Old 28th March 2016, 17:31   #1126
DerAlte's Avatar
Thanked: 2,879 Times
Default Re: The Damping Material and Sound Deadener Thread
Originally Posted by timuseravan View Post
I think he meant 3 layers one on top of another - but will confirm.
I will inquire about the 4 and rear door damping as you suggested - can you give an approx cost for the same?
3 layers one on top of another: if they have suggested this, quite likely their sheets are of inferior quality / too thin.
The rear door will cost only a couple of 100. All of them put together should come to 7-8K with Dampmat or Dynamat.
DerAlte is offline   (1) Thanks Reply With Quote
Old 30th March 2016, 08:53   #1127
timuseravan's Avatar
Thanked: 449 Times
One more question to the experts: I am not a big audiophile - I listen to mostly older hindi and softer songs. So is damping absolutely necessary for Scorpio doors?
timuseravan is offline   Reply With Quote
Old 30th March 2016, 09:06   #1128
Thanked: 656 Times
Yes & No.
Yes if one wants a quieter cabin, limit road noise from tyres and minimum vibrations from/to speakers. And also if one wants to notice finer nuances from songs (implying that investing in good quality speakers & amplifier).
No if above doesn't matter for one's listening taste.
sukiwa is offline   (1) Thanks Reply With Quote
Old 31st March 2016, 14:49   #1129
DerAlte's Avatar
... I am not a big audiophile - I listen to mostly older hindi and softer songs. So is damping absolutely necessary for Scorpio doors?
One doesn't have to be a big audiophile. It is enough to know that parts of the music is overpowered by the induced road noise. This happens to be in the same audio range as mid-bass, which means you are missing a part of the music. Why would you want to miss out?
Most people play audio slightly louder for overcoming the road noise. The actual solution is to damp it out.
Old 13th April 2016, 19:14   #1130
Hawkeye269's Avatar
Thanked: 184 Times
Question Re: The Damping Material and Sound Deadener Thread
After having scoured this thread for the better part of a week (had to take time off for mundane things like work, food and sleep ), I'd like to hear from you guys if the following would be a fairly ideal set-up for acoustic isolation and thermal insulation in a large SUV ("ideal" is subjective - in this case it means placing a higher emphasis on performance and a lower one on cost, all while trying not to go off the deep end with either):
  • Hood: layer of Xtreme Dynamat covered by Dynamat Hoodliner
  • Firewall (passenger side): layer of Xtreme Dynamat covered by Dynaliner
  • Floor: layer of Xtreme Dynamat covered by Dynaliner
  • Doors: layer of Xtreme Dynamat
  • Cargo area: layer of Xtreme Dynamat
  • Roof: Dynaliner
  • Underbody (including wheel wells): Würth Gravel Throw Protection Aqua Black
In this setup, what if anything would you change (no DIY suggestions please)?
Looking forward to reading your comments. Thanks!
Hawkeye269 is offline   Reply With Quote
Old 13th April 2016, 19:21   #1131
condor's Avatar
Thanked: 4,848 Times
@Hawkeye, have you got an estimate for that yet ?
I would suggest to exclude the hood. The Firewall would be key, followed by other metal sheet areas.
From the feedback I have, the under-body lining may not help drastically. But I want to try that myself before deciding.
condor is offline   (1) Thanks Reply With Quote
Old 15th April 2016, 17:57   #1132
DerAlte's Avatar
Originally Posted by Hawkeye269 View Post
... if the following would be a fairly ideal set-up for acoustic isolation and thermal insulation in a large SUV ("ideal" is subjective - in this case it means placing a higher emphasis on performance and a lower one on cost, all while trying not to go off the deep end with either) ...
... have you got an estimate for that yet ? ...
THE MOST important question, considering the last part of the para above!
* First open the bonnet and check if there is a liner. Even my 2007 Safari has it
* 'Thermal insulation' is already provided where is matters the most: the Ceiling Liner. In the areas where it really matters (day temperature >45degC), people cover the roof with a "Khus ki tatti" which they keep wet
* Most of the sound that affects ICE reproduction intrudes into the cabin from the doors - road noise is conducted via the door hinges to the outer panels, and the outer panel resonates. All cars have *some* damping provided to control NVH, but that may not make the cabin 'silent' for ICE purposes
* Boot floor already has at least one layer of felt mat - good enough
* Ditto the floor in the cabin - it usually has damping material placed strategically, as well as at least one layer of felt mat carpet
* 5th door can do with some closed-cell foam stuffing, as the number plate and wires / cables in it can rattle, especially if one has a subwoofer thumping away!
* Damping firewall is difficult - one has to completely strip the dashboard. For normal purposes, damping it doesn't give good returns!
* Underbody spray from Würth is worth it, especially for preventing rust in coastal areas
Old 15th April 2016, 18:35   #1133
There is a transparent sticker type sound dampener being released by 3M. Its very light weight compared to conventional (dynamate like) dampeners and costs 6000 for a car. I am considering this option, but I have already bought a full pack of Dynamate sound dampeners.
ForeRunner is offline   Reply With Quote
Old 15th April 2016, 18:42   #1134
Hawkeye269's Avatar
Thanked: 184 Times
From all my armchair research (long live the inter webs!), the consensus view seems to be that you can't go wrong with Dynamat. Sure it might be more expensive than other brands, or marginally thicker / heavier, but from an overall performance point of view Dynamat's pretty much the industry leader.
Old 15th April 2016, 18:45   #1135
condor's Avatar
.. fairly ideal set-up for acoustic isolation and thermal insulation in a large SUV
Question 1: Which SUV is this ?
I have tried damping mat for the bonnet of my Ikon, and it really didnt not help. I would suggest either to leave this, or look for the felt type hood liner that comes from OE.
* Most of the sound that affects ICE reproduction intrudes into the cabin from the doors - .... All cars have *some* damping provided to control NVH, but that may not make the cabin 'silent' for ICE purposes
I have opened 3 cars for such damping, though none in the SUV category. The doors did not have much in them except for pieces of anti-damping sheets there. (No foam etc). The lower priced cars had lesser damping on the floors.
@DerAlte, thanks for the inputs again. Will check the doors in the car again.
Old 15th April 2016, 18:54   #1136
Hawkeye269's Avatar
Thanked: 184 Times
Exclamation Re: The Damping Material and Sound Deadener Thread
... fairly ideal set-up for acoustic isolation and thermal insulation in a large SUV ("ideal" is subjective - in this case it means placing a higher emphasis on performance and a lower one on cost, all while trying not to go off the deep end with either)
Condor, DerAlte: thank you, gentlemen, for the prompt responses. In truth I do not have an estimate, but I already have most of the stuff lying in my store room, including:
  • Dynamat Xtreme 10455, 9 sheets measuring 18" x 32" x 0.067" (36 square feet in total) - in hindsight I'll probably need at least 2 more of these bulk packs
  • Dynamat Dynaliner 11102, 2 rolls measuring 32" x 54" x 1/4" (24 square feet in total) - I'll probably need 3 or 4 more of these as well
  • Dynamat Hoodliner 11905, 1 piece measuring 32" x 54" x 3/4"
  • Dynamat 13100, 1 roll of 1-1/2" DynaTape
  • Dynamat 10007 Dyna-Roller
Consequently, cost is somewhat moot for me at this stage...
Old 3rd May 2016, 21:10   #1137
sandeepmohan's Avatar
Thanked: 1,869 Times
Does applying damping material such as Dampmat, etc arrest vibrations from the plastic door panel?
From what I see, the damping material is being applied to the metal door frame. Not quite sure how this arrests or stops the plastic door panel from vibrating.
The plastic door panels on my Fiat Linea vibrate without even playing music too loud. If I invest in damping material, where do I apply it.
sandeepmohan is offline   Reply With Quote
Old 6th August 2016, 12:15   #1138
Gurus, need some guidance.
While we are talking about damping, I feel that NVH levels in my Innova (Jan 2009, 65 K kms done) have increased. Damping may be one way of reducing this, but was thinking of getting all the fasteners tightened, rubber and bushes checked and replaced. I feel aging may have damaged or hardened the rubbers and this might be leading to higher NVH (I dont hear too many rattles though)
Any suggestions and experience on this please.
Cinquecento500 is offline   Reply With Quote
Old 22nd August 2016, 16:36   #1139
straight6's Avatar
Thanked: 118 Times
Guys,
I'm getting Wurth damping sheets of 11mm thickness and 1000 x 500 size. Will these be good for our purpose or will they be too thick? And how many sheets of that size will I require for the SX4?
straight6 is offline   Reply With Quote
Old 2nd December 2016, 09:38   #1140
Thanked: 161 Times
Does any one know a good installer for Dynamat Hoodliner in Mulund, Mumbai? Rats have eaten away the factory fit damping cover under the bonnet and i need it replaced. Thanks
jinu_joseph is offline   Reply With Quote
Alternative material for damping amit_sound In-Car Entertainment 183 30th April 2016 12:36
Sound Proofing material for car ezee Modifications & Accessories 20 13th January 2010 16:17
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
sound proofing material query makanaka In-Car Entertainment 3 11th August 2008 11:53
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
