Old 24th August 2007, 13:51   #331
mobike008's Avatar
Thanked: 8,249 Times
Wont the double side sticker do the same job too?
I tried the double side sticker, its good for a day or two. But, continously playing music makes it get unstuck
Old 24th August 2007, 17:18   #332
Sam Kapasi's Avatar
Thanked: 1,473 Times
Use good quality foam double sided tape. Unscrew the number plate, apply the tape and stick it and then put the screws on.
Old 24th August 2007, 17:39   #333
nura's Avatar
Originally Posted by shrivz View Post
@nura: the rubber sheets I used had plastic film (with a scaly texture) on both sides. When peeled off, it reveals the adhesive and can be stuck onto normal rubber, metal et. all.
cheers!
Thanks Shrivz. I guess I haven't found the right rubber sheet yet.
nura is offline   Reply With Quote
Old 24th August 2007, 17:45   #334
panky12345's Avatar
Thanked: 147 Times
If you dont want to use double tape, soak the foam in ELFY and screw the # plate back. U'll never have a problem again, either with vibrations and/or # plate.
panky12345 is online now   Reply With Quote
Old 24th August 2007, 21:16   #335
Sam Kapasi's Avatar
Of course when you change your number plate, the plate will come off with the paint on your car, lol.
Old 24th August 2007, 21:57   #336
clipto333's Avatar
i had the same problem in my accent. i drilled two more holes at the bottom of the license plate. bought some rubber thingys used in scooters rear foot peg. i used the rubber bush(?) in between the plate and the metal. the rubber thingy had a hole to pass a screw.
result - well the license plate vibration was reduced by 90%. seriously. then i damped the boot and now there is no vibration at all.
hope this helps
cheers
clip
clipto333 is offline   Reply With Quote
Old 25th August 2007, 00:32   #337
akbaree's Avatar
Thanked: 50 Times
Dampening:
Damping:
Damping is the technical term for the action of reducing vibrations in any object.
The material used for reducing metallic vibrations in car panels and doors caused when speakers play is called damping.
You get damping sheets (or mats if you will) and liquid (spray or inject or apply on with a brush) damping.
I want to damp my car. Which is a better option? sheets or liquid? Does damping my car wil spoil it
akbaree is offline   Reply With Quote
Old 25th August 2007, 10:29   #338
Thanked: 43 Times
Don't use foam. It will absorb water and you'll have a rust problem. Use any material that is non-absorbent.
filcord is offline   Reply With Quote
Old 25th August 2007, 10:32   #339
navin's Avatar
Thanked: 4,266 Times
Liquid should be used for hard to reach areas (underbody, A-B-C Pillars etc...) but in genergal (doors, trunk, under carpet, etc...) sheets is easier to apply.
Old 25th August 2007, 13:23   #340
mobike008's Avatar
Thanks Sam, Panky and Clip. I will get it done the way you folks suggested and see how it comes out
Old 3rd September 2007, 20:53   #341
shajufx's Avatar
Thanked: 489 Times
Anyone can give some contact numbers in Bangalore to get a proper dampening done ? Searched online but could not find anything worth. Reply greatly appreciated !
shajufx is offline   Reply With Quote
Old 4th September 2007, 12:49   #342
panky12345's Avatar
Thanked: 147 Times
i think SAM sourced american acoustics (or american dynamics) damping sheets from bangy. Search the threads and am sure u'll find a reference.
Old 4th September 2007, 13:15   #343
DerAlte's Avatar
Thanked: 2,879 Times
American Dynamics it is. Yeah, I had bought some from the same place: Hot Tracks (Residency Road, right after Bangalore Club on the left after the flyover ends).
Not sure if he has anyone who can apply it, since @shajufx wants the whole job done, I think, apart from sourcing the sheets.
Old 4th September 2007, 13:52   #344
panky12345's Avatar
Thanked: 147 Times
DerAlte: Pasting is no rocket science naa yaar, he can go through a couple of Gunbir's threads/google and ask his local installer to do the installation. (unless he opts for liquid damping etc)
Old 5th September 2007, 14:25   #345
shajufx's Avatar
Thanked: 489 Times
I have asked for quotes from few shops, not yet got a finalised pricing. American dynamics is supposed to be costlier than Dynamat, Wuerth and Rockford etc. Most of them are available in Bangalore. Carshringar promised to do all the work but not yet clear with the pricing part. Since every customer differ in chosing the size of area to be covered, there is no uniformity in pricing.
I found amazon.com is offering the best prices (US$ 70 - 115 for dynamat extreme) but sadly they dont ship to India. I am sure this pricing is far below a shop can quote here. Searching for any other means to get it by courier for a cheaper price. If the installation is a DIY thing, I dont mind trying it, atleast its better than doing sunfilm installation. US$ 115 is a price on amazon for 36 sq.ft.( 9 sheets of 18"X32" ) which is enough for a complete car installation.
Alternative material for damping amit_sound In-Car Entertainment 183 30th April 2016 12:36
Sound Proofing material for car ezee Modifications & Accessories 20 13th January 2010 16:17
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
sound proofing material query makanaka In-Car Entertainment 3 11th August 2008 11:53
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
