rear speakers and no amp, etc.
anujatwork is offline   Reply With Quote
Old 20th February 2013, 10:13   #3
navin's Avatar
Thanked: 4,282 Times
Default Re: Troubleshooting an Intermittent Speaker Issue
Guys, check connections at the speaker end. Maybe something is shorting.
Old 20th February 2013, 11:16   #4
Thanked: 708 Times
If problem persists after changing speaker cables, please check RCA connectors/cables.
Please check how amplifier has been grounded. As far as I know, it should be on non-painted area on car body.
Have you checked if amp remains ON when you face this issue? If amp remains ON, problem would be with RCA cables/connectors. If amp doesn't remain ON, problem lies with amp or amp grounding.
sukiwa is online now   Reply With Quote
Old 20th February 2013, 13:12   #5
Thanked: 154 Times
Yes the RCA cables has been changed too, grounding is without paint and has been checked as well.
The amplifier is ON as one of the sides i.e. left is working fine.
The next set of things I plan to check is.
1. Check the wires ones again to be sure again.
2. Move the grounding point though its as per norms i.e. without paint and confirmed connection.
3. Change the 4 AWG wire (power and ground wires).
4. Check the remote wire, though the amp is ON as one of the sides is working but just to be doubly sure.
Old 20th February 2013, 14:16   #6
shuvc's Avatar
Thanked: 287 Times
You seem to have eliminated most options.
I'd switch the L and R speakers and then switch the crossovers too. And see if this then repeats on the RHS. If the problem starts on the LHS then you have a component problem.
Old 6th March 2013, 13:53   #7
Thanked: 154 Times
Thought about updating this thread.
The problem was resolved, there was some issue with the amp which was shutting down intermittently.
The wires as it is were checked again, fuse changed and now it works fine.
Can you change the time interval set for intermittent wipers? girlieonwheels Technical Stuff 14 27th August 2011 11:43
Nissan Quest - Intermittent air-con blower speed vivekiny2k Technical Stuff 1 21st July 2009 13:11
Intermittent Issue with Sony Car Stereo. keralshobhit In-Car Entertainment 11 16th July 2009 12:07
Intermittent Squeal in Zen @ri Technical Stuff 3 10th December 2008 15:05
Intermittent headlight malfunction : What could have gone wrong? kvish Technical Stuff 1 22nd May 2008 15:58
