Old 28th January 2012, 12:48   #916
DerAlte's Avatar
Thanked: 2,877 Times
Default Re: The Damping Material and Sound Deadener Thread
American Damping or American Dynamics? If the latter, you can ask at the accessories shop on Residency Road just after Bangalore Club on the left, before the pedestrian overbridge. I had bought some from him 3-4 years back.
Old 30th January 2012, 17:45   #917
Thanked: 9 Times
Does anyone has used/experienced this product?
RAAMmat BXT II - RAAMaudio Inc.
This one has high rating at
Adding soundproofing to your car to reduce noise
I would like to know a word or two before I purchase it from
eBay - The UK's Online Marketplace
I plan to use these on the floors, roof and the firewall, once the wurth underseal(bitumen based) is done and the damping and deadening sheets I purchased from ebay is delivered and the doors are done for good.
Wurth underseal will be done tomorrow for 2.6k, the korean sheets cost me around 5.5k(~ 17 sq ft - 9.5 of polyether based sound deadening and 7.5 of butyl-aluminum damping) and the above RAAMmat(40 sqfeet) would cost me around 10K including shipping, which sounds like 18K in all, for the whole car.
Does it sound like good idea or am i going over the top?
glidealong is offline   Reply With Quote
Old 30th January 2012, 18:13   #918
DerAlte's Avatar
Though there is no end to the quest of damping, usually the point of diminishing returns is somewhere in the INR5-10K band. That is, less than 5K doesn't get you enough; and more than 10K does not necessarily get you more and more.
The "INR5-10K" assumes off-the-shelf Dynamat/Dynamat Extreme type of damping sheets pasted in strategic areas, augmented by closed-cell foam / cotton-waste stuffing in some areas.
DerAlte is offline   (1) Thanks Reply With Quote
Old 30th January 2012, 18:51   #919
adityamunshi's Avatar
How does cotton waste help? Where would it be available ?
adityamunshi is offline   Reply With Quote
Old 30th January 2012, 19:13   #920
Thanked: 162 Times
Any information / feedback about damping sheets by American Damping ? I am not able to find any information anywhere on this.
Accessories dealer says that this is available in two types - one that does not need heating (non-adhesive side is metallic color), and the other that needs heating (is black/dark color). Sheets are 1.5mm thick.
Condor Sir - Satya of Evo damped all the doors in my Swift using this brand of damping sheets. I have no idea whether heating is required or not, as i wasnt present when it was done, but they have made quite a difference. No vibration or rattles. Also the outside noise has reduced to quite an extent !
nirmaljusdoit is offline   Reply With Quote
Old 30th January 2012, 22:07   #921
condor's Avatar
Thanked: 4,412 Times
Default Doors & Firewall are the key
Just coming to the closing stages of my DIY damping experiments. Summary:
1. It will help to damp the doors (has already been told to us by the guru's -Navin / DerAlte) - and firewall.
2. For the firewall, get hold of a good mechanic who can open the dash. Apply the damping sheets as much as possible. Get the thicker sheets like Dynamat.
3. Dont worry about the floors- there is already some damping there, and I dont think it will make more difference than what 1 & 2 will.
4. In case there is some lining on the firewall already - unless it is damping sheets, open this lining, apply damping sheets & re-apply the OE lining.
5. You will also get suggestions to damp the pillars & roof. You can, at least the pillars. But inside of the roof I have not tried & you will need someone well versed in this.
6. If you want to try a little more, then you can work on the rear wheel arches - from inside the cabin.
@Nirmal, Satya had quoted the same brand to me. But I would have thought you would do it yourself ! When I can, it should have been much easier for you.
Last edited by Amartya : 30th January 2012 at 22:47. Reason: Edited based on RP. Thanks :).
Old 30th January 2012, 23:43   #922
Thanked: 162 Times
There was also other work to be done like changing the wiring, changing the comps, moving front comps to rear etc so got the whole thing done by Satya as a project
Also was not sure about where to damp, how to damp, how much to apply etc, so wanted it best left to an expert to handle. Job took a whole day & i just came back & collected the car.
Great job done by Satya, haven't faced any issues till date !
Am thinking of now damping the floor, what do you recommend - Underbody coating by 3M along with damping sheets ?
Old 30th January 2012, 23:49   #923
condor's Avatar
Default OE Damping of floor
@Nirmal, if you are going to damp the floor, then try 3M / Wuerth under-body - as pointed out in recent posts. I dont think applying sheets inside will help that much. Any way, the manufacturer would have already put in at least some amount of sheet there (from inside).
Here's a pic of the damping by Ford, in the Ikon. Section is the left passenger (rear seat). The sheet is in the lower section of the pic. The black part on the left is a fabric sticker. The middle one-third shows the bare-metal mid-floor ridge, which is not covered.
Old 31st January 2012, 07:59   #924
condor's Avatar
@Aditya, check this:
http://www.team-bhp.com/forum/diy-do...ml#post1482003 (DIY : Damping the swift with yoga mats and making it rattle free)
Cotton waste is available in most auto spares shops / lube oil stores.
American Damping.
We opened up the boot lid's panel and filled up every nook and cranny that we could reach with the cotton waste. 2 hrs and voila we had a boot lid which was heavier and no rattles from the back now.
The darn thingy ate up close to 6 kgs easily
Riju, any problems with rusting here ? The cotton waste would soak water (possible during washing at servicing time). And nooks and crannies always take more time to dry.
Old 31st January 2012, 14:55   #925
DerAlte's Avatar
@condor-bhai, where did you expect the water to enter from? The only suspect side is the door pad side, which doesn't see a pressure wash ever. All the other ingresses have a rubber grommets minimizing water entry. If water does get in, you will start to get that typical 'musty' smell sooner or later. CC foam is a better, if costlier, alternative.
Old 31st January 2012, 17:02   #926
condor's Avatar
Sir-ji, sorry - mixed it up with the bonnet. My bad.
Old 31st January 2012, 21:24   #927
condor's Avatar
Navin @ DerAlte, question reg damping sheets vs Yogamat.
from what I have seen, Damping sheet can be used only on metal, and Yoga mat can be used on both metal & door pads/panels.
What is the difference if we used Yoga mat on metal ? Will it damp as well /comparably as damping sheet on metal ?
Is Yoga mat CC or OC ?
Old 1st February 2012, 10:35   #928
nvc_4125's Avatar
hi,
I m from Surat and ask here so many car accessory shop about dumping sheet but can't get any thing.
Finally i get dumping sheet from Rockford which is priced 1000 Rs per 1.5 sq.f. is it priced ok.
i search on net and found this from ebay.
SilverStone 21-Inch x 15-Inch 4mm Thick 2-Piece Sound Dampening Acoustic EP0M S | eBay
is it ok to go with this one.
nvc_4125 is offline   Reply With Quote
Old 1st February 2012, 10:55   #929
DerAlte's Avatar
Originally Posted by nvc_4125 View Post
... I m from Surat and ask here so many car accessory shop about dumping sheet but can't get any thing. ...
Dumping sheet you can get from any supermarket (4 rolls per pack)! No, seriously, that foam sheet on eBay is not meant for use in a car - 'yoga mats' will be better since they are higher density. Of course, you will need to stick them with 'rubber solution' (like Fevicol SR) - there is a thread in the DIY section, I think, which has enough info on how to do it.
The Rockford one is more conventional, and price is reasonable.
Check with @vigsom (PM him) - he is in Surat and will be able to guide you in damping your car.
Old 1st February 2012, 20:56   #930
condor's Avatar
@DerAlte & Navin, one more question:
I have seen that either:
Damping sheets are stuck on the inner metal sheet of the door (the surface facing the door pad) - OR -
Yoga mat is stuck on the inner-side of the door pad.
Which is the best location for the sheets (both damping sheet & yoga mat).
Why dont installers apply the damping sheets on the inner surface of the outer metal sheet ? (I know it is hard to access). The damping at the factory is done on this section - inner surface of the outer sheet .. so why dont installers follow this ? Is it because of advantages / disadvantages - or the time it takes to apply the sheet in this area ?
Alternative material for damping amit_sound In-Car Entertainment 183 30th April 2016 12:36
Sound Proofing material for car ezee Modifications & Accessories 20 13th January 2010 16:17
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
sound proofing material query makanaka In-Car Entertainment 3 11th August 2008 11:53
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
