Old 17th May 2006, 02:48   #1
freakrz's Avatar
Thanked: 50 Times
Default Polk Momo C 500.1 Mono Block AMP
hi..guys ..i am looking for an amp to power up my alpine SWR 1242 D Sub in my swift...i earlier checked on alpine MRP M450 and JL 1200e Amps..but now i have got a better deal on the polk c.500.1 mono block amp.
the specs for the sub are..
Power Handling
* • Power Handling Capacity (Peak) : 1500W
* • Power Handling Capacity (RMS) : 500W
General
* • Diaphragm Material : Kevlar Reinforced Pulp
* • Spider Material : Nomex
* • Frequency Response : 23Hz - 500Hz
the specs for the amp are
Power
Channels 1 MonoBlock
Total Dynamic Power (all ch. driven) 975 watts
14.4 Volts RMS Not Bridged @ 1kHz
4 Ohms 350 watts x 1
2 Ohms 500 watts x 1
Electrical
Signal-to-noise (Referenced to rated power) > 105 dBA
Remote Gain 0 to -30dB
Input Impedance > 10k Ohms
Output Impedance < 0.02 Ohms
Overall Frequency Response (-3 dB Points) < 10Hz to 200Hz
Protection circuitry Power and ground reversal, Thermal and Short, Current
Overdraw and Low Impedance Protection with auto stand-by mode
Filter Settings
Subsonic Filter 24dB/Octave @ 15Hz
Low Pass Filter frequency 30Hz to 200Hz
Low Pass Filter slope 12 or 24dB/Octave
I would like to know if this amp would be a better alternative to the alpine MRP M450 / JL 1200e.
freakrz is offline   Reply With Quote
Old 17th May 2006, 10:44   #2
amit_sound's Avatar
hi,
How much is the amp costing??, Is it a class D mono amp?
amit_sound is offline   Reply With Quote
Old 17th May 2006, 11:05   #3
navin's Avatar
Thanked: 4,265 Times
http://mobile.jlaudio.com/products_amps.php?amp_id=257
http://www.alpine-europe.com/content...-AMPLIFIER.htm
the momo amp puts out 500W at 2 ohms v/s 275 for the JL as per above links. The Alpine puts out 400W but has one confusing spec.
"Per channel into 4 ohms: 220W x 1 (1% THD)
Per channel into 2 ohms: 400W x 1
Brigded 4 ohms: 600W x 1 "
how does one bridge a mono amp! ???
Old 17th May 2006, 12:25   #4
Autophile's Avatar
Polk Audio amplifier is good, the amps equivalent and comparable to Polk is JL Slash Series 500/1 and Alpine V12 Series MRD-M605. Not the lower end ones.
Autophile is offline   Reply With Quote
Old 17th May 2006, 12:53   #5
Thanked: 294 Times
Navin ji it is a typo on the alpine europe part
http://www.crutchfield.com/S-76BDcGG...120&I=107C5001
http://www.alpine-usa.com/en/product...model=MRP-M450
U can go for the polk as it the most powerful in all the three. Also the S/n ratio is better than alpine and jl is a ab class . rest it is ur money use it where do u like.
Old 19th May 2006, 00:34   #6
freakrz's Avatar
Thanked: 50 Times
Originally Posted by amit_sound
hi,
yes its a class D amp and its costing around 349$...
Old 19th May 2006, 00:39   #7
freakrz's Avatar
Thanked: 50 Times
Thanx for your advice...!
how would you compare the alpine MRP M650 with the polk..the alpine is costing around 200$ and its specs are below..
i would be saving 150$ if i go for this one..only if its best suited for the sub rather than the polk...
SPECIFICATIONS
CEA-2006 Power Rating
* • CEA-2006 Power Rating (40hm@14.4V = 1%THD+N), S/N 65dBA (Ref. 1W into 4Ohm): 400W x 1
RMS Power (at 14.4V THD+N, 20Hz-20kHz)
* • Per channel into 4 ohms: 400W x 1 (0.08% THD)
* • Per channel into 2 ohms: 600W x 1
Bass Engineฎ Sound Tuning
* • Crossover Frequency : 50Hz-200Hz,-24dB-oct (LP)
* • Subsonic Filter (Fixed): 15Hz
* • Bass EQ Frequency (Fixed): 50Hz 0 to +12dB
Dimensions
* • Heat Sink (WxHxD) in: 11-1/64" x 9-31/64" x 2-23/64"
* • Heat Sink (WxHxD) mm: 280mm x 241mm x 60mm
* • Foot Print (WxHxD) in: 12-7/8" x 9-31/64" x 2-23/64"
* • Foot Print (WxHxD) mm: 327mm x 241mm x 60mm
General
* • Power Requirements: 14.4V DC (11V to 16V)
* • Fuse Type: 30A x 2
* • Frequency Response: 20Hz - 200Hz (+3/-3dB)
* • Signal to Noise (S/N): 90dBA (Reference to Rated Power)
* • Input Sensitivity (For Rated Power): 0.2V to 4.0V (1.0 at Center Detent)
* • Input Impedance: 10k Ohm
* • Speaker Impedance: 4 or 2 ohm
Old 19th May 2006, 10:25   #8
navin's Avatar
Lets get this straight
The Alpine 605 is costing $200 and puts out 600W at 2 ohms The Polk cost $350 and puts out 500W at 2ohms (@ 14.4V). I dont see a question.
Old 19th May 2006, 22:20   #9
panky12345's Avatar
Thanked: 147 Times
alpine MRD 605 for 200 $?? i doubt sir....even ebay is offering it for $ 260 +
Old 20th May 2006, 00:00   #10
freakrz's Avatar
Thanked: 50 Times
i got a deal for alpine MRD M605 for $230 thats the best i have ever found online....but when i checkd the MRD M650 the RMS and some other specs seems to be same except 605 is a V12...what is the actual difference except for the pricing...
Old 20th May 2006, 00:02   #11
freakrz's Avatar
Thanked: 50 Times
its not alpine MRD-M605 ...its the 2006 alpine MRP-M650... i guess its a new model..
Old 20th May 2006, 02:52   #12
panky12345's Avatar
Thanked: 147 Times
its here, http://www.crutchfield.com/S-L3fMZTC...0&I=500MRPM650
it says its a V class amplifier, i dunno whass the diff between V and V12 series thou.
i dont see much of a difference between the PM and Alpine except the brand name and price tag!
Old 20th May 2006, 06:43   #13
navin's Avatar
Alpine V12 amps allow you to tune the amp from some Alpine HU but you need an expensive connector cable to do that.
Beyond that I think there is little difference. The 2 amps weigh about the same. (3.7 v/s 3.9 kg).
from Alpine's website
"Extensive control doesn’t mean much if you have to crawl under the hood or take your equipment apart to do it. Amplifier Link lets you make comprehensive sound adjustments to all the V12 AccuClass-D amplifiers in your system — up to eight of them — directly from the head unit. A total of 11 parameters can be adjusted, including Digital Time Correction, Crossover and Parametric EQ. Amp temperature, voltage and current are even shown on the head unit display, and each amp can be named for easy identification."
here the link
Old 20th May 2006, 21:56   #14
freakrz's Avatar
Thanked: 50 Times
thanx navin...right now my setup consists of alpine 9852 HU,Alpine SVR 1242D type R sub, polk momo db6750 components and polk momo mmc690 coax speakers..and if i get the alpine mrv m650,since i m just lookin to power my sub ...would this amp be good enough,instead of mrd m 605.in terms of powering the sub and pricing...
Old 2nd June 2006, 20:50   #15
panky12345's Avatar
Thanked: 147 Times
can somebody give me the RMS @ 12 V and current drawn by Alpine MRP-M650?
Confused between Pioneer 308d4 or Polk db1240 or Polk db1212 althaaf In-Car Entertainment 10 27th October 2011 14:03
Alpine SWR-1222D for Pioneer Mono Block D510 kiran1103 In-Car Entertainment 6 22nd March 2008 12:17
Polk MOMO Swift blueraven316 In-Car Entertainment 44 13th August 2007 20:49
Polk Momo Demo Car blueraven316 In-Car Entertainment 56 31st July 2007 07:36
HU Query for JBL speakers was "Polk MOMO vs db Compos" hyper-VTEC In-Car Entertainment 43 13th December 2006 15:03
Copyright ฉ2000 - 2018, Team-BHP.com
