Old 10th May 2008, 04:37   #511
finally, a need for damping has arrived, after 4 months of my ICE install. i have started hearing vibrating sounds from civic from the rear parcel shelf and the front co-passenger door. need help, i see Noisekill to be the best option.
i got my ICE installed from DRIVEN, east of kailash. i think they have noisekill. what is the cost like and how much do you think i'll need to damp the front 2 doors and rear parcel shelf of civic. i don't want to go overboard with it, just to reduce those annoying rattles.
sanchits is offline   Reply With Quote
Old 10th May 2008, 09:21   #512
Noisekill retails for 150/sq ft.
Mind you if your only objective is to get rid of rattles then you can get away with damping just a few bits where the plastic trim/plank is causing the sound. Even foam or other jugaad methods will work.
Old 11th May 2008, 19:56   #513
thanks... souljah for the suggestions. i am not getting enough mid bass from the front compos, so as suggested by many t-bhpians, i am planning to get damping done on the front doors to get better sound as the doors act as a enclosure for the speakers, right. due to the sub in the boot, the rear parcel shelf vibrates like hell, so want to get it damped too.
i want to know how much noisekill would i require for the front doors+rear parcel shelf.
i am new to this stuff, so would damping really help with vibrations and rattles.
Old 12th May 2008, 20:42   #514
Maybe you can check with B&T ? Id say get atleast 30 sq ft to start with.
For the swift I used about 50sq ft, it was worth it. Though I could definitely use another 50sq ft in there easily
Old 14th May 2008, 18:16   #515
guys, got a quote of 3k for the front doors and 2K for the rear parcel shelf, for dynamat. i got this quote from Joy car center in Khan Mkt, delhi. Is it a good deal or should i go for noisekill.
Old 14th May 2008, 18:32   #516
Bass&Trouble's Avatar
Thanked: 64 Times
5k would mean approx 33 sq. ft. of Noise Kill.
Dynamat Xtreme Bulk Pack which is 36 sq. ft. is for Rs. 18000/-
How much Dynamat and which one (original/ xtreme) are you getting?
Old 14th May 2008, 18:39   #517
simply_sunny001's Avatar
Thanked: 15 Times
looks like sachits got the quote for chinese Dynamat.
@sanchits
if you getting Dynamat Extreme for your civic then its ok as other Dynamat variants are not much effective compared to the cost.
In that case go to Noisekill or Fonomat or Wurth all of them are VFM and serve the purpose well.
simply_sunny001 is offline   Reply With Quote
Old 20th May 2008, 23:04   #518
Default dymanat extreme 20sq
guys, got my car tints from elegance in gurgaon. they also had dynamat extreme. so got a quote of genuine dynamat extreme 20sqft pack for 9k including installation. do you think its worthwile spending that much for dynamat or should i go for noisekill, i mean is it as good. for noisekill i dont want to spend more than 5k. cause civic is well built, i just want to cut out the rattles and vibrations. so, would 5k be enough for noisekill or is it worth spending 9k for dynamat.
Old 20th May 2008, 23:54   #519
Akshay1234's Avatar
Thanked: 5,338 Times
in 3k you would get 20 sq ft of noisekill.
Old 21st May 2008, 11:41   #520
nickoo's Avatar
go for noise kill...as stated...150/sq ft...and real VFM.....dynamat is pretty expensive affair!!
nickoo is offline   Reply With Quote
Old 21st May 2008, 19:20   #521
Thanked: 76 Times
Default is NoiseKill the best budget recomendation ?
At 150/sq.ft is NoiseKill the best option ( in terms of budget v/s performance )
How much sq.ft would be required in an Innova and is it only to be used in the 4 doors ?
pinnacle is offline   Reply With Quote
Old 23rd May 2008, 10:54   #522
arpandiv's Avatar
Thanked: 27 Times
@Navin: Heatlon (the foam lookalike) is to be put below the bonnet right?
arpandiv is offline   Reply With Quote
Old 1st June 2008, 22:52   #523
shuvc's Avatar
Thanked: 282 Times
Query - Is it possible to remove damping material like NoiseKill? Can it be scraped off or would any cleaning solution work?
Old 11th June 2008, 00:36   #524
AbhiJ's Avatar
Thanked: 322 Times
Default Sound Dampening/Deadening...
Hi Guys...
This is a question regarding products like Dynamat.
Does Dynamat have any competition in India, possibly something which is reasonably priced?
Has this product been developed in India yet?
Thanks in advance
Moderator's note: Thread merged with existing topic. Please search before posting new threads.
AbhiJ is offline   Reply With Quote
Old 11th June 2008, 13:01   #525
whatcanthisbe's Avatar
Hi guys on speeds over 120ish in my accent there is considerable (for my tastes) road noise inside the cabin what can i do to reduce that (other than reduce the speed or change the car)
whatcanthisbe is offline   Reply With Quote
Alternative material for damping amit_sound In-Car Entertainment 183 30th April 2016 12:36
Sound Proofing material for car ezee Modifications & Accessories 20 13th January 2010 16:17
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
sound proofing material query makanaka In-Car Entertainment 3 11th August 2008 11:53
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
