Old 22nd August 2007, 17:43   #316
Sam Kapasi's Avatar
Thanked: 1,472 Times
Default A quick YetiGuide® -
Dampening:
There are 2 meaning to dampen.
1) To wet something : I unzipped my pants and dampened the grass below with all my strength.
2) To reduce enthusiasm: Watching me pee so much did not dampen her spirits at all!
Damping:
Damping is the technical term for the action of reducing vibrations in any object.
The material used for reducing metallic vibrations in car panels and doors caused when speakers play is called damping.
You get damping sheets (or mats if you will) and liquid (spray or inject or apply on with a brush) damping.
Old 22nd August 2007, 17:52   #317
jkdas's Avatar
Thanked: 1,435 Times
Originally Posted by Sam Kapasi View Post
Dampening:
Damping:
that was great!
Old 22nd August 2007, 18:03   #318
nura's Avatar
@Sam - Thought so too. Was surprised to find that most car audio sites used the words "dampening" & "sound-deadening".
nura is offline   Reply With Quote
Old 22nd August 2007, 18:04   #319
rocksterraghu's Avatar
Thanked: 88 Times
So, do you want a damping mat or a dampening mat (Read the first meaning and example very carefully)?
Old 22nd August 2007, 18:07   #320
Sam Kapasi's Avatar
Sound deadening is OK.
Dampening is not.
Old 22nd August 2007, 19:46   #321
kpzen's Avatar
Thanked: 1,636 Times
Originally Posted by chiragh_bir View Post
Guys I need dampening mat for mah getz.. Please tell give me details of the person in delhi who sells them..
Chiragh
Dampening:
2) To reduce enthusiasm: [i]Watching me pee so much did not dampen her spirits at all!
Originally Posted by simply_sunny001 View Post
you can contact LBM/Gunbir for that.
Sunny I dont think LBM or Gunnu paji can help anyone in dampening.
Old 22nd August 2007, 20:31   #322
aah78's Avatar
Thanked: 1,724 Times
Exclamation damping
Threads concerned with Damping Accessories and Sound Deadening Materials merged into one and renamed.
aah78 is offline   Reply With Quote
Old 22nd August 2007, 21:03   #323
Thanked: 43 Times
Perhaps he does mean dampening as in "moistening". have you tried a humidifier?
filcord is offline   Reply With Quote
Old 23rd August 2007, 15:50   #324
chiragh_bir's Avatar
Thanked: 69 Times
guys i wrote is by mistake.. i mean damping
plz reply guys where can i find damping mat!!!!!!
Last edited by aah78 : 25th August 2007 at 00:38. Reason: posts merged. you have time to edit and add material to your post.
chiragh_bir is offline   Reply With Quote
Old 24th August 2007, 00:04   #325
nura's Avatar
Originally Posted by shrivz View Post
Its been sometime now since i've installed the sandwitch..overall, its a successful DIY install...
@Shrivz - Thanks for your replies to my pms. Thought I should take this onto the forum, in case someone else is interested.
I found a tyre repair shopowner who showed me the rubber roll you have described. He called it kachha (raw) rubber. One surface was sticky, the other covered with plastic film. I nearly shouted "Eureka". But my joy was shortlived. The shopowner showed me that this sticky surface could only be stuck if folded back on itself. It refused to stick to normal rubber, metal or anything else around.
Did you use this for damping? How on earth did you get it to stick to the door panel - by using Dendrite? Must have been awfully hard work.
Old 24th August 2007, 10:04   #326
shrivz's Avatar
Thanked: 92 Times
@nura: the rubber sheets I used had plastic film (with a scaly texture) on both sides. When peeled off, it reveals the adhesive and can be stuck onto normal rubber, metal et. all.
cheers!
shrivz is offline   Reply With Quote
Old 24th August 2007, 11:50   #327
mobike008's Avatar
Thanked: 8,231 Times
Guys, my rear number plate makes a helluva noise when i turn up the volume anything above 10. Other than this thak thak noise from number plate, there is hardly any noise or vibration.
my question is what material should be used to make the number plate stick to the car body so firmly that if the woofer is blasting it shouldnt budge?
Old 24th August 2007, 12:12   #328
moralfibre's Avatar
Thanked: 6,460 Times
Add a piece of foam behind the number plate to stop vibrations. You don't need damping there.
Old 24th August 2007, 13:45   #329
mobike008's Avatar
Thanks but how exactly do i apply the foam? can you explain?
Old 24th August 2007, 13:48   #330
kpzen's Avatar
Wont the double side sticker do the same job too?
Alternative material for damping amit_sound In-Car Entertainment 183 30th April 2016 12:36
Sound Proofing material for car ezee Modifications & Accessories 20 13th January 2010 16:17
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
sound proofing material query makanaka In-Car Entertainment 3 11th August 2008 11:53
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
