Old 29th November 2007, 15:03   #436
navin's Avatar
Thanked: 4,282 Times
Originally Posted by johy View Post
It would, vebmetal. I have been looking high and low for Wuerth, but no luck. So got to buy whatever is available. .
Noise Kill might be available. PM B&T for details.
Old 29th November 2007, 17:29   #437
adityamunshi's Avatar
Hey gurus,
Where would i get some common form sheet for damping ? Ive absolutely no idea where to look for it.
adityamunshi is offline   Reply With Quote
Old 29th November 2007, 22:56   #438
navin's Avatar
Originally Posted by adityamunshi View Post
Hey gurus,
if you mean foam dont use foam. it will deteriorate and become dust. use butyl rubber.
Old 29th November 2007, 23:22   #439
nura's Avatar
@Johy - Have you contacted the Wuerth office in Kolkata? They had given me a quotation when I had spoken to them a few months ago. This doesn't necessarily mean that they have the stuff in stock, though.
nura is offline   Reply With Quote
Old 30th November 2007, 07:37   #440
@navinji
I dont know if its foam or not. Its the material used in this setup. http://www.team-bhp.com/forum/sound-...e-pioneer.html
Old 30th November 2007, 08:15   #441
johy's Avatar
Thanked: 373 Times
Infractions: 0/1 (5)
Hi Nura,
I got the address from an earlier post from Navinji with details. The number was "temporary out of order" yesterday. Will try again today.
Bettina Würth Auto India Pvt Ltd
4. Hoboken Depot, Jain Kunj, Kolkata 700 088
+91 33 24 392 458 +91 33 24 394 152
e-Mail: sales@wuerth.co.in
I have written to them, but no reply on that. It would be really nice if I could get the stuff. Also PMed B&T - hoping for the best.
johy is offline   Reply With Quote
Old 30th November 2007, 10:08   #442
ashthedivx's Avatar
Thanked: 22 Times
Originally Posted by shrivz View Post
you can buy closed cell foam, also known as cross-link foam.
Gymnasiums use floor mats for exercising which are made of pretty much the same material, try sourcing them and the applying adhesive on one side, or you might be lucky to find one side adhesive foam readily available!
this will serve your purpose and will be relatively cheap, some 200 buks for a 3' x 4' sheet.
Does these sheets can be really considered as damping materials, Also... as Optra has enough of Damping in Doors with some thick stuff which i gotta see when the door trims were opened for some lock problem... I need to do damp the Boot which give enough of sound with a small increase in BASS...
Also, is it something DIY or you really need some specialized mechanic to get it fixed ?
Old 30th November 2007, 11:39   #443
johy's Avatar
Thanked: 373 Times
Default Update: Getting Wurth done in Siliguri
Eureka! I am getting Wurth in Siliguri itself (special thanks to Nura - I had almost decided on D Extreme). They apparently have 2 salesmen here and they are getting the stuff for 4500/- (4 doors + hatch door) + 500 labor charges.
I sure am glad - some damping better than nothing.
Will post pictures when done.
Old 30th November 2007, 13:21   #444
nura's Avatar
Congratulations, Johy. Remember, these are bitumen-based sheets & need to be warmed well before being stuck.
Old 3rd December 2007, 09:31   #445
ashthedivx's Avatar
Thanked: 22 Times
Thumbs up
Anyone would throw light on the same ??
Old 3rd December 2007, 20:31   #446
guys, ive got a civic, i want to get some damping done on the front doors,parcel tray and boot. what is the most VFM option for me and how much would i need and cost.
sanchits is offline   Reply With Quote
Old 3rd December 2007, 22:31   #447
navin's Avatar
This thread is getting a bit out of control. To put the whole question of damping in perpective let me sumarise and say this.
1. there are a host of damping materials out there. Wurth, Fonomat, Dynamat, American Dynamics, Noise kill, E-Dead, etc...
2. damping materials made of butyl rubber are better than those made from asphalt which is a low cost alternate.
3. foam (closed cell) will not absorb water but being foam will deteriorate over time.
4. open cell foam should be avoided
5. damping material is sold in sheets ranging from 1ft x 1ft to 1m x 1m. you need about 10 m2 to damp an entire midsized sedan (all doors, fire wall, trunk, under carpet). Cost to do this can range from Rs. 8,000 to 20,000 and more.
6. It is impossible to ascertain which selection of damping brands are available where. It is recomended that users do local homework from atleast 3-4 reputed dealers and use the above guidelines to make educated decisions.
7. It would be much appreciated if users could post there findings here using the format below. Maybe by doing this we will hae a large enough database that other members will find worth while.
Car damped:
Panels Damped:
Brand of Damping used:
Qty of Damping used:
Cost of Damping:
navin is offline   (2) Thanks Reply With Quote
Old 4th December 2007, 11:26   #448
suren181's Avatar
The following is for a very basic, low cost damping for my Santro. The problem area basically was my boot lid which I had targeted (earlier, the number plate was removed and in place had a Sticker stuck on which was made ditto as per the number plate specs.)
Car damped: Santro Zip plus 2002 LS
Panels Damped: Front Doors and Boot Lid
Brand of Damping used: Accumat a Scosche Brand
Qty of Damping used: 5 nos. 1' x 1' Mats. 1 Mat each for the Front doors and 3 Mats for the Boot Lid
Cost of Damping: Rs. 3,000/-
Time taken: Around 30 minutes
DIY / Installer: Done by Moto Axis (Installer), Secunderabad.
suren181 is offline   Reply With Quote
Old 4th December 2007, 13:22   #449
navin's Avatar
Originally Posted by suren181 View Post
The following is for a very basic, low cost damping for my Santro. .
thank you. thanks a lot.
Old 4th December 2007, 13:24   #450
Bass&Trouble's Avatar
Thanked: 71 Times
Is that sarcasm? @ 600 bucks a foot?
Alternative material for damping amit_sound In-Car Entertainment 183 30th April 2016 12:36
Sound Proofing material for car ezee Modifications & Accessories 20 13th January 2010 16:17
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
sound proofing material query makanaka In-Car Entertainment 3 11th August 2008 11:53
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
