Old 10th May 2007, 22:26   #196
elf
elf's Avatar
Thanked: 9 Times
Originally Posted by shrivz View Post
... rubber smells ...
That's the excuse I always use.
Jokes apart, when I'm out for work (yes, I do that sometimes), my car's most often parked in the sun & am worried that it'll get stinking hot in more ways than one.
All that rubber will definitely make me sick by the time I get back.
Do Dynamat, Wuerth, etc. also stink?
elf is offline   Reply With Quote
Old 10th May 2007, 23:13   #197
Thanked: 294 Times
dont know about dyna......but wuerth does not stink.......
Old 10th May 2007, 23:36   #198
Sam Kapasi's Avatar
Thanked: 1,473 Times
the rubber smells, so i'd be better off with using just the required amount, otherwise i'll have smelly door panels..
Let me get this straight. It smells now? Before the sun warms it up?
Shrivz, you're going to sacrifice your olfactory sense i favour of aural excitement?
I suggest DIYing a gas mask. Start with an old Y front underwear....
Sam Kapasi is offline   (1) Thanks Reply With Quote
Old 11th May 2007, 00:24   #199
Thanked: 294 Times
nice one Sam Bhai.........
so are we expecting a new thread on this.....
Old 11th May 2007, 09:38   #200
navin's Avatar
Thanked: 4,286 Times
Navin I suggest we remove all of Shrivz's and related posts from this thread and create a DIY damping thread, in the DIY section.
It is a bit painful so please be patient I am not good at all this computer stuff.
Old 11th May 2007, 09:45   #201
shrivz's Avatar
Thanked: 92 Times
actually, its not stinking at the moment, im just dreading the worst!
anyways, if it does stink and becomes intolerable, I'll start a new thread..
The Dont DIY damping thread!
and of course get rid of the damping..
shrivz is offline   Reply With Quote
Old 11th May 2007, 11:06   #202
elf
elf's Avatar
Thanked: 9 Times
Another DIY tip, shrivz. Add lumps of charcoal - 2 for each door, 2 below each seat. It should take care of the smell of the rubber. I always install a lump of charcoal in my rubber before usage.
In case that doesn't work, I could sell you a slightly used pair of my Y-fronts. It's still got the original labelling, but no box.
Since you're a BHPian, it'll be cheap. Only 300 bucks.
Old 11th May 2007, 13:18   #203
navin's Avatar
I always install a lump of charcoal in my rubber before usage..
Do you need to? Considering the rubber you are using has high carbon content (BTW it is also electrically conductive).
The Behavior of Carbon Black-Filled Natural Rubber under High Strain Rates
Old 11th May 2007, 13:25   #204
elf
elf's Avatar
Thanked: 9 Times
My point exactly.
To quote:
"The modulus increased with increasing strain rate because there was little time for stress relaxation. Above a critical strain rate, no change in modulus was observed because the time of the experiment was short compared to the lowest characteristic relaxation time of the material. Dynamic stress-extension ratio curves did not have the very sharp upturn at break, which is observed from strain-induced crystallization in natural rubber under quasistatic loading."
In simpler terms, don't overuse your prophylactics or you'll suffer from overstrain & failure. Use the blue pill to avoid such situations.
Especially at our age.
Old 11th May 2007, 14:27   #205
shrivz's Avatar
Thanked: 92 Times
@elf: thanks.. but i dont need the Y-fronts... the car was in the sun the whole day and isnt smelling..
Finished the second door today.. and I'm happy.. still need to identify some very minor rattles, (this takes the maximum time!)
cheerss!
Old 11th May 2007, 14:31   #206
elf
elf's Avatar
Thanked: 9 Times
shrivz, don't mean to nit-pick, but was the car closed & parked in the sun or was it open?
I'm really curious because as I explained to you the other day, I plan to use copious quantities of the stuff all over the interior, & don't want my car smelling like a new gum boot.
Old 11th May 2007, 16:06   #207
Sam Kapasi's Avatar
Navin, he adds the lump of charcoal to his rubber before use, so as to fill up the rubber nicely. Endowment is a requirement these days, gone are the days when size didn't matter.
Old 12th May 2007, 10:05   #208
navin's Avatar
lump of charcoal to his rubber before use.
Reminds me of a song my son was singing a few weeks ago. Something like
"My love (love), my love, my love, my love (love)
You love my lady lumps (love)...
My lovely lady lumps (lumps)
In the back and in the front (lumps)"
Old 12th May 2007, 10:20   #209
elf
elf's Avatar
Thanked: 9 Times
Size doesn't matter. Remember, I'm the one who chopped 4 inches off my shaft to increase pleasure. That's 'gear shaft' & 'shifting pleasure'.
I was talking about the smell of the rubber. Nobody wants a stinky butyl smell when you're in the mood to have some fun. Correct?
Also, shrivz is making his own rubber. Such problems would not arise if one used more expensive off the rack options.
Old 12th May 2007, 10:29   #210
shrivz's Avatar
Thanked: 92 Times
i shall send you a free 1" x 1" sample.. I'm assuming you have a heat gun at home so that you can put it on..
sorry for going OT guys.. its elf's fault!
Alternative material for damping amit_sound In-Car Entertainment 183 30th April 2016 12:36
Sound Proofing material for car ezee Modifications & Accessories 20 13th January 2010 16:17
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
sound proofing material query makanaka In-Car Entertainment 3 11th August 2008 11:53
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
