Old 22nd May 2007, 13:56   #241
Vid6639's Avatar
Thanked: 19,377 Times
moral, your close up pics are out of focus. I noticed the same in your fiat report. Which cam you use? also is macro enabled?
Old 22nd May 2007, 13:56   #242
srishiva's Avatar
Thanked: 823 Times
So far American Dynamic (available at Hot Tracks) and Wurth on JC Road are listed in this thread. Any other damping products and their availability in Bangalore. Please list the ones you know. Would be useful for DIY.
srishiva is offline   Reply With Quote
Old 22nd May 2007, 13:58   #243
Rtech's Avatar
Thanked: 212 Times
Originally Posted by Sam Kapasi View Post
Have received 36 rolls of AD damping in my office today. Am handing over 24 rolls to Navin.
And 4 to me. Don't forget.
Old 22nd May 2007, 13:59   #244
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by Technocrat View Post
err kiran from what I have read so far, isnt this too thick ??
err, its kiran who's a bit thick here.
This damping is 2.6mm thick. The other variant is 1.7mm thick, same as Dynamat Xtreme, if that is any benchmark for comparison thickness-wise. 7 mm would be damn thick, but unlike rubber sheets which arent exactly malleable, this will still spread and occupy the space available. Very flexible and high density material. Perfectly visco-elastic. Another material which I'm getting a sample shipment of very soon is exactly Dynamat Xtreme in terms of composition. That is about 1mm thick, about that of Dynamat original, but with Alu foil and self adhesive too. About Rs. 150 per sq. ft, I'm hoping.
Old 22nd May 2007, 14:00   #245
BUSA's Avatar
There are many other damping products like Fonomat(used by Hydra in his Palio) & Original Dynamat, Dynamat Extreme, etc. All are avilable with professional installers AFAIK.
Old 22nd May 2007, 14:08   #246
moralfibre's Avatar
Thanked: 6,144 Times
Help me please. It is a Canon Powershot A95. I dont know A.b.c's about setting it up.
I need new eyes and better senses :(. So does my camera!
Btw whats the name of this product. I forgot to click the one which was black in colour. Can you shed more light on it?
Old 22nd May 2007, 14:14   #247
Vid6639's Avatar
It should come out ok in auto mode. Also, are you doing the half press for the focus then pressing it further down fully to snap.
And camera shake steady hands as much as possible.
Camera is good dude. play around with it.
cheers
sorry for OT.
Old 22nd May 2007, 14:16   #248
moralfibre's Avatar
Exactly what I do. Will play around with it to get it better next time . Thanks for the heads up.
Old 22nd May 2007, 19:22   #249
navin's Avatar
Thanked: 3,883 Times
Wed-Thu wifey's car gets damped. Fri my car gets damped (only the front door were damped earlier. Mon-Tues or there abouts Mom's car will get ICEd and damped (if only I can find a good cheap 5/6ch. amp, budget 20K -see marketplace).
Damping: Stage 1
Front Doors: 3 sheets
Under carpet: 2 Sheets
Trunk: 2 Sheets
Rear Doors:2 sheets
3 cars = 27 sheets but my car alreadyhas front doors done so 3 sheets less = 24 sheets.
Stage 2: If required Viper's boys will be coraled into doing underbody damping.
navin is online now   Reply With Quote
Old 23rd May 2007, 12:55   #250
Mad Monkey's Avatar
Thanked: 308 Times
Damping: Stage 1
Trunk: 2 Sheets
Rear Doors:2 sheets
me want a peek when they do ye shkoda !! ???
Mad Monkey is offline   Reply With Quote
Old 23rd May 2007, 12:59   #251
navin's Avatar
Any time mate. They are not doing much just simple stuff. You've done a lot more for your car.
Old 23rd May 2007, 13:04   #252
iraghava's Avatar
Thanked: 153 Times
You mind posting some pics of YOUR Skoda? With all the new Uffers, Damping & Amplifires going in I think it's time you posted some pics of it.
P.S. What happened to the machine?
Old 23rd May 2007, 13:33   #253
navin's Avatar
B&T posted a pic of the Sub. That was a little unusual given the compact self made FRP box.
The rest is quite a regular setup. Gunbir and B&T posts much better pics here. My ICE needs are dictated by the use of the Skoda to carry 2 30" bags + atleast 1 carry on to/from airports.
What I have:
Blau 275 driving Infinty 12" sub
Blau 450 driving 2 6" Blau midbasses (80Hz - 250Hz) in rear as I noticed that the rear speakers were too small to even do a decent job of the midbass.
Infintiy 340 driving front and rear.
Options: replace 450 and 275 with a single amp that can deliver 100 x 2 + 250 x 1
Old 24th May 2007, 03:47   #254
Thanked: 294 Times
What I have:
Navin Ji I am bit confused here....you are driving two set of speakers in the back......6 inch midbass and which speakers.....
we need some pics so that we can see the install......
that amp would be the 75.4.......
Old 24th May 2007, 10:39   #255
navin's Avatar
Originally Posted by low_bass_makker View Post
Navin Ji I am bit confused here........
repeat...
Blau 275 driving Infinty 12" sub (B&T posted a pic of this on thei forum)
Front Speakers are ScanSpeak woofers (18W) mated to Blau Silk domes from their 172. Rear are Vifa 13cm midbasses (P13W) mated to Vifa tweeters (D26NC) but using the Velocity tweeter's mesh. I got the tweeters for cheap as someone had friend one woofer and was discarding the set. I even managed to salvage the ferrite cores from the XO of the Velocity and use them to build an XO for my wifes car.
Crossovers are my own. I use Solen caps with a MIT 1uf bypas cap for the front, CTR poly caps for the rear and ferrite core inductors (air core makes it too big), XOs were built using LSP Cad.
I'd have to find all my papers to knwo the exact model numbers of the drivers but since they are really all out of production (the D26NC was the last to be in production) it really does not matter. IN fact Vifa is not v-linein the Peerless product range.
it gets complicated right? Now you know why i dont talk about what I use. Few care, and fewer understand and a few even think of me as the ultimate scavenger/cheapskate.
Alternative material for damping amit_sound In-Car Entertainment 183 30th April 2016 12:36
Sound Proofing material for car ezee Modifications & Accessories 20 13th January 2010 16:17
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
sound proofing material query makanaka In-Car Entertainment 3 11th August 2008 11:53
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
