Old 17th May 2006, 15:04   #16
Thanked: 17 Times
Sounds like the Wiring is the culprit here. You've to get the wires seperated and check the monsters are real monsters.
Old 17th May 2006, 15:19   #17
frankmehta's Avatar
Thanked: 2,334 Times
ok thanks for all this feedback.....
the car has gone for a week for a holiday i will get it checked out for the checkpoints mentioned by all of youll....
frankmehta is online now   Reply With Quote
Old 23rd December 2008, 09:02   #18
Thanked: 36 Times
Default Whining sound coming from speakers
My speakers have started to give out a high pitched wheee.... sound since a couple of months. The sound is absent when the engine is off but comes on as soon as engine is turned on. The pitch appears to increase with the engine rpm. Though the wheeee.. sound is low enough it is annoying while playing FM or during some silent gaps in the CD.
Interestingly I have observed that the sound goes away when it rains
zaks is offline   Reply With Quote
Old 23rd December 2008, 10:48   #19
navin's Avatar
Thanked: 4,286 Times
1. check your RCA wiring
2. does the tone of the whine change when you rev your car?
Old 23rd December 2008, 12:13   #20
Thanked: 36 Times
Yes, it goes to high pitch with high rpm.
Old 23rd December 2008, 12:22   #21
Technocrat's Avatar
Thanked: 2,589 Times
Try this - turn your stereo on without the engine running. Do you still hear the whine?
Old 23rd December 2008, 12:30   #22
navin's Avatar
Looks like faulty RCAs.
Old 23rd December 2008, 14:46   #23
nitrous's Avatar
Thanked: 285 Times
Please do check the gains on your amp.
It shouldn't be over 50%.
Old 23rd December 2008, 14:51   #24
Thanked: 36 Times
No.
Really, because I think they used the cables from Illusion Audio.
They are < 50%
Old 23rd December 2008, 14:55   #25
DjNik's Avatar
It is a alternator whine.You will most probably have to ground the Rca preouts to the HU.This will most probably solve your problem.
DjNik is offline   Reply With Quote
Old 23rd December 2008, 14:58   #26
Technocrat's Avatar
So thats an Alternator whine. The more electronic equipment you switch on (read a\c, wipers, headlights) the more audible the whine will be.
The Illusion audio speakers must be the ones used for speakers, the RCAs are used from HU to Amp.
Old 23rd December 2008, 15:17   #27
sonirohit's Avatar
Is it a Pioneer HU??? If yes the solution is usually a straight forward and a DIY - just ground the RCA connectors, it solves the whine.
If it is not a pioneer HU - then the problem is with the cables.
Is the Power Cable running alongside the RCA cables? If yes then make sure the Power and RCA cables run through opposite sides of the car.
If that doesn't solve the problem - upgrade to better quality RCA Cables.
If that doesn't solve the problem - try adding the line noise filter (I've got no idea what it does or what it's for)
I had a pio and the first one did the trick for me...
sonirohit is offline   Reply With Quote
Old 23rd December 2008, 16:35   #28
Thanked: 36 Times
This whine was not present at the time of installation but is there only from the past 2 months. The RCA cables are Cadence, I think.
Old 23rd December 2008, 16:37   #29
Technocrat's Avatar
Zaks- Ditto with me, it just started one fine day.
Old 23rd December 2008, 17:34   #30
Thanked: 36 Times
So it cannot be cable problem then, could it be loose ground connection at HU?
Suzuki names son Toshihiro as President. India to make up 60% of global volumes by 2020 volkman10 The Indian Car Scene 7 7th July 2015 01:46
Whining sound from throttle body in My Spark electricheart Technical Stuff 15 28th January 2014 18:15
Fiat Linea MJD : Turbo whining sound? S.I.N.G.H Technical Stuff 16 20th June 2011 23:49
Swift = Whining in Overdrive ballkey Technical Stuff 40 18th September 2009 10:22
WHINING SOUND - Pioneer HU - Any Help ? passion4cars In-Car Entertainment 4 23rd August 2008 18:48
