Old 2nd December 2016, 10:10   #1141
Leoshashi's Avatar
Thanked: 12,618 Times
Default Re: The Damping Material and Sound Deadener Thread
Originally Posted by jinu_joseph View Post
Does any one know a good installer for Dynamat Hoodliner in Mulund, Mumbai? Rats have eaten away the factory fit damping cover under the bonnet and i need it replaced. Thanks
Why not purchase a new OEM damping?? Which car is it??
Shashi
Leoshashi is offline   (4) Thanks Reply With Quote
Old 2nd December 2016, 12:38   #1142
Thanked: 150 Times
This is a Skoda Superb TDI. I checked with the workshop and they said they dont have it in stock and not available anywhere in India in stock as of now. If required an order will have to be placed and it is very expensive. He said it could cost upwards of 30K
jinu_joseph is offline   Reply With Quote
Old 2nd December 2016, 15:40   #1143
manson's Avatar
Thanked: 2,142 Times
Check with Pai Auto at Santacruz (Tel: 022 2661 4798) if they can arrange for an OEM unit. Either way, their workmanship is good and they would do a good job even with an aftermarket liner if you / they can arrange for one.
manson is offline   Reply With Quote
Old 2nd December 2016, 20:28   #1144
DerAlte's Avatar
Thanked: 2,877 Times
Originally Posted by straight6 View Post
... Wurth damping sheets of 11mm thickness and 1000 x 500 size. Will these be good for our purpose or will they be too thick? ...
2 issues:
1. Could be too thick when applied over bends and discontinuities - will not hug the profile
2. If density is too less, damping will not be efficient
DerAlte is offline   (1) Thanks Reply With Quote
Old 2nd December 2016, 22:58   #1145
straight6's Avatar
Thanked: 115 Times
Originally Posted by DerAlte View Post
2 issues:
I eventually bought 44 sq ft of Dampmat Exceed. Installation will be done soon.
straight6 is offline   (2) Thanks Reply With Quote
Old 8th September 2017, 16:43   #1146
HimuraKenshin's Avatar
Thanked: 183 Times
Does anyone know where i can purchase noise kill damping material in mumbai or navi mumbai
HimuraKenshin is offline   Reply With Quote
Old 7th December 2017, 11:58   #1147
Dramitn's Avatar
Thanked: 52 Times
Anybody here has a good recommendation for damping of the car in Pune/Kolhapur?
Dramitn is online now   Reply With Quote
Old 15th January 2018, 16:06   #1148
SJM1214's Avatar
Thanked: 253 Times
I went for damping in my new MS Vitara Brezza. It was to tackle high NVH level inside the cabin. I went for all 5 doors damping in my car. Somehow, I m still not satisfied with the result. I m thinking to go for boot floor damping and cover other places which are not covered.
My question is, won't it increase the overall weight of the car? Is it advisable?
STP i SILVER ANTIRUST DAMPING sheets. Rs. 1200 per sheet. Used 5 sheets for 5 doors.
SJM1214 is online now   Reply With Quote
Old 15th January 2018, 16:45   #1149
navin's Avatar
Thanked: 3,980 Times
Did you notice any difference in the NVH levels after damping the doors? Perform a "rap test" on the outside of the doors and see if you hear any metal ringing.
Damping the boot floor etc. will not have as significant a change as damping the doors. Another source of road noise is from under the car and from the firewall but damping these areas requires you to remove the carpet and I find that in many cases they are not able to re-install the carpet as original.
That said even if you damp the boot floor and under the carpet the added weight will not make a significant change to your car's acceleration.
After all, all the damping you add will not total 20kgs (about the size of a big child). Even if you added a couple of amps and a subwoofer the effect on acceleration would be minimal.
navin is offline   (2) Thanks Reply With Quote
Old 15th January 2018, 17:10   #1150
SJM1214's Avatar
Thanked: 253 Times
Yes. NVH level was decreased after damping but not up to the marks. Noise is high on bad patches and at high-speed.
To tackle the road noise from under the car, I installed PVC carpet mat along with 3M Nomad floor mat. So, now I have two (in fact three, if we consider stock carpet) layers of mats on my car floor. However, these mats are not installed on boot floor, that's why I was thinking to go for damping of boot floor.
PVC Carpet Mat.
3M Nomad Mat.
Thanks for Input Navin ji.
SJM1214 is online now   (2) Thanks Reply With Quote
Old 16th January 2018, 10:26   #1151
navin's Avatar
You can damp the boot floor but don't expect a huge difference from where you are now.
navin is offline   (1) Thanks Reply With Quote
Old 29th January 2018, 16:07   #1152
supertinu's Avatar
Thanked: 460 Times
I think there is so much you can do to improve beyond a certain point. Alternate view point in my mind is that too much damping means lot more rubber which is fairly flammable in nature . May not be a genuine risk since most things are anyways easily flammable inside a car.
Another option could be the anti rust 3M rubber coating of the underbody. That also helps a bit.
supertinu is offline   (1) Thanks Reply With Quote
Old 29th January 2018, 16:40   #1153
SJM1214's Avatar
Thanked: 253 Times
3M anti-rust Underbody Rubber Coating is allready done. I think I have to learn to live with this NVH level.
Old 29th January 2018, 17:57   #1154
supertinu's Avatar
Thanked: 460 Times
What about tires? they also make a huge difference to NVH of a car. Are you running OEMs? they are typically not the best brands. Softer ones like Michelin XM2 would also help a fair bit.
supertinu is offline   Reply With Quote
Old 29th January 2018, 18:22   #1155
Thanked: 738 Times
Perfect thread to upload a few pics of how i managed to dampen the boot door due to the woofer rattle in my Hexa. The base quality post this is seriously amazing!
abhi7013 is offline   (1) Thanks Reply With Quote
Alternative material for damping amit_sound In-Car Entertainment 183 30th April 2016 12:36
Sound Proofing material for car ezee Modifications & Accessories 20 13th January 2010 16:17
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
sound proofing material query makanaka In-Car Entertainment 3 11th August 2008 11:53
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
