Old 15th May 2006, 19:33   #1
Thanked: 1,503 Times
Default JBL Bass Pro II
Dear ICE Gurus
What is your opinion on the JBL Bass Pro II Active Sub? Would it be better than the Blaupunkt ODsb 8000A ?
Proposed application - Tata Safari which already has the Blau. Will go for the JBL if it is considered better than the Blau, in which case I need to find a buyer for the Blau.
Humbly yours in ICE,
Steeroid is offline   Reply With Quote
Old 15th May 2006, 20:00   #2
Bass&Trouble's Avatar
Thanked: 71 Times
Better is subjective, considering I haven't heard the JBL. The Blau I have heard, and have not returned very impressed. The JBL is certainly more powerful in terms of the amplifier power, and is more pleasing to the eye
Old 15th May 2006, 22:42   #3
kb100's Avatar
Dont know if I qualify as a shishya.. but having seen/heard your blau I feel you can do with a lot more bass in the car ... I am no bass head but the JBL can be an immense improvement...
You also need to upgrade your speakers and hook a basic 4 channel amp to it... Will take your SQ into another league!
Take a look at the Innova install pics.. should give you am idea or two... I feel two 10" under the front seat should take care of things - esp considering you drive and dont get driven... well ... most of the time!
kb100 is offline   Reply With Quote
Old 15th May 2006, 22:57   #4
navin's Avatar
Thanked: 3,882 Times
I'd take the blau woofer and stuff it under the front seat if it will go there by moving some bass to the front. then use the JBL for some more bass.
Old 16th May 2006, 12:23   #5
jkdas's Avatar
Thanked: 1,389 Times
CAnt do that Navin, its an active one and hence a bit bulky even to go under the Safari's frnt seat.
As KB said, 10incher under frnt seat and another 12 inch for the boot. Then a very decent mono amp and a 4 channel amp for your big car will do good. Also look at hertz range ( or ID?) as they need less vol for teh box.
Old 16th May 2006, 13:00   #6
jkdas's Avatar
Is this teh JBL thingy ? The one on the left. The other one is teh Pio one
Old 16th May 2006, 13:33   #7
Good idea. I've been toying with the idea of putting the blau betweent the two front seats (it will fit in there) after removing the blowers to the rear seats that are currently there. The rear seats are adequately served by the roof-mounted a/c coils so there's no real need for the floor-level blowers - this might in fact improve the airflow to the front seats as well.
Two Subs in my Safari????
Old 16th May 2006, 13:38   #8
navin's Avatar
The safari's cab is large it will accomodate 2 subs quite well.
Old 16th May 2006, 13:58   #9
Sam Kapasi's Avatar
Thanked: 1,452 Times
bass pro II is not quite to my liking. I don't recommend it to you steer. *shrug*
Old 16th May 2006, 14:04   #10
Thanks Sam. I'll still go ahead with the Blau relocation and leave the space behind as 'available' for another sub...do you think it will serve as a second sub well enough? If the front is served by the Blau and the rear by the JBL, we might still be able to get the desired result, right? Or dyou think not?
Old 16th May 2006, 14:12   #11
Sam Kapasi's Avatar
It's a nice compact active sub. Tight (Quad coil 8") but the sound... well i dont like it at all. I dont think you should buy it.
Old 16th May 2006, 14:17   #12
Thank you. I wont buy it...that effectively closes the subject. Whoever said ICE guys never reach a conclusion?
Now I need to look for alternatives that will fit in the space vacated by the Blau.
Old 16th May 2006, 14:20   #13
jkdas's Avatar
Steer would the active blau subs go under that seat???
Steer how abt some tuned ported sub by Pio? Its bigger than your current blau sub. Or maybe you can get a proper sub box like gto1200b and a good amp for it?
Old 16th May 2006, 14:23   #14
Nope. I'm (thinking in terms of) putting it BETWEEN the front seats - its shape is quite similar to that of a plastic console that may normally have been between the seats (if not for the rear a/c vents). Thats a lot of bass close to you, though...maybe I'll get a Bass-massage as I drive.
Old 16th May 2006, 14:52   #15
navin's Avatar
Steeroid, just so that you know 2 8" woofer have about the same area as a 12" woofer so in case you dont have room for 1 bog box with a 12" woofer you may be able to squeeze 2 small boxes with 8" woofers.
Eicher introduces 3 reefer trucks - Pro 1059XP, Pro 1100XP and Pro 6025 Aditya Commercial Vehicles 0 22nd December 2015 18:01
Eicher launches Pro 8031XM, displays Pro 6025T trucks at EXCON 2015 Aditya Commercial Vehicles 0 26th November 2015 14:40
For Sale - JBL Bass Tube Revvhead Shifting gears 8 18th July 2007 08:32
JBL Bass Pack for Sale Chetu Shifting gears 5 23rd April 2007 11:23
Bass Box 6 Pro flipsyde In-Car Entertainment 8 5th March 2007 15:43
