Old 14th March 2012, 18:37   #961
greenhorn's Avatar
Thanked: 1,508 Times
Default Re: Sound Absorbing Materials :what are the options?
I'd noticed some stuff under the hood and below my carpeting. most of it looked tired. Was thinking about upgrading/swapping them at first. Any ideas for them?
Old 14th March 2012, 22:09   #962
condor's Avatar
Thanked: 4,848 Times
@Greenhorn, my experience - pull out the dash, damping sheets on teh firewall. Damp the inside of the doors too. You'll be good to go.
Check out the sound damping thread. Lots of info there.
Old 16th March 2012, 16:42   #963
sunster's Avatar
Thanked: 21 Times
Default Re: The Damping Material and Sound Deadener Thread
Hi all,
I'm expecting my new 2012 Honda city E-MT any day now. Just wanted some advice since I intend to do some "dynamatting". Will it enhance the sound and reduce NVH drastically. Please advice.
Sunny
sunster is offline   Reply With Quote
Old 16th March 2012, 17:14   #964
Safari_Beast's Avatar
Thanked: 197 Times
Hello Sunny
With stock speakers in Honda , there is no need for damping . I have sat in my friends honda city and didnt find any need for damping . If you happen to upgrade your speakers , then damping is required . Nobody on teambhp ever complained about NVH inside cabin . So go ahead and get your honda , inveest in damping when you upgrade your ICE .
Originally Posted by sunster View Post
Hi all,
Sunny
Safari_Beast is online now   (1) Thanks Reply With Quote
Old 16th March 2012, 17:17   #965
sunster's Avatar
Thanked: 21 Times
Thanks Safari Beast. Sorry I did not mention. Im going to totally change the ICE with a Pioneer HU, Focal Components, JBL Touring series mono amp, a 4 channel amp (still undecided) and a Kicker enclosure sub.
Old 16th March 2012, 17:23   #966
infotech58's Avatar
Thanked: 217 Times
with the given choice of equipment, invest a little in damping as well; you may go with the new line of NoiseKill which is almost as good as dynamat (i've NoiseKill in my City and Dynamat in my Lancer); it would certainly make a lot of difference in the way your ICE would sound. damp atleast front doors, parcel tray, and bootlid completely.
infotech58 is offline   (1) Thanks Reply With Quote
Old 16th March 2012, 17:27   #967
sunster's Avatar
Thanked: 21 Times
Thanks a lot infotech,
Now this is something to look forward to. BTW, my car accessories guy at Borivli does not stock Noisekill. Do you know of a good competent place to get all this done from preferably close to Borivli (western suburbs).
SUNNY
Old 14th April 2012, 04:22   #968
mjumrani's Avatar
Thanked: 584 Times
Hey guys
So I got all the doors in civic dampened but I found a new issue.
The door handle (interior) assembly rattles on songs with high bass.
I got to this conclusion because as soon as that sound came on the driver's end and I held the door handle by taking it out a bit, the rattling stopped for a while and started up again (eventually)
Any idea how this could be fixed?
mjumrani is offline   Reply With Quote
Old 14th April 2012, 06:52   #969
Thanked: 121 Times
Originally Posted by greenhorn View Post
We all know about DynaMat and all those sheets of damping material, But these are essentially damping material - they are rather heavy sheets which are stuck to the metal to prevent vibration. But I'm looking towards options for noise absorbing material .
look at www.armacell.in Around three years back, I did use their material to to damp the all the doors, hatch and boot of my swift vxi, I was very much satisfied with the result. They are available in 1mt x 1mt size, needs to by atleast 10 sheets. (but managed to get 6 sheets) I remember it costed me around Rs.140+ per sq.ft. in 2008-09
Now I am considering to get the same thing done for my new swift ZDI
manjubp is offline   Reply With Quote
Old 14th April 2012, 07:51   #970
K a s h's Avatar
Thanked: 31 Times
It seems to be costly. Are your sure its Rs 140 per sq.ft? It works out to Rs. 1500 per sheet!
K a s h is offline   Reply With Quote
Old 14th April 2012, 09:17   #971
try by re-fitting the door trim, most probably the spring in handle assembly has not been fitted properly.
Originally Posted by mjumrani View Post
Hey guys
dinitrol is offline   Reply With Quote
Old 14th April 2012, 09:27   #972
navin's Avatar
Thanked: 4,265 Times
The door handle (interior) assembly rattles on songs with high bass...Any idea how this could be fixed?
Yes the door trim might be loose. Ask your dealer to open the door panel and tighten the fit. Then add damping so that the vibrations dont loosen the trim over time.
Old 14th April 2012, 10:25   #973
condor's Avatar
Originally Posted by K a s h View Post
It seems to be costly. .. It works out to Rs. 1500 per sheet!
American Damping, 1.5mm thick, 1m x 60cm is being sold at about 1500-1600 per sheet. This 1m x1m at 1400 looks well priced, and not very high.
Old 14th April 2012, 16:43   #974
condor's Avatar
Default Cheaper alternative to Yoga Mats.
Coming back to tackling rattling of door-pads: Forget the Yoga mats. You can do it at just 15-20% of the cost of yoga mats.
This synth sheet is used below carpets (like in offices). It is available in at least 2 types:
* 6 mm thick (black) @ Rs 50 per meter,
* 8 mm thick (white). @ Rs 60 per meter.
Width of sheet: about 50 inches.
This sheet is lighter than Yoga mats, but will do the job just as effectively.
Available in any shop that sells synthetic carpets / Car seat cover material etc. In Bangalore, there are enough shops in JC Road.
Old 14th April 2012, 23:12   #975
Thanked: 121 Times
Including tax it was around 1600/- for 11 sqft. Do note that it was 10mm thickness. The cost depend on thinkess.
manjubp is offline   (1) Thanks Reply With Quote
Alternative material for damping amit_sound In-Car Entertainment 183 30th April 2016 12:36
Sound Proofing material for car ezee Modifications & Accessories 20 13th January 2010 16:17
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
sound proofing material query makanaka In-Car Entertainment 3 11th August 2008 11:53
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
