Old 23rd May 2006, 21:26   #16
Sam Kapasi's Avatar
Thanked: 1,453 Times
Originally Posted by sharu
hi speedzak,
planning to get rear - GTO 937 6X9 for the rear, so need a box....also do we need to go for the custom box made by the installer, or are the boxes available from the manufacturer itself.....
i suppose custom made boxes would be cheaper....any idea wht material they need to use
Generally .75 inch MDF is ok.
Old 24th May 2006, 01:27   #17
Thanked: 16 Times
Sam has said it. Using MDF will be good.
And putting some sound dampening inside the box will make it more bettter. Make sure not to put any loose objects in the box (like wire pieces, sponge pieces etc..)
Old 24th May 2006, 07:00   #18
hello i have one doubht, as iam totally ignorant in amp installation cant we install an amp somewhere in the front and avoid that extra wiring of placing the amp in the back. my car is baleno lxi.
premdiv is offline   Reply With Quote
Old 24th May 2006, 11:30   #19
Sam Kapasi's Avatar
Yes you can install an amplifier under your seat in the Baleno. Generally I recommend putting the amp in the back, it's a neater install, easily accessible for settings and change of mind etc.
Old 25th May 2006, 09:09   #20
jkdas's Avatar
Thanked: 1,389 Times
what are you gonna save? 500rs??? Save 500 if you want someone to park his legs on your amp. Dude. Baleno has a boot, use it! If my car had a boot, damn, can I start? Get it screwed to the back of boot or so. Check my pix.
Woofer from a computer sound system possible in a car audio setup? Deeps In-Car Entertainment 2 5th August 2008 22:51
Car Audio Setup for SANTRO XING jkdas In-Car Entertainment 588 7th October 2007 10:38
Ice Setup Zen Ė Audio Gurus plz help nicejits In-Car Entertainment 14 20th September 2007 15:45
Advice needed for high end audio setup for my car Aryaan In-Car Entertainment 9 12th September 2007 10:40
Please Advise on this Car Audio Setup k_ajay In-Car Entertainment 29 6th July 2005 13:11
